Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic DIY / How To > DIY How To's > Engine Tech / Drivetrain DIY How-To's
OFFICIAL DIY: Skunk2 Intake Manifold Install - GSR
User Tag List
Old 02-26-2007, 02:00 PM   #1
Jay Jay
ADMIN
Default OFFICIAL DIY: Skunk2 Intake Manifold Install - GSR
DIY: Skunk2 Intake Manifold Install – 94-01 Integra GSR
Applicable Years: 92-00 Honda Civic, 90-01 Acura Integra
Difficulty: 2 out of 5
Estimated Time: 3hrs
Product Features:
• Single staged intake manifold design
• 64mm plenum opening
• Factory throttle body may be reused
• Utilizes factory sensors
• Larger plenum and runners to optimize horsepower
• Smoother finish to optimize air flow
• Modified #4 intake entry
• Significant mid to high-range power gains
Purchase a Skunk2 Intake Manifold
http://www.tunersports.com/products/...ifold_114.html
Product Photos:
The Install Process:
Disconnect your negative battery terminal and drain coolant.
Relieve fuel pressure by loosening the banjo bolt on the top of the fuel filter and remove the fuel line at the rail. Then disconnect the lines from the fuel pressure regulator and remove the fuel injector clips.
Remove your intake from the throttle body. Then disconnect all hoses and sensors leading to the intake manifold and throttle body including your throttle cable bracket.
Unbolt the manifold from the cylinder head. Remove the intake manifold, throttle body, and fuel rail as one unit. Inspect intake manifold gasket. Replace as needed. Make sure to note all disconnected hoses and sensors.
Unbolt the throttle body from the intake manifold; inspect the throttle body gasket for damage and replace as needed. Unscrew the throttle body studs from the flange and reinstall in the new manifold (make sure that when lining up the throttle body gasket, the U-shaped portion faces top-left-corner of flange).
Remove fuel rail assembly and install in the new manifold, including the fuel rail studs. Inspect o-rings and replace as needed.
From the factory intake manifold, unbolt and remove the idle air control valve and intake air temperature valve to install into the new manifold.
Bolt on manifold-throttle body-fuel rail assembly back onto cylinder head, making sure that the manifold gasket is positioned properly and securely. Connect the evaporative emissions purge control solenoid valve. Due the new intake manifold design, there is no mounting location for the EVAP purge control solenoid valve. It is recommended the unit be zip-tied to a secure location. For 94-95 vehicles, one hose end will plug into the charcoal canister and the other hose end will plug into the small vacuum fitting located on the rear of the new intake manifold. For 96-01 vehicles, please refer to the note below.
The FPR host will be re-plugged into the small vacuum fitting located on the front of the new intake manifold.
Bolt on and connect the fuel injector harness holder and hoses. Connect TPS, map sensor, and fuel line. Tighten the banjo bolt on the top of the fuel filter.
Connect batter and replace coolant.
Any unused fittings can be plugged by using vacuum caps
I ended up eventually getting a Type R throttle body bracket, throttle cable, and LS throttle pulley to make the install a bit cleaner looking.
Note:
1996-2001 vehicles are OBD II and equipped with a different-type EVAP purge control solenoid compared to that of pre-1996 vehicles.
1996-2001 EVAP: The EVAP purge control solenoid valve will not have a mounting point due to the new design of the manifold. It is recommended thtat the unit be zip-tied to a secure location. In order to connect the EVAP purge control solenoid valve, a T-fitting must be used to re-fit the PCV hose and EVAP hose onto the larger vacuum fitting located on the manifold plenum body.
1996-2001 PCV: The upper and lower Type-R PCV (positive crankcase ventilation) hoses will be used to reconnect the breather chamber to the PCV valve, to the T-fitting opposite of the EVAP hose.
1996-2001 Linkage: As an option, the Type-R throttle body cable and mounting bracket can be used.
Anatomy of an Intake Manifold – Skunk2 vs. Clone
Click here to view the PDF file.
Skunk2 vs. Stock Intake Manifold Photos:
Click image for larger version
ID:	21622   Click image for larger version
ID:	21623   Click image for larger version
ID:	21624   Click image for larger version
ID:	21625   Click image for larger version
ID:	21627   Click image for larger version
ID:	21628   Click image for larger version
ID:	21629   Click image for larger version
ID:	21630   Click image for larger version
ID:	21632   Click image for larger version
ID:	21633   Click image for larger version
ID:	21634   Click image for larger version
ID:	21635   Click image for larger version
ID:	21637   Click image for larger version
ID:	21638   Click image for larger version
ID:	21639   Click image for larger version
ID:	21640   Click image for larger version
ID:	21642   Click image for larger version
ID:	21643   Click image for larger version
ID:	21644   Click image for larger version
ID:	21645   Click image for larger version
ID:	21647   Click image for larger version
ID:	21648   Click image for larger version
ID:	21649   Click image for larger version
ID:	21650   Click image for larger version
ID:	21652   Click image for larger version
ID:	21653   Click image for larger version
ID:	21654   Click image for larger version
ID:	21655   Click image for larger version
ID:	21657   Click image for larger version
ID:	21658   Click image for larger version
ID:	21659   Click image for larger version
ID:	21660   Click image for larger version
Justin
[B]www.tunersports.com | www.clubcivic.com | www.clubintegra.com
Support ClubCivic.com
Buy Merchandise
Buy Parts from our Online Store - Save 3% if you have a Premium Membership
Get a Premium Membership - Only $10 / 6 months
Use Coupon Code: FallSavings to save on most items.
$$ Price Match: Find a lower price? PM or contact us and we'll try our best to match it.
