help! code P1337.....
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 09-25-2007, 04:19 PM   #1
lownslow
lownslow's Avatar
lownslow is on a distinguished road
Default help! code P1337.....
I have had a check engine light for some time now and i finally got around to checking the codes which came up with a P1337 on a scanner tool. I was wondering what this code is and what could be wrong and any suggestion on how to fix it. thanks. eric.
edit: 97 civic dx 5spd
lownslow is offline   Reply With Quote
Old 09-25-2007, 04:25 PM   #2
PICKLED
El mero mero Aguacatero
PICKLED's Avatar
PICKLED is on a distinguished road
P1337 = bad flux capacitor
im on a 1 Year ban because my avatar was NWS again.
PICKLED is offline   Reply With Quote
Old 09-25-2007, 04:31 PM   #3
lownslow
lownslow's Avatar
no seriously i looked the code up on one of the lists in the how to section and it says
"P1337 Engine Speed (RPM) Fluctuation Sensor No Signal" lol after thinking about this i wasnt sure if u are serious or just using a back to the future refference but regardless n e guess on how to fix it and what is wrong lol.
Old 09-25-2007, 05:01 PM   #4
PICKLED
PICKLED's Avatar
Your speed sensor is prob shot. It sits on top of the tranny.
Old 09-25-2007, 08:20 PM   #5
lownslow
lownslow's Avatar
i never even knew manual trannys had those
Old 09-26-2007, 12:32 PM   #6
lsvtecEK4
lsvtecEK4 is on a distinguished road
^^^^^wrong wrong wrong wrong wrong^^^^^
engine speed fluctuation sensor is driven off the crank, a seperate exciter ring with a magnetic sensor that recieves a signal when each tool passes. your ECU is no longer seeing this signal. most likely bad wiring or a bad sensor. you do have to remove the crank pulley and atleast lower timing belt cover. if you have no experience working cars... then here...
The scan tool indicates Diagnostic Trouble Code (DTC) P1337: No signal in the Crankshaft Speed Fluctuation (CKF) sensor circuit.
Description
The diagnostic system has a pulser rotor on the crankshaft and a pulse pick-up sensor on the engine block. The ECM/PCM monitors the crankshaft speed fluctuation based on the CKF sensor signal, and judges that an engine misfire occurred if the fluctuation goes beyond a predetermined limit.
2003 Honda Civic Si
It may look like a Honda Odyssey
lsvtecEK4 is offline   Reply With Quote
Old 09-26-2007, 12:33 PM   #7
EgHatch93
EG Whore
EgHatch93's Avatar
EgHatch93 is on a distinguished road
^--- Very nice...
Originally Posted by GSratedR View Post
i could hear it for sure. as for throwing me back into my seat and into a world of road ecstacy and high rpm sex mashed with powerful bursts of speed and exhaust notes that would make any normal person squeel with the most incredible amout of rapture. no. not really. i still felt it but i dunno if im just retarded and dont know anybetter. it feels quicker than when it was not working at all. but i still need to get a new solinoid i think.
EgHatch93 is offline   Reply With Quote
Old 09-26-2007, 12:37 PM   #8
PICKLED
PICKLED's Avatar
That'll teach me.
Old 09-26-2007, 12:38 PM   #9
lsvtecEK4
lol its all good. and thanks
2003 Honda Civic Si
Old 09-26-2007, 12:39 PM   #10
PICKLED
PICKLED's Avatar
No...thank you.
Old 09-26-2007, 04:16 PM   #11
lownslow
lownslow's Avatar
thank you very much this has been very helpful i really appreciate it bud.
Old 12-02-2007, 11:57 AM   #12
lownslow
lownslow's Avatar
lol i couldnt find this thread in so long. i never tried to fix it because i have been super busy with work and the short days have been owning me. but lol the pictures are gone that i was gunna run off of from lsvtecek4 so i cant do this is there any way that you can get them up again so i can try this out and see if thats the problem...i was told it could be my dizzy but i think your solution seems more valid. so if there is any way you could get it back up it would be greatly appreciated. thanks bro. also is it bad if i have driven this long with the cel on?
Old 12-02-2007, 12:00 PM   #13
lownslow
lownslow's Avatar
also it wouldnt be because i tapped into the wire on the dizzy to grab a signal for my tach would it? it almost seems it was not too long after i did that and rinsed down my engine bay a bit. lol. i really want to get this fixed quick its been bothering me. thanks.
Old 12-04-2007, 05:21 PM   #14
lownslow
lownslow's Avatar
BuMpItY bUmP bUmP!!!
Old 12-07-2007, 10:11 PM   #15
knightxrider1
knightxrider1's Avatar
knightxrider1 is on a distinguished road
finally someone w the same prob. i have CEL # 1336 & 1337 same thing. i read about it and it doesnt look like the sensor is an easy fix. its all the way down there and i was wondering. does your car feel sluggish? i have a d16y8 w ps and ac and i was wondering if it makes my car go into "limp mode"
bump!!!!!!!!!!!!!!!!!!!!
knightxrider1 is offline   Reply With Quote
Gsr -rpm fluctating-code p0450,p1337 civiccademas Engine Tech / Drivetrain 0 11-18-2010 01:43 PM
p1337 hormiga Show off your 7th Generation Honda Civic (2001-2005) 2 10-06-2010 09:33 PM
Dtc P1337 xowiickedox Tech Archive (No Posting) 5 03-12-2010 05:51 PM
Help! P1337 code being thrown after B16B Type R motor swap! SubieGirl21 Tech Archive (No Posting) 14 02-04-2009 07:14 PM
ctr trans stamp code and gsr head code? what are they? nurevEKcivic00 Engine Tech / Drivetrain 2 05-27-2007 01:54 PM
