Search:
Welcome to ClubCivic
Sudden loss of gas mileage...What could be the cause?
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
User Tag List
Old 01-13-2007, 07:01 PM   #1
daveskitz
Default Sudden loss of gas mileage...What could be the cause?
My '96 civic EX has been getting around 350 miles per tank full for as long as I can remember. All of a sudden in the last month or two I barely get 250. Driving habits have not changed and I was wondering what could be the cause of this sudden loss in gas mileage? I do not smell fuel and had garage check for fuel leaks but they found none.
I did a major tune up including fuel filter but minus the pcv valve, which I will replace with next oil change; checked and fixed tire pressure, which was a little low 25 vs 30 fronts and 25 vs 29 on rears; the 02 sensor was replaced this past summer.
The car is leaking oil but I'm not sure from where exactly but after steam cleaning the engine last week, I see oil under the valve cover and distributor.
I did notice that when idling the car sometimes idles with a bit of a rough vibration. It kind of feels like when A/C would kick on but I'm not running A/C this time of year.
daveskitz is offline
Old 01-13-2007, 07:04 PM   #2
AliasNeo
AliasNeo's Avatar
could be the cold weather... its happened to me too lol
"Ask anyone who has ever drag raced Mom's Accord and you'll learn our next trick. A stripped interior not only saves 273 lbs, it also lets everyone know you're serious."
AliasNeo is offline
Old 01-13-2007, 07:14 PM   #3
JohnS.
BANGARANG
JohnS.'s Avatar
First off, .
Now getting on topic, are you SURE you didn't leave anything out when you did a tune-up? Also, is your car throwing any CEL's? (You didn't mention you were hence why I'm asking).
As for the idle, sounds like maybe a dirty IACV or something.
The only reason why I personally lose MPG is because I put the gas all the way down too much.
Questions / comments / concerns? Feel free to PM me.
New to ClubCivic? Click Me!!!
JohnS. is offline
Old 01-13-2007, 07:23 PM   #4
daveskitz
Never happened before in cold weather...
and it's actually been pretty mild for this time of year so far.
Old 01-13-2007, 07:31 PM   #5
daveskitz
[QUOTE=amej8]First off, .
Thanks for the welcome!
I replaced air filter, fuel filter, distributor cap & rotor, spark plugs and wires. Will change out pcv valve with next oil change.
I'm not very mechanically inclined so pardon my ignorance but I don't really know you are talking about here.
Old 01-13-2007, 07:33 PM   #6
JohnS.
BANGARANG
JohnS.'s Avatar
CEL = Check Engine Light. An orange light on your cluster that will light up if there is a problem. I'm assuming it's not on since you haven't mentioned it.
As for the tune-up, what about fuel filter, O2 sensor (I know you said you changed it but you sure it's still good?), and fuel injector cleaner?
JohnS. is offline
Old 01-13-2007, 07:50 PM   #7
daveskitz
Boy don't I feel stupid no CEL is not on.
I did the fuel filter but no fuel injector cleaner...any recommendations on which cleaner to use? As far as the 02 sensor...CEL came on this past summer and it was determined by dealer that the 02 sensor needed to be replaced, so that's when it was done. How do I know if it's still good or not? Wouldn't CEL come back on if it were no good anymore?
Old 01-13-2007, 08:33 PM   #8
JohnS.
BANGARANG
JohnS.'s Avatar
Oh yeah forgot you said you already changed it :.
As for fuel injector cleaner, it really doesn't matter. Actually, you know what you should try? Seafoam. That helps A LOT. Especially with older cars that are dirty in the internals.
JohnS. is offline
Old 01-13-2007, 10:00 PM   #9
iOn
I like pie.
o2 sensor?
iOn is offline
Old 01-14-2007, 12:48 AM   #10
Redbone
Movin on up...
Redbone's Avatar
did you do the timing belt, water pump, tensioner change out too? That's an important step along the way. Also, did you get a valve adjustment?
Life's tough, but it's tougher if you're stupid. - John Wayne
Redbone is offline
Old 01-14-2007, 12:54 AM   #11
Szady
D-Series Master
Szady's Avatar
..whens the last time you changed your oil? You didnt mention that you changed the oil w/your last tune-up. Old oil WILL give you bad gas mileage.
Szady is offline
Old 01-14-2007, 01:08 PM   #12
daveskitz
Thanks I'll give that a try.
Old 01-14-2007, 01:11 PM   #13
daveskitz
Timing belt and water pump done about 23, 000 miles ago; not sure about tensioner. No valve adjustment done.
Old 01-14-2007, 01:11 PM   #14
daveskitz
Oil changed about 2 weeks ago.
Old 01-14-2007, 01:28 PM   #15
iOn
I like pie.
no one thinks o2 sensor could be a possibility? might be causing you to run rich... it is a possibility if the usually tune ups do not improve fuel economy. vacuum leaks and ignition problems are common problems also.
iOn is offline
Loss in gas mileage. autocrosser09 Tech Archive (No Posting) 46 01-16-2010 02:13 AM
Poor gas mileage ( Too much gas consumption) SAUL CIVIC 93 Tech Archive (No Posting) 0 11-14-2009 05:51 PM
My gas mileage CivicRoller2009 Engine Tech / Drivetrain 8 03-27-2009 09:48 PM
Gas Mileage 20civic04 Tech Archive (No Posting) 19 07-21-2008 01:15 AM
Gas Mileage ? curveit Engine Tech / Drivetrain 3 12-11-2002 08:11 AM
Copyright ®2007 ClubCivic.com
Freelance Web Design