Jay Jay is offline   Reply With Quote
Old 02-27-2007, 12:22 AM   #2
steve98ex
say no to rotas
steve98ex's Avatar
very nice write up justin. i just bought a gsr and it has the older skunk2 mani on it and it came with the stock one also. how does the new one perform? i was thinking about putting the stock back on for the BAR process but I might just keep it on there and see how it goes.
Originally Posted by Suanico
butt sex and titties, you make me want to spend thousands of dollars into my car tomorrow
steve98ex is offline   Reply With Quote
Old 02-27-2007, 12:25 AM   #3
--<EM1>--
boosted ftw
--<EM1>--'s Avatar
awesome write up!!!!!!
--<EM1>-- is offline   Reply With Quote
Old 02-27-2007, 10:49 AM   #4
Jay Jay
ADMIN
I would personally keep the skunk2 instead of going back to the dual stage stock one. I could definately feel it pull harder in the high rpms on the butt dyno.
Justin
Buy Merchandise
Old 02-27-2007, 10:57 AM   #5
stolibears
Use your dipstick Jimmy!!
stolibears's Avatar
OMG! I wish I had that third arm to take photos while I work
Great writeup
Looks like a fun bolt on. How long did take?
stolibears is offline   Reply With Quote
Old 02-27-2007, 11:07 AM   #6
Jay Jay
ADMIN
It took a few hours. The part that took the longest was remove the old intake manifold gasket.
Justin
Buy Merchandise
Old 02-27-2007, 12:06 PM   #7
NoBoost
138,000 Mi. EM1
NoBoost's Avatar
Jay Jay:
This is a great write up, im sure many people agree with me.
Could you possibly tell us the gains you noticed, how much, and specifically during what RPM range ( as this is till a HUGE debate for many people)
Also, to relieve fuel pressure, unscrew the gas cap prior to disconnecting the FPR and the fuel line, this will cause not as much fuel spraying everywhere.
Thanks
NoBoost is offline   Reply With Quote
Old 02-27-2007, 12:14 PM   #8
Kingjames83
Kingjames83's Avatar
nice write up.... thanks for taking the time to do that.
Kingjames83 is offline   Reply With Quote
Old 02-27-2007, 12:50 PM   #9
Genuine Rolla
Its PETEY PETE, y0!
Genuine Rolla's Avatar
very nice write up man...! Couldnt be any better.
x
[ProjectJayDeM, y0!] [<><] [CCSC#9] [College.$tatus] [ClubCivicCouch Crew#4]
Originally Posted by connies92hatchie View Post
Cmon do you see how small Max's head is? Pushing Dank's body through these p***y walls is gonna be a piece of cake!
Genuine Rolla is offline   Reply With Quote
Old 02-28-2007, 06:08 PM   #10
stealthy
4 Doors For More Whores
nice job....i hate installing/removing IM's with the motor in the car, the nuts are so hard to get to
--BJ--
- GSR Sedan
- CP 81.5 9:1 Pistons
- Eagle H Beam Rods
- Garrett T3/60-1 .63a/r
stealthy is offline   Reply With Quote
Old 02-28-2007, 06:26 PM   #11
Steven.
Formally Green 91
Steven.'s Avatar
Originally Posted by NoBoost
Jay Jay:
Thanks
Steven. is offline   Reply With Quote
Old 03-04-2007, 01:22 AM   #12
steve98ex
say no to rotas
steve98ex's Avatar
hey jayjay, i was wondering what kind of intake you went with. i've been looking at the aem hybrid intakes, there's one for the b18c1 with stock gsr manifold and a different one for jdm single stage manifold. so basically is the throttle body in close to the same spot for both manifolds?
Old 03-04-2007, 05:58 PM   #13
Jay Jay
ADMIN
I have intercooler piping You would need the intake manifold for the c5 since the skunk2 is pretty much the same design. You can see in my comparison photos that the gsr throttle body sits a good distance lower than the skunk2.
Justin
Buy Merchandise
Old 03-04-2007, 06:09 PM   #14
steve98ex
say no to rotas
steve98ex's Avatar
intercooler piping eh? you need to catch us up on your car :) thanks for the help, can you still get good prices on parts even though tunersports is no more?
Old 03-07-2007, 01:33 PM   #15
Jay Jay
ADMIN
i'll be coming back with something in a bit
Justin
Buy Merchandise
Tags
official diy
WTB old school style Skunk2 intake manifold for GSR yesSIR-S Parts Wanted 0 01-02-2010 01:22 PM
FS: Skunk2 intake manifold for GSR hardcore97 Parts for Sale 8 08-28-2009 06:31 PM
gsr skunk2 intake manifold tharealjdm Parts for Sale 17 08-03-2008 02:03 PM
How To: Properly Mount a Skunk2 Intake Manifold on a GSR Cylinder Head. vandynamics Engine Tech / Drivetrain 4 08-23-2006 06:06 PM
FS Skunk2 Pro Series GSR Intake Manifold pre94 Parts for Sale 8 02-02-2006 10:31 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
