Removing tension rods, and adding trunk strut
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 01-01-2007, 03:02 PM   #1
rebyid
rebyid is on a distinguished road
Default Removing tension rods, and adding trunk strut
In the process of a mod for my subs in my trunk, I ended up popping off one of the "tension rods" for my trunk. These are the twisted torqued rods which hold the trunk in the open position.
Does anyone of any idea of how to get this rod back on? I tried for over an hour trying to twist it back but it requires more force than I can deliver.
So far, I have tried clamps, wrenches, and taking a screwdriver and just trying to torque it.
The only other solution I have yet to try and am still trying to figure out how to do, is to take the other rod off, and add a trunk strut (those little cylinders used to hold up the trunk). I have no clue how to do this either, but if I can't get the rod back on, it's what I'll have to do.
rebyid is offline
Old 01-01-2007, 03:05 PM   #2
Evan.
iTrader EVERYthing
Evan.'s Avatar
Evan. is on a distinguished road
Trunk Spring Tool
Genuine Honda Civic spring tool. Assists in removing stock springs and installing new ones that come with trunk spoilers.
All sales of this item are final, no returns for any reason
- Shipping information Availability: Honda's Retail $37.21
our Price $26.80
Seen on this page:
http://www.handa-accessories.com/civic98.html
Originally Posted by Mugenkid18 View Post
sk8shorty017: Ruining the hopes and dreams of civic enthusiasts one genuine part at a time.
Originally Posted by projektej8 View Post
mine is genuine Mugen I got it from Sk8shorty on here. He's Baller. Theyre hella expensive
Originally Posted by 98civb18c View Post
$80 is cheap, considering its been handled by the modern day jesus himself, Sk8shorty. GLWS lawl.
Evan. is offline
Old 01-01-2007, 03:05 PM   #3
cgpEJ6
noob
cgpEJ6 is on a distinguished road
I believe Honda sells a tool specifically for that because you change them if you add a spoiler
1997 Honda Civic LX – project car to be | 2010 Honda Fit Sport – daily driver
cgpEJ6 is offline
Old 01-01-2007, 08:45 PM   #4
rebyid
Thanks for the quick replies guys. I was flipping out for a little bit there.
Ordered the part.
rebyid is offline
Old 01-02-2007, 09:26 AM   #5
02EXSILVER
I have a monkey?
02EXSILVER's Avatar
02EXSILVER is on a distinguished road
There have been posts on other forums about adding gas struts/pistons. I've even got the parts to do it... Just haven't had the time. If I can find the how to, I'll copy and paste...
I've removed the tension rods, and can understand your frustration. Although the tool isn't required to change/remove/replace the rods, it does make it easier. I used two screwdrivers to give me the leverage.
Usuialy at work
I was told I could listen to the radio at reasonable volume.
02EXSILVER is offline
Old 01-07-2007, 01:58 AM   #6
JDM melbatoast
That's what she said..
JDM melbatoast's Avatar
JDM melbatoast is on a distinguished road
i have a rear wing on my car. the middle support popped off and now it just rattles with my sub. i dont think ill be able to fully glue it back on can ijust take off my tension rods? will the trunk still open a little bit when i hit the trunk pop?
It's not what you drive, it's what drives you.
Hi, I'm Chris Hansen and your on To Catch a Predator.
JDM melbatoast is offline
Old 01-07-2007, 02:01 AM   #7
rebyid
Having taken one of the tension rods off, I can speak from experience.
Your trunk will be a b**** to open without those tension rods.
It is better to get some weather stripping foam and stick it anywhere that there is vibrations, at least you will be able to get your trunk open.
rebyid is offline
Old 01-07-2007, 02:03 AM   #8
Evan.
iTrader EVERYthing
Evan.'s Avatar
I believe you need both for the trunk to function correctly, or at all for that matter.
Evan. is offline
Old 01-07-2007, 02:06 AM   #9
JDM melbatoast
damnit the bracket thing int he middle made out of probably the worlds s***tiest steel popped off any ideas on what to use to get it back on?
Old 01-07-2007, 02:07 AM   #10
Evan.
iTrader EVERYthing
Evan.'s Avatar
pop it back in? idk...
*hold* while I research.
Evan. is offline
Old 01-07-2007, 02:09 AM   #11
JDM melbatoast
looks liek the welds cracked that held it ill take pics tomorrow and post cause i bet im not the only one with this problem
Old 01-08-2007, 10:39 PM   #12
rebyid
sk8shorty017 is correct. Your trunk will pop open without those rods. It will work, you just have to actually try to lift it with your hands.
I know the bracket in the center you are referring to. I'll play around and see if I can think of anything. You could always try making a new one out of some wood or something, bolting it on.
rebyid is offline
Old 01-09-2007, 11:19 AM   #13
JDM melbatoast
well let me knwo what you think of this.
you knwo how there is a lip between the body of the car and the weather stripping? can't i just remove my tension rods and put a spring in there that is compressed when the trunk is closed but once the latch is released it pops the trunk open. then when this is done i could have a gas strut monted on the trunk bracket arm to hold the trunk open when i wanna keep it open. think that will work?
Old 01-09-2007, 11:23 AM   #14
rebyid
I am not sure. A gas strut should be able to pop the trunk open on its own.
rebyid is offline
Old 01-09-2007, 11:26 AM   #15
JDM melbatoast
i might just converted to a straut strut or two. i saw them on sale at boat us and ill just get one that is used for marine hatches. i had no idea a strut can pop open a compartment.
help removing interior trunk paneling davebu Interior / Audio / Electronics 2 06-21-2011 09:26 PM
removing HB trunk inner lining........... CSB Show off your 6th Generation Honda Civic (1996-2000) 5 01-19-2007 05:59 PM
adding and removing color to your tail lights jdmpimpn1053 Exterior / Detailing / Bodywork 14 03-22-2006 02:16 PM
removing spring from strut DirtyD Engine Tech / Drivetrain 5 02-09-2004 10:38 PM
