Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic DIY / How To > DIY How To's > Interior / Audio / Electronics DIY How-To's
How To: "Big 3" Ground Upgrade
User Tag List
Old 03-15-2007, 01:34 PM   #1
1999stockaccord
Honduh's... LULZ
1999stockaccord's Avatar
Default How To: "Big 3" Ground Upgrade
I take no credit for this, I found it on www.the12volt.com Install Bay Forums
Originally Posted by DYohn
Since this question comes up again and again here, I thought this might be a useful post. Performing a "Big 3" upgrade on your vehicle is one way to improve the electrical system performance and its ability to supply power to your audio system. This upgrade will help any vehicle using an after-market amplified stereo system, and most certainly should be performed on any vehicle after a high-output alternator is installed.
Please be sure you read and understand this entire instruction before you begin.
Definition: the "Big Three" upgrade means improving the current capacity of three cables: 1) alternator positive to battery positive, 2) battery negative to chassis, and 3) engine ground to chassis. Some people replace the factory wiring; others add additional cables to the factory wiring. This instruction is to add cables to existing OEM wiring.
Parts and Tools:
As a minimum, you will need to purchase the following:
• Sufficient length of high-strand count high capacity power cable.
- The length required differs for every vehicle. You can measure the length of the existing cables and buy the same length, or contact your dealer or a mechanic and ask, or sometimes you can look it up in a manufacturer's wiring book, or guess. If you guess, make sure you over-estimate and buy too much.
- High strand count cable is more flexible and more reliable than low-strand count cable. Never use solid-core wire in a moving vehicle as it will eventually break.
- The gauge of wire you need depends on the total current draw of your audio system, and/or the current generating capacity of your alternator. Never use smaller cable that you used to power your amps; never use smaller cable than what already exists in your vehicle; never use smaller cable than the generating capacity of your alternator; never use smaller than 4 AWG (it's just not worth the time to use anything smaller); if in doubt, always use higher gauge cable than you think you need. If you look at the Power and Ground charts and your amplifier current draw corresponds to 2 AWG cable, use no smaller than 2 AWG cable, and use 1/0 if you can.
• 6 ring terminals or lugs of the appropriate size for the cable chosen. Two of these need to be large enough to fit over your battery posts, or appropriately sized to bolt onto your existing battery terminals.
• 1/2" or 5/8" shrink tubing (or some other form of permanent electrical insulation. Tape is NOT recommended.)
• Cable ties (plastic zip ties.)
• Wire cutters large enough to handle the cable you choose.
• Crimpers large enough to handle the connectors you choose.
• Soldering iron or gun.
• Solder.
• Scotch brite and/or a small wire brush.
• Heat gun.
• Safety razor blade (or other tool for stripping cable).
• Heat gun (if using shrink tubing).
• Wrenches for removing bolts in your vehicle.
Procedure:
1. Make sure your engine is completely cool before beginning. Identify the three cables being replaced. Make sure you can reach both ends of all cables. NOTE: the engine block to chassis cable may be between the engine and the transmission, or connected to the transmission and the fire wall, and is often an un-insulated flat braid cable.
2. Determine the lengths of cable needed to reach between the three locations being upgraded. Be sure you measure with a flexible tape (a tape measure used for sewing works great) and record the total length along the path you intend to install the cable. You do not want your cables to be pulled tight between any two locations as things move and vibrate as you drive. Be sure to include at least 1 inch extra for slack. NOTE: there is no reason to copy the existing wiring layout in your vehicle unless you want to. Also, be sure that the path you choose does not follow or lay across anything that gets hot, like exhaust parts, or anything that must move, like throttle linkage.
3. Cut your new cable to the three proper lengths. NOTE: some people like to use red cable for positive and black cable for negative. Doing this is completely up to you and is nice, but not necessary. You can use cable with any color insulation you like.
4. Strip each end of all cables to the proper length for the terminal lugs being used. NOTE: after full insertion into the lug, a small "band" of bare wire is usually seen between the back of the lug and the beginning of the cable insulation.
