Replacing B16A block with a B20 keeping the head of the B16A
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 03-11-2007, 01:50 PM   #1
mok
mok is on a distinguished road
Default Replacing B16A block with a B20 keeping the head of the B16A
I have a B16A2 engine came stock on my EG6 1992, I want to replace my block with a B20Z (CRV), what parts should I change? I want to keep my B16 head obviously
Can I keep everything the same, engine mounts, transmission, clutch ,axles
mok is offline   Reply With Quote
Old 03-11-2007, 02:11 PM   #2
ryanM
ryanM is on a distinguished road
yes you keep everything the same, just swap the bottom end
ryanM is offline   Reply With Quote
Old 03-12-2007, 02:20 PM   #3
Ls-HatchBoy
Honda Whore
Ls-HatchBoy's Avatar
Ls-HatchBoy is on a distinguished road
everything is the same, cept you need to get a special head gasket kit, and tap the head
Ls-HatchBoy is offline   Reply With Quote
Old 03-12-2007, 02:25 PM   #4
defvayne
Set This World On Blaze!!
defvayne's Avatar
defvayne is on a distinguished road
yup there is a kit you can purchase from Honda-T**ch.com search it up.
Discontinued 96-98 Rear Lip #0001 ][ VSM Crew #5 ][ LSMC #2 ]
defvayne is offline   Reply With Quote
Old 03-12-2007, 04:08 PM   #5
Billy.
Billy.'s Avatar
Billy. is on a distinguished road
uhh, i dont know bout everyone elses, but my b20vtec needed fuel management. pressure regulator and vafc2 to get the AFR in the green zone
*EDIT*
i recommend if you going to do a b20 bottom, build it for higher compression unless your plan to boost. the vtec head likes more air pressure, else it will stop making power in the low 7k rpms and you wont expect to see more than 165whp stock.
Billy. is offline   Reply With Quote
Old 03-12-2007, 04:13 PM   #6
ryanM
*EDIT*
why did swapping blocks change your air/fuel?
Old 03-12-2007, 04:43 PM   #7
Billy.
Billy.'s Avatar
you tell me. but it did, it ran lean past 6k rpm
Old 03-12-2007, 05:02 PM   #8
ryanM
that sounds like an unrelated problem to me, swapping bottom ends shouldnt change your a/f at all, thats controlled by the injectors, throttle body/intake and ECU.
Old 03-12-2007, 05:28 PM   #9
defvayne
defvayne's Avatar
i guess you have to get the ecu tuned.
Old 03-13-2007, 09:08 AM   #10
Billy.
Billy.'s Avatar
...that or use piggyback hack vafc
Old 03-13-2007, 09:48 PM   #11
DAF
Zinc Member
DAF is on a distinguished road
You can use the LS/Vtec conversion kit for it. All a b20 is, is a 84mm LS block basicly.
DAF is offline   Reply With Quote
FS: b16a motor head/block spooneg6 Parts for Sale 1 11-13-2008 09:19 AM
b18c5 head vs ported b16a head on a b18c1 block for n/a help! FLCL7777 Engine Tech / Drivetrain 8 05-18-2008 02:55 PM
EG4 with B16A Head + B20B bottom block EG4 Show off your 5th Generation Honda Civic (1992-1995) 29 04-21-2007 11:35 AM
B18B Block + B16A Head JohnS. Engine Tech / Drivetrain 12 04-02-2007 12:07 PM
b18b head with a b16a block? 98xSLVRxEK Engine Tech / Drivetrain 2 04-25-2004 01:38 PM
