Search:
Welcome to ClubCivic
Cold start Idle problem
Responding Members:
User Tag List
Old 02-12-2007, 01:00 AM   #1
slowhatch
torque?
slowhatch's Avatar
Default Cold start Idle problem
i've had a bouncy idle for about a month now, thats been getting progressively worse. its only during cold start and i've already replaced the iacv and cleaned out the pcv valve. what else am i missing? i started out by cleaning the original iacv with some carb cleaner and ive been told not to but to use electrical cleaner.. the iacv i replaced it with is from a y8 (my engine is a z6), are the not interchangeable? im also considering replacing my pcv valve with the y8 pcv (since i have the whole y8 im), are they different? its frustrating that ive done 2 things that should've fixed it, replacing the iacv and cleaning the pcv valve (i've also checked for vacuum leaks). help me please!
engine: d16z6 obd1 (obviously) no cel
mods: t3 turbo kit/dsm 450's/missing link
Sig size limit 35kb please resize. -oilpool
Originally Posted by bizoneoeh View Post
don't type so hard or your trailer might tip over
"...Sometimes the starter whirrs enthusiastically but having been unrewarded by either a spark or a supply of petrol it looses interest and fades into an asthmatic wheeze. Other times it just clicks signifying that, for some reason the battery has forgotten what it is, and is hanging around in the engine bay imagining that it might be a hammer or a fighter plane. " -Clarkson
slowhatch is offline   Reply With Quote
Old 02-12-2007, 06:31 PM   #2
slowhatch
torque?
slowhatch's Avatar
bump for some help
Old 02-12-2007, 06:45 PM   #3
JAPDOMMOT
I'M WATCHING YOU...
JAPDOMMOT's Avatar
Mine Was Doing The Samething I Unplugged The Map It Idled A Little High When Cold Then Idled Normal Check Your Coolant And Battery
JAPDOMMOT is offline   Reply With Quote
Old 02-12-2007, 07:01 PM   #4
jason_guy_yeah
jason_guy_yeah's Avatar
What did you use to check for a vacum leak? And go get a new iacv from autozone or from honda. Unplug your MAP sensor for a moment and post up your results.
jason_guy_yeah is offline   Reply With Quote
Old 02-12-2007, 07:11 PM   #5
JAPDOMMOT
I'M WATCHING YOU...
JAPDOMMOT's Avatar
My Iacv Was $117 From Acura With Discount
Old 02-12-2007, 07:45 PM   #6
lilwhitecoupe
Ricer
lilwhitecoupe's Avatar
i would go to honda personally, i trust the oem parts more for things like that... autozone could work though
lilwhitecoupe is offline   Reply With Quote
Old 02-12-2007, 08:14 PM   #7
guwakjai010
Dr Tai tai
guwakjai010's Avatar
i had the SAME problem a year ago... everyone says IACV and crap but the IACV only controls when ur car is warmed up and idling... but when your car is warming up, you actually have the FITV controlling the idle. theres a lil plastic screw thing in it that gets loose over time and u need to open the FITV and just tighten the screw, They say its not recommended to open it instead u should replace it but couple people i know opened it including me and fixed the problem.
guwakjai010 is offline   Reply With Quote
Old 02-12-2007, 08:19 PM   #8
guwakjai010
Dr Tai tai
also if u don't kno where the FITV is.... heres a link with pictures and labels... like i said... its MOSTLIKELY your FITV http://www.clubcivic.com/board/showt...highlight=fitv
The Following User Says Thank You to guwakjai010 For This Useful Post:
esebanester (03-02-2014)
Old 02-13-2007, 12:50 AM   #9
slowhatch
torque?
slowhatch's Avatar
wow you are a life saver. thank you very much!
Old 02-13-2007, 12:51 AM   #10
guwakjai010
Dr Tai tai
heh NP just let me kno if it worked for you.
Cold start idle question on 95 civic ex Vx2ko 5th Generation Honda Civic (1992-1995) 6 12-09-2011 06:44 PM
low idle cold start high idle when warm 00civick_si Engine Tech / Drivetrain 3 05-20-2011 02:02 AM
low idle cold start high idle when warm 00civick_si Engine Tech / Drivetrain 1 05-19-2011 07:25 PM
High idle at cold start, no CEL kuttlazz92 Tech Archive (No Posting) 3 05-05-2010 06:49 PM
Wierd Cold Start Idle? Help! Mr.Luder Engine Tech / Drivetrain 8 12-10-2005 05:08 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
