Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Wheels / Tires / Brakes / Suspension
1999/2000 OEM SI Rear Sway Bar Questions
Responding Members:
User Tag List
Old 04-05-2007, 04:58 AM   #1
JohnS.
BANGARANG
JohnS.'s Avatar
Default 1999/2000 OEM SI Rear Sway Bar Questions
So I searched and I just want to confirm some information I've read. I have a 99 EX coupe and I'm aware that the LCA's should be pre-drilled and ready for an OEM sway bar to be bolted up to it.
I'm also aware that I'll need the bar, D brackets, SI endlinks (NOT gsr) and the various washers and bolts.
My questions are:
1) Would someone care to further explain everything I need in detail? Pictures would be even better than words.
2) Maybe I'm just absolutely retarded but what are the D brackets? In some threads I found, certain D brackets only worked with certain applications. I don't want to be stuck with the wrong hardware.
3) Anything else I should know before buying and installing? I don't plan on hardcore track/auto-x so I do not want an ITR/CTR/aftermarket 22mm+ sway bar nor do I want/need an ASR brace.
Questions / comments / concerns? Feel free to PM me.
New to ClubCivic? Click Me!!!
JohnS. is offline   Reply With Quote
Old 04-05-2007, 05:08 AM   #2
Sammo115
It be me, Sammo
Sammo115's Avatar
1: I think you already know everything you need.
2: Dlink or D brackets are the brackets that goes over the bushing and holds the bar to the frame also for the applications, just get the oem brackets that would fit the bushings. say u go with the Si sway, get the brackets from an Si .........dur lol
3: You should be all good.
Good luck brudda, hope this helps
Originally Posted by YoungKadafi View Post
I know most people will be like WTF-R, but after that many episodes of bangbus my fingers can bend raw titanium.
Sammo115 is offline   Reply With Quote
Old 04-05-2007, 12:31 PM   #3
JohnS.
BANGARANG
JohnS.'s Avatar
Thanks .
I just wanted to double check to make sure I wasn't missing anything. I always like to be ahead of myself before going about things.
And now too bad I'll be getting replies over on H-T from people saying that just a sway bar will make no difference at all. Someone already did so .
Old 04-05-2007, 12:59 PM   #4
Evan.
iTrader EVERYthing
Evan.'s Avatar
LOL I just checked your H-T thread, thats PEARLelectron from here, who got banned for fighting.
si does make a difference
Originally Posted by Mugenkid18 View Post
sk8shorty017: Ruining the hopes and dreams of civic enthusiasts one genuine part at a time.
Originally Posted by projektej8 View Post
mine is genuine Mugen I got it from Sk8shorty on here. He's Baller. Theyre hella expensive
Originally Posted by 98civb18c View Post
$80 is cheap, considering its been handled by the modern day jesus himself, Sk8shorty. GLWS lawl.
Evan. is offline   Reply With Quote
Old 04-05-2007, 01:05 PM   #5
JohnS.
BANGARANG
JohnS.'s Avatar
Ahhhh sk8 I was hoping you'd step in . And yeah H-T just...wow. But whatever. I know it does, especially from personally driving a car so nothing no one will say can and will change my desire of wanting one.
Now that you're here, I was actually going to PM you but I figured I'd ask in the thread as a side question. I recall that you already stated this before but couldn't find the post under your username. But what size drill bit did you use to install the OEM SI front strut bar? And what size/length nuts? I want one of those too.
Old 04-05-2007, 01:10 PM   #6
Evan.
iTrader EVERYthing
Evan.'s Avatar
Well, I dont remember the size off hand. I believe what I did was just take the largest size drill bit that fit through the holes on the si bar, lined up the bar and drilled... I think theres engraved parts on the chassis too (so you know where to drill). Then when all four holes where drilled, your ready for some mad bolt action. I just put a bolt up (from the wheel well - you may have to take a tire off) and then put a nut on it (on the si bar side). I think I also used some lock washers. Did that for all four and tightened em up. Hope that helps.
Old 04-05-2007, 01:12 PM   #7
JohnS.
BANGARANG
JohnS.'s Avatar
Yeah I'm aware there are dimples on the shock tower to show where to drill. thanks mang.
But getting back on topic, is there anything else I'm missing? I know I should probably also go with a poly bushing set for the sway but that's just a lot of money for a few pieces of polyurethane. Perhaps in the future.
Old 04-05-2007, 01:14 PM   #8
Evan.
iTrader EVERYthing
Evan.'s Avatar
Nah bro your fine. Haha you always seem to get so nervous when it comes down to doing stuff to your car. Dont be. Dont get me wrong, we are here to help, you have to be a strapping young lad yourself
Old 04-05-2007, 01:19 PM   #9
JohnS.
BANGARANG
JohnS.'s Avatar
Well it's not that I'm nervous, I just like double checking with other people that actually know about the stuff I want before going about it. Just being cautious . Thanks again.
Old 04-05-2007, 10:17 PM   #10
Sammo115
It be me, Sammo
Sammo115's Avatar
Dang, I didnt know u needed to drill holes...i thought the oem lcas already had'em haha.
Old 04-05-2007, 10:19 PM   #11
Evan.
iTrader EVERYthing
Evan.'s Avatar
They do
Old 04-05-2007, 10:21 PM   #12
Sammo115
It be me, Sammo
Sammo115's Avatar
then whats with all the drilling for again? i dont understand when i read through what u guys said when u said something about that.
Old 04-05-2007, 10:22 PM   #13
Evan.
iTrader EVERYthing
Evan.'s Avatar
we were referring to the OEM si FRONT strut tower bar. On non-si models, you have to drill through the strut tower in order to secure it.
Old 04-05-2007, 11:53 PM   #14
JohnS.
BANGARANG
JohnS.'s Avatar
Yep yep. But lucky for us, there are dimples that are put there already for you so you know exactly where to drill .
And you also do have to drill the LCA's or swap them out on certain models don't you? I just can't remember which (just woke up from a 2 hour nap).
Old 04-06-2007, 12:00 AM   #15
Evan.
iTrader EVERYthing
Evan.'s Avatar
nope, shouldnt have to drill / swap for any of the models
WTB 99-00 civic si oem rear sway bar slocvc08 Parts Wanted 0 09-14-2009 03:06 AM
99-00 EM1 Si OEM rear LCA's and Sway Bar SiRcivic27 Parts for Sale 6 07-02-2009 01:56 PM
wtb rear sway bar for 2000 civic coupe immajackuup Parts Wanted 0 02-18-2009 12:35 AM
Rear SI Sway bar on 2000 Civic dx good? pradaG Wheels / Tires / Brakes / Suspension 1 06-20-2008 08:12 AM
TW/WTB: OEM SI Rear Sway Bar & Hardware JohnS. Parts Wanted 2 04-07-2007 10:39 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
