Search:
Welcome to ClubCivic
Rough Idle Troubleshooting
Ľ Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
Ľ Responding Members:
Ľ All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
User Tag List
Old 12-09-2006, 09:27 PM   #1
kyle10182
NA is Best
kyle10182's Avatar
Default Rough Idle Troubleshooting
alright, i was just reading a post about a rough idle. some people seem to think that they are the first honda owners to have this problem. well its a common problem. especially after a swap. well i visit G2IC.com a lot. and they have a lot of useful information on there that can help these problems. im going to copy a post from there that can hopefully help everyone with their idle problems. maybe a mod will even sticky this to keep down on the bad idle threads everyday.
Bad Idle Troubleshooting
This is for high and roaming idles but may work for low idles as well.
First, terms:
TB Ė Throttle Body
IM - Intake Manifold
IACV Ė Idle Air Control Valve (also called the Electronic Air Control Valve or EACV)
FITV Ė Fast Idle Thermo Valve
TPS Ė Throttle Position Sensor
I finally got the swap (b18a) in my civic. Unfortunately when I started it up it idled at 3k and then had a hunting idle from 2k to 2500 rpm when it warmed up. I stood over that thing for 3 days, testing and scratching my head. On top of that I did a TON of searching on the h-t, hybrid boards, and on here. I hope what is contained within helps someone. Maybe they wont have to go through as much work as I did.
The idle on our Hondas is a tricky thing. It is controlled by two main sensors: the FITV and the IACV. The FITV is a mechanical valve that is controlled by coolant temperature (there is no ECU plug to it). When the coolant is cold the valve is open and letting air into the IM through a hole in the TB before the throttle plate. This essentially creates a small vacuum leak which in turn lets the motor idle higher than normal (supposed to be around 1500-2k for warming up). As the coolant warms up the valve closes and no longer lets air in through the hole in the throttle body. All the while the IACV, which is ECU controlled, is letting small amounts of air into the IM through another hole in the TB. Any amount of extra air the ECU is not expecting will confuse it and you will get either a high idle or a roaming/hunting/fluctuating idle. On to the troubleshooting.
First things first, donít skip any of these steps. From what I have read (and experienced) usually small dumb things cause these problems so donít overlook anything. Also refer back up to the pictures if need be.
1) Check your vacuum routing. On the underside of your hood there should be a vacuum diagram. If there isnít a diagram under there, there is one in a Helms, Chiltons, or Haynes manual for your car (you should have one of these anyway). Remember, ANY extra air will confuse the ECU. Check for cracked or bad vacuum hoses. If in doubt just replace the hose, they are cheap.
The PCV valve could also be the culprit. Take it out and examine it. If it is cracked it could be causing a vacuum leak. Replace the peice if you arent completely sure it is ok (the helms/chiltons/haynes manuals tell you how to check it).
2) Check to see that your throttle plate is closed all the way. Take your intake off at the TB and check to see that nothing is blocking the plate. If nothing is in the way and it isnít closed all the way, loosen your throttle cable.
3) Check to see if the nuts holding the TB and the IM on are tight, this was the source of my idle problem. If they are loose, tighten them.
4) Bleed your coolant. Some air bubbles may throw the FITV off and keep the valve open.
5) Take the 3 10mm bolts out of the FITV (you donít have to take off the coolant lines). Then take off the 2 8mm bolts off the plate on the back of the FITV. Once the plate is off you will see a white plastic thing, screw that all the way in. This causes a TON of peopleís hunting idle problems (itís a source of a vacuum leak). Put the FITV back on and start the car up. If it still idles bad go on.
6) Clean the IACV screen(s). See Ozís write up elsewhere on G2IC.
7) Make sure your car is completely warmed up. With it running, take the intake off the TB. There are 2 holes right in front of the throttle plate, these are the holes that feed the IACV (top hole) and the FITV (bottom hole). With your finger, cover up the bottom hole (it should NOT be sucking if your car is warmed up). If the idle goes down the FITV is to blame, either get a new one or take it apart and screw the valve completely closed (I have only read of people doing this, so I donít know exactly how. Also, you will have to keep the engine speed up yourself when the car is cold).
Next cover both holes up with your fingers. The car should sputter and die (or almost die). If it does then the source of your crappy idle is the IACV. Replace it. If you want you can test the IACV. Shut the car off and put + battery voltage to the blk/yel terminal (on the valve) and momentarily touch ground to the blu/yel side. When doing this the valve should click, if it doesnít, replace it.
If, when covering both holes the car still has a high idle, you have a vacuum leak somewhere. Again check the IM and TB nuts. You can spray carb cleaner around those areas and if any gets sucked in (the engine will rev) you have found your leak. Another source of vacuum leaks are where the FITV and IACV connect to the IM. Either replace the gaskets or use silicone gasket sealant.
