Search:
Welcome to ClubCivic
Tach Jumping???
Responding Members:
User Tag List
Old 07-26-2007, 01:58 PM   #1
BIGODUB
bigodub
BIGODUB's Avatar
Default Tach Jumping???
I Have Another Problem With My Hatch. I Have A Autometer Auto Gage Tach In My Car. When I Start It Up It Says It Idles Around 1.5 -2.0 Rpm. When I Give It A Little Gas The Tach Sticks At 2.5 Then Jumps To 3.5. If Thats Not Bad Enough When I Give Full Throttle The Tach Goes Up To 7000 Smooth Then Jumps Down To 5000 Then Rises To 7000 Again. What The Hell Is This. I Have Hard Wired The Tach Wire To The Distributor Hoping To Fix This But It Is Still Giving Me The Same Problem. And I Have The Std Cluster So It Does Not Have A Tach For Me To Compare It To. Need Help.
embrace the snail, go turbo!!!
BIGODUB is offline
Old 07-26-2007, 02:39 PM   #2
90B16Ed
At Your Mom's House
90B16Ed's Avatar
Location: In my room with the lights off, thinking about you
check all the wires that you connected. somewhere some of the wires are not fully connected.
90B16Ed is offline
Old 07-26-2007, 02:45 PM   #3
Silver Bullet
6 spd = titis
Silver Bullet's Avatar
bad ground?
Thanks Petey For the Sig...!!!
Silver Bullet is offline
Old 07-26-2007, 04:22 PM   #4
BIGODUB
bigodub
BIGODUB's Avatar
I Have It Grounded To The Radio Ground. That Should Be Good Enough Right. Ill Have To Check The Wiring Again But Im Pretty Sure It Is Good.
BIGODUB is offline
Old 07-26-2007, 04:51 PM   #5
Genuine Rolla
Its PETEY PETE, y0!
Genuine Rolla's Avatar
How old is the tach...?
x
[ProjectJayDeM, y0!] [<><] [CCSC#9] [College.$tatus] [ClubCivicCouch Crew#4]
Originally Posted by connies92hatchie View Post
Cmon do you see how small Max's head is? Pushing Dank's body through these p***y walls is gonna be a piece of cake!
Genuine Rolla is offline
Old 07-26-2007, 06:01 PM   #6
4doorcivic16
4doorcivic16's Avatar
did tou cut the 2 wires on the back for a 4 cylinder> orange and green i think
04 wrx sti
4doorcivic16 is offline
Old 07-26-2007, 07:06 PM   #7
panda
D-series soldier
if i was you from trying it myself i would just get the built in tach you can get it out of a si i think but you need to get the one for your year if you have a 90-91 get that tach but what is prolly happening is your getting a off reading being attached to the dizzy or a loose wire but i would go with the built in tach.
ED squad #11
panda is offline
Old 07-26-2007, 07:22 PM   #8
BIGODUB
bigodub
BIGODUB's Avatar
I Dont Know How Old The Tach Is, It Came With The Car When I Bought It. But It Is Still In Good Condition.
BIGODUB is offline
Old 07-28-2007, 08:02 PM   #9
trace01m
E thug.
trace01m's Avatar
It sounds like a bad ground to me, too.
Try grounding somewhere else and see if it helps. If not, it could be something wrong with the tach, too.
Trace01m for President 2016
trace01m is offline
Old 07-29-2007, 01:13 PM   #10
rickles8099
Faster than you
rickles8099's Avatar
$20 says you have a bad ignitor pack.
rickles8099 is offline
Old 07-29-2007, 10:16 PM   #11
BIGODUB
bigodub
BIGODUB's Avatar
what the hell is a ignitor pack and where is it located.
BIGODUB is offline
Old 07-30-2007, 01:16 AM   #12
rickles8099
Faster than you
its located in the distributor. if you leave the distributor on, and just take off the cap. you will have to take off the little black cover inside the cap. on the lower front side (closest to your radiator) you will see a little either brown or black rectangle thing with about four wires going to it. that is your ignitor pack. one of the first signs of the thing going bad is a jumping tach.
any ignitor pack from a 88-91 civic will work. it doesnt matter if its a dpfi or mpfi, hatch, crx, or sedan. they all will work. if you go to the junkyard you can get them for a couple of bucks. i would recommend grabbing two or three of them because they go out fairly often.
Old 07-30-2007, 01:24 AM   #13
BIGODUB
bigodub
BIGODUB's Avatar
is there anyway to trouble shoot this.
BIGODUB is offline
Old 07-30-2007, 01:07 PM   #14
rickles8099
Faster than you
not that im aware of. but then again, i havent really checked.
tach jumping around and squeak noise 94fourdoor Interior / Audio / Electronics 7 03-13-2011 12:48 AM
://DIY 92-95 Civic Cluster Swap - from NO tach to TACH (retaining OEM miles) Declectic Tech Archive (No Posting) 14 10-18-2008 03:45 PM
jumping tach jcook8333 Interior / Audio / Electronics 1 02-05-2007 07:04 PM
Jumping Tach jcook8333 Tech Archive (No Posting) 1 02-05-2007 06:40 PM
Jumping The Ecu 20secondcivic Tech Archive (No Posting) 8 10-28-2004 09:43 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
