Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Exterior / Detailing / Bodywork
Exterior / Detailing / Bodywork Includes exterior lighting and body styling
pinstripe
Responding Members:
User Tag List
Old 02-26-2007, 01:06 PM   #1
Dyl415X
never enough
Dyl415X's Avatar
Default pinstripe
I know removal has been covered before, but this summer i'd really like to remove my the ugly pinstripe on my car. I want to get some opinions as to whether or not its worth doing since the car is going on 7 years old now because I have a feeling even if I take it off, the ghost of it will still be there. Could it still be removed completely without having to take it to the body shop?
Dyl415X is offline   Reply With Quote
Old 02-26-2007, 01:09 PM   #2
Silver Bullet
6 spd = titis
Silver Bullet's Avatar
yes it can be removed....many things you can use to remove it (gluegone) just search and for the pinstripe some civics look good with and with out depending on if u have anything to match with it...
Thanks Petey For the Sig...!!!
Silver Bullet is offline   Reply With Quote
Old 02-26-2007, 02:14 PM   #3
PEARLelectron
Keep it pinstripes are balla
PEARLelectron is offline   Reply With Quote
Old 02-26-2007, 06:57 PM   #4
Szady
D-Series Master
Szady's Avatar
I took the pinstripes off my 2000 Civic 4dr, and theres tan lines that arent very noticeable, unless you're looking for them. What I did, was get either a heat gun, or a blow dryer, and warm up the pinstriping. Then peel/scrape it off with your fingernail (its actually not that hard/painful, b/c its warm, it'll come right off). Then get some Goof-Off (or something similar, like Goo-Gone. I used Goo-Gone. Smells like oranges ), and put some on a rag, then rub the adhesive off.
Szady is offline   Reply With Quote
Old 02-26-2007, 07:41 PM   #5
Dyl415X
never enough
Dyl415X's Avatar
did you use rubbing compound at all?
Old 02-26-2007, 07:48 PM   #6
Szady
D-Series Master
Szady's Avatar
after I took the pinstriping off (like a week later) I washed, claybar'd, polished, and waxed the whole car....so Why do you ask?
Old 02-26-2007, 07:52 PM   #7
Dyl415X
never enough
Dyl415X's Avatar
because from what ive read a lot of people use it to help get the ghost line off completely..j/w if you did or if it helped
Old 02-26-2007, 08:35 PM   #8
Szady
D-Series Master
Szady's Avatar
Oh...I have no idea if it helped. Usually, with tan lines, its un-fixable without repainting. But. mine arent as bad, and the pinstriping had been on for 7 years....
Old 02-26-2007, 11:46 PM   #9
#1FG
Rev Limiter= Fun Limiter
#1FG's Avatar
I removed mine last summer. I just waited for a hot day and i could peel them off with my fingers. As far as removing the ghost lines, i just ended up doing a total detail on my car but the stripes werent bad in the first place since my car is new.
http://www.swollenmembers.com/swollen_tour_splash/ <-- check them out
#1FG is offline   Reply With Quote
Old 02-27-2007, 04:16 PM   #10
Jordan_n
No fun unless ur Dragging
Jordan_n's Avatar
i'd rock the stripes u should keep'em
Jordan_n is offline   Reply With Quote
Old 02-27-2007, 07:20 PM   #11
PEARLelectron
this guy knows
Old 02-27-2007, 09:19 PM   #12
Trey99EK
I removed mine on a hot day with my fingers. As for the line a good solid paste wax got it off.
Trey99EK is offline   Reply With Quote
Old 02-27-2007, 10:23 PM   #13
NOFX
I'm NOT eran!
NOFX's Avatar
Some cars might end up with lines left over, and some won't. Sometimes you can remove them easily, sometimes you can't.
And polishes and clay bars are for removing stuff from the car, not wax. Wax is a protactant.
NOT ACTIVE ON SITE. STOP ASKING ME WHERE I BUY MY PARTS.
[OEM 98 Discontinued Rear Lip #0009]
[OEM 98 Discontinued Front Lip #0001]
NOFX is offline   Reply With Quote
Old 02-27-2007, 10:30 PM   #14
Trey99EK
I know what clay bars are waxes are for. That is what I found in the trunk of my car and it worked like a charm. Now if you have lots of crap built up around the stripes you will def need a clay bar.
Old 02-27-2007, 10:58 PM   #15
NOFX
I'm NOT eran!
NOFX's Avatar
I'm just trying to keep anyone else from using wax to clean their car.
Black wheels with blue pinstripe? Vashkon Wheels / Tires / Brakes / Suspension 6 04-08-2009 02:13 PM
Si pinstripe? UH AzN Tech Archive (No Posting) 19 11-18-2008 12:17 AM
Dropped and pinstripe removal dj_cronic_metal Show off your 7th Generation Honda Civic (2001-2005) 51 08-15-2008 08:26 PM
whats the best way to remove pinstripe neXed Exterior / Detailing / Bodywork 17 04-29-2005 01:39 PM
Removing pinstripe silentdaredevil Exterior / Detailing / Bodywork 3 04-13-2004 03:43 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
