Search:
Welcome to ClubCivic
D16Z6 Rebuild Thread
Responding Members:
User Tag List
Old 01-08-2007, 04:30 AM   #1
importedTuna
Extreme User
importedTuna's Avatar
Default D16Z6 Rebuild Thread + snoob's Bay Tuck
So a little while ago, my friend snoob and I swapped a d15b vtec into his car, and the z6 that was in the way of that had to come out. After pulling the rod and bearing (w/piston) that was causing it to knock, we let it sit, and then busted the head off a month or two later, then the block, etc.
The process avalanched and completely became a full-scale rebuild and we have everything figured out save the crank and the pistons/rods. The crank is somewhat scored from the knocking rod/bearing, and may need to be machined along with acquiring an oversized bearing, and probably y8 pistons/rods or perhaps some tuner toy rods. Pictures of the crank are coming, along with pictures of the DIY port & polish job we did.
Hopefully I can put this in a 5g hatch soon, as long as the world's supply doesn't run dry.
snoob: So I walk out into the garage only to see some guy just doing donuts in my garage, and what's more, the thunderbird has somehow, finally, magically disappeared! The guy stops his car, apologizes for the noise, and tells me he's there to deliver a turbo. And then I woke up.
me: And you were normally aspirated.
importedTuna is offline
Old 01-08-2007, 08:28 AM   #2
Destroy
Destroy's Avatar
Destroy is offline
Old 01-08-2007, 01:20 PM   #3
snoob
9k RPM and 1+ Lateral G
snoob's Avatar
i wish we were closer to done :O we need a tripod.
Quoted from the local idiot: " you should fix your winshield wipers, if they get frozen in an upright position in the winter it could blow your whole engine."
*project boosted d comming soon*
Originally Posted by importedTuna
I mean jesus...we painted it billet
snoob is offline
Old 01-08-2007, 08:29 PM   #4
Boricuanology
Boricuanology's Avatar
good luck man with your engine, Im waiting myself for my engine to come from the machine shop so that I can start the build up.
Boricuanology is offline
Old 01-08-2007, 08:33 PM   #5
FRODO
Teh Oldest NooB.
FRODO's Avatar
Cool you building for boost?
http://www.clubcivic.com/board/showthread.php?t=213508
Turbo build part out.
FRODO is offline
Old 01-09-2007, 03:15 PM   #6
chiliredDX
chiliredDX's Avatar
looks good so far. im dropping a z6 into mine here in a few weeks.
what pistons/rods you looking at?
chiliredDX is offline
Old 01-09-2007, 03:21 PM   #7
Endemic
i need to do that on my eg6 too..
[/B]
WHY AM I SUCK AT ENGLISH? CLICK HERE
Endemic is offline
Old 01-09-2007, 04:59 PM   #8
blacknmild874
b00st s00n!
blacknmild874's Avatar
may i suggest the Vitara Pistons and Tuner Toys rods set up?
the vitaras have been known to hold 425 so far. which is pretty awesome since you can pick them up for under 150 shipped for pistons and rings.
good luck and have fun with the build!
Originally Posted by AutoFanatik View Post
its only slower cuz your mom is sitting in the passenger seat playing snake swallower
blacknmild874 is offline
Old 01-10-2007, 12:09 AM   #9
Boricuanology
what color is that on your cylinder head cover? thats what I'm gonna be using, Vitara piston from FJT and eagle rods from summit racing, which they price match. Just waiting for my damm block to come, I hate waiting.
Old 01-10-2007, 04:38 AM   #10
importedTuna
Extreme User
Ehh if I have the money I'll go with the Tuner Toy / Vitara setup; it's most definitely what i want. I'll probably be limited to getting rods and some y8 pistons for the moment, which is fine. Though boost is the goal, I'll probably run it high-comp NA for a good long while, that is, when it gets dropped in something.
The paint on the valve cover is Cast Iron - it's just the 500 degree-rated engine enamel from advance auto, but it looks real beast. The block and head are painted some 1200 degree aluminum color...I believe it's just called Aluminum haha.
Seeing this thing in the garage makes me think we're a little ricier than I'd like to admit...I mean jesus...we painted it billet
Old 01-10-2007, 01:04 PM   #11
snoob
snoob's Avatar
it IS BILLIT
the paint doesn't look bad ask anyone, and it'll dull atlittle when warmed to a vtec temperature :O
we need to get rear shock bushings so we can finish that kids lowering springs today.
snoob is offline
Old 01-10-2007, 01:50 PM   #12
ryan89crx
Spoolin single cam!
ryan89crx's Avatar
look at the color of the oil that was in there! no wonder that bearing spun...
good job on the rebuild
www.d-series.org
www.tunewithcrome.com
Dont be so closed minded. The beaten path isnt always the best one.
Originally Posted by si-hatch86
i speak jibberish 90% of the time
ryan89crx is offline
Old 01-10-2007, 03:26 PM   #13
Chris.
Stickin' it to the man
Chris.'s Avatar
dood you left me out of that engine swap..!! its ok tho im not important...lol
all in all it looks almost brand new
Originally Posted by Beelzebubba
I want A/C. I have the 95 degree rule. anything over 95 and it's windows up, A/C on. Also need A/C when it's 90 degrees and raining or you can't clear your windows.
Originally Posted by EJ6Civic27
No way its stock...its gotta be boosted...
Originally Posted by dank24
Ridin' with no tint so the motherf***ers know it's me
bng b0ng : I don't understand teh online talk, "fit = couch".
bng b0ng : care to elaborate?
DANK : no
bng b0ng : lol alright, thanks
Chris. is offline
Old 01-10-2007, 05:02 PM   #14
snoob
snoob's Avatar
tell me about it i bought it 190k and drove that motor to 210k. its safe to say that the thing has been pushed hard its whole life
we took the crank into the machine shop today, when we walked in the smell of domestic vehicles just filled the air, as we cradled our baby d series crank to a man named chad, who said he'd take a look at it and call us back on a price later in the day.
snoob is offline
Old 01-10-2007, 05:05 PM   #15
snoob
snoob's Avatar
aww you were in our hearts most of the time... well actually we imagined you standing there shaking your head at the sloppy job we're doing
oh yeah and we used my brother and a wrench to push down the valve springs... lol at least it worked, gotta mod a valve spring compressor eventually.
right now we're attempting a wire tuck on the passenger side of my engine bay, however we don't know how long it will be until we give up, and i doubt its going to look amazing. there will also be some painting, because the previous owner thought he'd up the value of the car by touching up the look of the engine bay with a fresh coat of black spray paint.
snoob is offline
d16z6 complete rebuild kit mugenkid91 Parts for Sale 22 11-04-2011 07:07 PM
D16Z6 Engine (in parts, needs rebuild) 2nedhnda Parts for Sale 20 07-29-2009 01:13 AM
LOOKING FOR A D16Z6, D15B to rebuild jdmdelsol Engine Tech / Drivetrain 1 09-03-2007 10:38 PM
Help on d16z6 rebuild. all_conference Engine Tech / Drivetrain 2 11-16-2005 10:16 PM
d16z6 rebuild kits and other questions hawkscivic Wheels / Tires / Brakes / Suspension 0 12-05-2002 03:06 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
