Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Tech Archive (No Posting)
Tech Archive (No Posting) This will also temporarily hold all of the old gen specific threads until they are all moved to the correct categories.
Some Indicator lights do not work!
Technical forums are exclusively for technical discussions.
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
Limit your posts to helpful responses, and do not tell members to "Go Search", unless you also provide some specific guidance on the technical question or problem.
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 03-02-2008, 04:28 PM   #1
dementor
dementor is on a distinguished road
Default Some Indicator lights do not work!
Hi guys,
I just noticed several of my indicator lights do not work on my Canadian 00 civic SE - and yes, they used to! I don't know when they stopped working. Here are the ones that DO NOT work:
-low oil pressure indicator
-parking brake indicator
-ABS indicator
-Malfunction Indicator lamp
-Low fuel indicator
-washer level indicator
The rest work fine, and illuminate when I have my key in the on position.
What do you guys think the problem is? Fuse? Light bulbs? Something else?
dementor is offline
Old 03-02-2008, 04:55 PM   #2
knightxrider1
knightxrider1's Avatar
knightxrider1 is on a distinguished road
take the cluster out. w that many probs. maybe the harness in the back is loose.
knightxrider1 is offline
Old 03-02-2008, 05:03 PM   #3
dementor
Ok I took the cluster out, I have it here in my hands hehehe
I made a mistake... not all those lights are out. Just these 3:
-Low fuel indicator
-Trunk indicator
It doesn't appear to be the light bulbs.
dementor is offline
Old 03-02-2008, 05:11 PM   #4
simmons
simmons's Avatar
simmons is on a distinguished road
try looking for broken fuses, this has happened to me before and a couple of fuses needed replacing
simmons is offline
Old 03-02-2008, 05:29 PM   #5
dementor
Any specific fuses? itd be annoying (and COLD!) to go through every fuse in the car looking for a broken one.
dementor is offline
Old 03-02-2008, 05:34 PM   #6
simmons
simmons's Avatar
pop the bonnet and the fuse box lid should have a diagram showing which fuses affect certain areas.
look for the one you're having problems with and hopefully that means you won't have to go through all of them! cold? you woman!
simmons is offline
Old 03-03-2008, 12:50 PM   #7
dementor
Should it be the fuse box under the dash, or under the hood?
dementor is offline
Old 03-04-2008, 12:20 PM   #8
dementor
Ok, fuses look good, light bulbs are fine... What else can I potentially check?
dementor is offline
Old 05-14-2008, 05:02 AM   #9
Lisa-Adam
Lisa-Adam is on a distinguished road
In this forum there is no any person who suggest you better. So Suggest to mechanic.
Get information about Gary Winnick from The New York Times.
Lisa-Adam is offline
Old 05-18-2008, 12:18 PM   #10
Shamus
Shamus is on a distinguished road
I have the same problem with my 00 EX. Let me know if you figure anything out.
I swapped bulps, checked fuses, and wiring. So far, nothing!
Shamus is offline
parking lights work but the brake lights dont, confusedddd! HELP Jabes Interior / Audio / Electronics 0 08-18-2011 12:13 PM
What lights SHOULD work? civic21911 Interior / Audio / Electronics 2 11-18-2010 12:01 AM
reverse lights dont work and right turn signal doesn't work 100% jazzyJAE Interior / Audio / Electronics 5 09-14-2010 09:13 PM
low beams, tail lights, park lights, and brake lights dont work? need help? scotty0607 Interior / Audio / Electronics 3 09-12-2010 04:15 AM
blinkers wont work but hazard lights work. hondamnit99 Exterior / Detailing / Bodywork 3 03-14-2009 01:22 PM