5. Begin at any one end and insert the stripped cable into the lug. Make sure it is fully inserted. Crimp the connector to hold the wire in place. NOTE: crimping large cable can be difficult. The intention here is not to make the crimp the sole means of holding the wire, but only to make sure the lug does not slip around during the soldering phase. I do NOT recommend using hammers or pliers or vices to crimp the connector as over-crimping can break the strands of the cable, reducing the current carrying capacity. Do not over-crimp.
6. You may need to use a vise or some other set of "helping hands" to hold the cable while you solder it. Heat your soldering iron and place it on the connector (on the lug side) barrel. Hold a piece of solder against the tip of the iron and melt the solder into the strands of the cable. Use sufficient solder to fill the connector and completely cover all strands of the cable. NOTE: the lug will get hot and will burn you if you try to hold it. Also, if the insulation on the cable starts to melt, you are over-heating the cable and not paying attention to melting the solder into the cable. You do not need to try and melt the cable!
7. Repeat the above steps on each end of all three cables.
8. After the cables have completely cooled, cut a piece of shrink tubing long enough to cover the soldered barrel end of the lugs and reach about 1/2" onto the insulation of each cable end. Slide this over each lug and use a heat gun to recover the tubing in place.
9. Disconnect your battery, starting with the negative cable first then the positive cable. Discharge any caps you may have in the system.
10. Begin adding your new cables along side the existing ones. I usually begin with the alternator positive cable. Locate the output stud on your alternator and remove the nut. Slip the new cable onto the lug and replace the nut. There is no need to disturb the existing cabling. Route the new cable to the battery and position it to connect to the positive battery post (or connect it to the positive terminal on the OEM wiring) but do not connect the battery yet.
11. Secure the new cable in place by using cable ties every 6 to 8 inches. Secure the cable to cool non-moving parts!
12. Locate where the negative battery cable attaches to the vehicle chassis. Remove this bolt and the OEM battery cable, and clean the mounting area of the chassis using scotch brite and/or a wire brush. Make sure there is no dirt, rust, paint, undercoating, etc in this location. You want bright shiny metal. Connect both your new ground and the OEM ground back to the chassis. NOTE: Some people like to create a new ground location by drilling into the chassis and using a bolt with star lock washers for the new ground cable. Route this new cable back to the battery and position it to be attached, or connect it to the negative terminal. Do not reconnect the battery yet.
13. Secure the negative cable using cable ties every 6-8 inches. Again, don't tie it to anything that moves or that gets hot!
14. Disconnect the engine ground strap at both ends. Using the wire brush or scotch brite, clean both the engine block and the chassis as you did for the first ground strap.
15. Line up the lugs on both the OEM ground strap and your new ground cable, and use cable ties to secure them to each other. This is much easier to accomplish in your lap or on the floor than it is while lying under your car or hanging upside down in the engine compartment. Reinstall both cables at the same time using the factory bolts.
16. Double check to make sure all bolts are tight. Be careful not to over-tighten them as you don't want to strip anything! Also, on some factory alternators it is WAY too easy to twist off the positive output lug. If you break it off, well hell, you really wanted a high-output alternator anyway, right? It is also a good idea at this point to measure resistance of the new cables. Take an ohm reading between the battery end of the new ground cable and the engine block. It should read less than one ohm. Also check between the alternator bolt and the disconnected positive battery terminal, which should also be less than one ohm. If you read too high resistance, double check all connections and make sure you do not have something c**ked sideways or hanging loose.
My Accordian :)
Originally Posted by MaxJkind
Marc saying I made coffee is like anyone else saying hey, i took a breath.
Originally Posted by Genuine Rolla View Post
I fill half with V-Power and Half with Techron
So, I have V-TECH gas.
1999stockaccord is offline   Reply With Quote
Old 03-15-2007, 01:35 PM   #2
1999stockaccord
Honduh's... LULZ
NOTE: Realize that the "absolute ground" of the electrical system is not the battery negative terminal or the vehicle chassis, but is the case of the alternator itself. This is why perhaps the most important cable among the Big 3 is the engine ground strap, as this is what connects the alternator ground to the vehicle's chassis. Be certain the resistance between the alternator case (the engine block assuming the alternator is properly bolted to the engine) and the battery negative is minimized. (Thanks to the12volt for pointing this out!)