8) If nothing has worked you should test your TPS. Probe the middle wire on the TPS plug (with the key on but not running, and the plug still connected to the sensor) with the + probe on the volt meter, and the neg probe to ground. You should have .5v with a fully closed throttle plate and 4.8v with it wide open. If the TPS is off, replace it. My TPS was .425v to 4.55v and it idles fine now so I donít know how big the margin of error is. Also, it is pretty rare for these to go bad.
9) If, still, nothing has worked you might want to try a new ECU. This also is very unlikely, but worth a try.
10) If it still idles bad, go through the steps again.
I really really hope this helps someone out. It was a pain to have this mysterious problem and very little info on how to go about troubleshooting it. Comments or suggestions are welcome.
This information comes from Ben Ogle @ G2IC.com.
kyle10182 is offline   Reply With Quote
Old 12-09-2006, 09:31 PM   #2
si-hatch86
undesputed slowhatch
si-hatch86's Avatar
no im the only person that has EVER had this problem
good post
"fighting for peace is like f@cking for virginity"
transzex of d-series.org
....only stupid people hydro lock motors....
Originally Posted by turbo95eg6
You give your mom "hard rides"...?
ED squad #2
si-hatch86 is offline   Reply With Quote
Old 12-09-2006, 09:51 PM   #3
stealthy
4 Doors For More Whores
good s***
--BJ--
- GSR Sedan
- CP 81.5 9:1 Pistons
- Eagle H Beam Rods
- Garrett T3/60-1 .63a/r
stealthy is offline   Reply With Quote
Old 12-09-2006, 10:06 PM   #4
kyle10182
NA is Best
kyle10182's Avatar
Originally Posted by stealthy
good s***
u should read on g2ic's forced induction forum.
Old 12-10-2006, 08:50 PM   #5
rexman
hondas for life
wow......after all the frustration who wouldve known it was that simple. GOOD post man!!
rexman is offline   Reply With Quote
Old 12-11-2006, 05:52 PM   #6
kyle10182
NA is Best
kyle10182's Avatar
i think this should be stickied. to prevent the same questions coming up everyday because of these common problems...
Old 12-11-2006, 06:23 PM   #7
rexman
hondas for life
definatly
Old 12-11-2006, 06:29 PM   #8
kangaroo
..........UPS.........
kangaroo's Avatar
NIce...Nice..Nice....
kangaroo is offline   Reply With Quote
Old 12-11-2006, 06:34 PM   #9
BuiltforSin
BuiltforSin's Avatar
great post!
BuiltforSin is offline   Reply With Quote
Old 12-13-2006, 01:58 PM   #10
Rex_89
Rex_89's Avatar
Good post deifently helped out. I was just wondering. If someones timing is a little off, it could make the idle off too right? I didnt see that mentioned and thats why I was wondering.
Rex_89 is offline   Reply With Quote
Old 12-13-2006, 05:18 PM   #11
kyle10182
NA is Best
kyle10182's Avatar
u mean cam timing or ignition timing? i dont think ignition timing will have anything to do with it.
Old 12-13-2006, 09:53 PM   #12
Rex_89
Rex_89's Avatar
No, I mean cam timing. Cant that mess up the idle?
Old 12-13-2006, 09:56 PM   #13
kyle10182
NA is Best
kyle10182's Avatar
i dont think it would. maybe if its off by one tooth. you'll notice alot more then idle if its off by anymore then that...
Old 12-14-2006, 01:26 AM   #14
Rex_89
Rex_89's Avatar
I think my s***s off a little. Probably like by one tooth. Also sounds like my exhaust is spudering. I dont know but im pretty sure my cams are off by a tooth or so. Hopefully I will try to fix it this weekend.
Old 12-14-2006, 10:10 PM   #15
kyle10182
NA is Best
kyle10182's Avatar
is it in limp mode?
Help Troubleshooting Idle/Engine issue for 1997 Civic EX dkanter 6th Generation Honda Civic (1996-2000) 14 11-26-2009 11:19 PM
Rough Idle SleepingSol Engine Tech / Drivetrain 2 06-10-2007 01:21 PM
rough idle --> brake= not rough andre4444 Tech Archive (No Posting) 1 05-31-2007 08:32 PM
Rough idle bilzhorse Tech Archive (No Posting) 2 12-10-2006 12:02 AM
rough idle? NoWayBack91Si Tech Archive (No Posting) 3 07-06-2006 11:56 PM
Copyright ģ2007 ClubCivic.com
Freelance Web Design