17. When you are sure you are done and anything in your system that you may have disconnected are re-connected, clean your battery posts and reconnect the positive battery terminal first, then the negative one.
18. Start your vehicle. Hopefully the engine starts. :) Examine the engine compartment and make sure none of your cables are getting hot or are vibrating or shaking around. If they are vibrating too much you may need to relocate them or use more cable ties. If you see smoke, immediately shut off the car and disconnect the battery. Seek help. :)
19. Assuming all looks good, take a voltage reading at your amplifier and ensure you read 13.8 (or higher) volts. This indicates a properly operating charging system.
20. Now'd be a good time to turn it on and make sure it sounds good! Then of course log onto the12volt.com and post that you have upgraded your Big 3!
Comments from a Moderator over there:
Originally Posted by the12volt
Great post DYohn. Thanks for posting this. Here are a couple of tips and opinions I would like to add.
When measuring for resistance to ground, it is always best to use the case of the alternator as your reference point. This is absolute ground when the vehicle is running. I also find it better to use an analog meter for this purpose since analog meters allow you to "zero out" the meter to accommodate for the much longer than usual test leads needed to make such measurements and eliminate the resistance added by the extended test leads from your readings which provides you with a more accurate measurement and a zero ohm starting point. Doing this, you will see resistance levels much closer to zero than you will with digital meters without this "zero out" feature. Also, when replacing or adding a new ground from the engine to the vehicle's chassis, you should always use the case of the alternator as the engine connection point.
As DYohn stated above, some people replace the cables and others add them. In the majority of cases it is OK to leave the existing cables in the vehicle and if your vehicle is still under warranty, you should leave them to avoid any controversy with the dealership should you have an issue, but if it's not under warranty my preference is to replace each of the following.
Negative from alternator to chassis.
Positive from alternator to battery.
Negative from battery to chassis.
Even though it is usually not necessary, I find replacing them rather than adding them makes for a cleaner installation and helps to eliminate the potential resistance problems that can result from multiple connections at the same point, especially in the harsh conditions that exist in the engine compartment of any vehicle.
My Accordian :)
Old 03-15-2007, 01:45 PM   #3
DaGFTDOne
Car Audio Guru
Nice find Marc, looks good :)
1996 VSM Integra LS
DaGFTDOne is offline   Reply With Quote
Old 03-15-2007, 01:58 PM   #4
sohclubkid
Sick 6/6
sohclubkid's Avatar
nice... im gonna try that.
sohclubkid is offline   Reply With Quote
Old 07-24-2007, 05:59 PM   #5
1999stockaccord
Honduh's... LULZ
Just found a good vid on the Elemental Designs forum:
http://www.icixsound.com/iv/view_vid...e=&category=mr
My Accordian :)
Old 03-08-2009, 06:09 AM   #6
devo1104
devo1104's Avatar
I did my engine and tranny ground wire replacement today and took some pics. I will do my engine one tomorrow because I forgot to get a battery connector for mine. I used 4 gauge wire with 7/16" ring terminals. DO NOT DO THIS if you do not know what you are doing. I assume no liability for any problems or injuries that you may encounter while doing this. My father was an electrician for numerous years and has passed on his knowledge to me. It took me about 30 minutes to complete.
Here is what you will need.
Once you gather all of that up, turn off your car, and pop your hood open. There will be a wire on the driverside right behind that head light that connects to the alternator and the front brace. It is where the head light connects to the front brace.
I numbered the two bolts you need to undo to get it out.
In order to get it off, I used the thin extension through the adapter that was in my dad's socket set because my ratchet wouldn't fit.
Once you take it off, measure out the wire and make a new wire. Make sure to crimp the wires really well!!!!!! You do not want the wire to come out while you are driving. Here is a comparison of the wires.
This is a pic of the new wire installed.
Now that you are done with that wire, you need to go over to the other side of the car to where the intake is.
Undo these two bolts and pull out the intake.
Once you have done that, you will be able to see the ground wire coming off the tranny.
Remove the two bolts that are holding it in place and remove.
Once you have it out, measure it against your new wire and crimp the ends. Here is another comparisson photo.
Once you have done that, install the new wire into your car. This is a photo of the wire installed.
After you have finished installing that wire, reinstall the intake box and test out your car.
I will update tomorrow night after I have installed the ground wire from the battery. I hope you enjoy. Also so far this mod has cost me less than $5 due to the fact that I had the wire laying around and I bought the ring terminals from Circuit City for 60% off :)
devo1104 is offline   Reply With Quote
Old 07-14-2009, 07:20 AM   #7
Zaiber
Devo, did you wire loom your cables afterwards? And...how did it look?
Zaiber is offline   Reply With Quote
Old 12-12-2009, 05:37 AM   #8
codyspeedy
Cody T
codyspeedy's Avatar
Did you upgrade the negative battery cable? (ground) I thought your spost to
codyspeedy is offline   Reply With Quote
Old 05-16-2010, 03:08 PM   #9
Mugenn_civic
Mugenn_civic's Avatar
im gunna bump this ancient thread, it's a very simple and smart upgrade, but i will add, slightly sand contact points before reinstalling ground wires. this will improve conductivity rather than trying to ground over rust.
2000 Si Build Thread - - http://www.clubcivic.com/board/showthread.php?t=182579 - - R.I.P.
1998 Ex Build Thread - - http://www.clubcivic.com/board/showthread.php?t=213781 - Current
Amp Install D.I.Y. for 96-00: http://www.clubcivic.com/board/showthread.php?t=218406
Previous name: 2002civicLx
Mugenn_civic is offline   Reply With Quote
Old 06-09-2011, 03:17 AM   #10
scarhead92
where is the negative battery cable upgrade haha
most people (guys) spend their entire lives trying to get bras off. and then you go and put one on... Ever seen a babe topless and be like "nah you need a bra" ? exactly. same thing applies to cars......
fighting with the dmv is like jacking off to rosie o'donnel, theres no happy ending and you leave depressed.... fortunately for me we dont have smog tests in OREGON but good luck buddy...
scarhead92 is offline   Reply With Quote
Old 06-09-2011, 10:30 AM   #11
angushuck
Sweet, thanks for this, really a big help for me too :)
angushuck is offline   Reply With Quote
Old 10-18-2011, 10:20 PM   #12
mrprofits1
mrprofits1's Avatar
this!
i only saw big 2
mrprofits1 is offline   Reply With Quote
Old 10-18-2011, 10:20 PM   #13
mrprofits1
mrprofits1's Avatar
will def do it
Old 04-12-2012, 12:56 AM   #14
Chris1801
Chris1801's Avatar
Good stuff if your pushing an aftermarket system this should be your first step cant go wrong with it and use 0-gauge cables when doing this for best results.
Chris1801 is offline   Reply With Quote
Old 05-03-2012, 12:27 AM   #15
DMaldonado93
DMaldonado93's Avatar
Ive learned that for the best results, to ground the battery to the engine block and to ground the other to one of the strut tower bolts. It is the most solid connection to the entire body of the car.
DMaldonado93 is offline   Reply With Quote
1994 Civic UPGRADE WHEELS 14" TO 17" DIMITRI Wheels / Tires / Brakes / Suspension 2 03-21-2011 09:00 AM
""""FULLY BUILT JDM B18C5 ITR WITH 800 horse power!!!!!!""""" dookiehatch Tech Archive (No Posting) 12 11-06-2008 10:18 PM
OEM "upgrade" part from different models? mattvivsound Tech Archive (No Posting) 2 06-04-2008 02:29 PM
Ground upgrade - theory on "increased performance" Dough Tech Archive (No Posting) 16 01-25-2008 03:16 PM
Powerslot 12" upgrade rotor kit on 15" wheels Billy. Wheels / Tires / Brakes / Suspension 15 12-11-2007 06:20 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
