Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 6th Generation Honda Civic (1996-2000)
6th Generation Honda Civic (1996-2000) 1996, 1997, 1998, 1999, 2000 honda civic hatchback, coupe, sedan, coupe si
!!!!2000 Civic Si Not Starting (distributor Problem No Spark) Need Help Asap!!!
Responding Members:
User Tag List
Old 11-29-2007, 10:34 PM   #1
Civic_Type_Si
Default !!!!2000 Civic Si Not Starting (distributor Problem No Spark) Need Help Asap!!!
hi my Si is not starting at all at first i thought it was the computer i changed it same probelm, then removed the distributor cap to see if rotor is spining and it is. I dont know what the probelm is and i cant get to work or school help asap thanks
Civic_Type_Si is offline   Reply With Quote
Old 11-29-2007, 10:36 PM   #2
civicturbo91
professional b****slapper
civicturbo91's Avatar
check crankshaft position sensor. the only problem is you cant check to see if its good you have to change it out. its like30 for my car but for a 00 si its like 1 something. good luck dude
civicturbo91 is offline   Reply With Quote
Old 11-29-2007, 10:43 PM   #3
Civic_Type_Si
dont really have alot of money rite now, i got to be sure if am going to spend around a 100 thanks man i going to look into it
Old 11-30-2007, 02:49 PM   #4
biglou954
Heyyyy
biglou954's Avatar
are the plugs getting spark?
@biglou954 on Instagram
✯2012 Chevy Colorado✯
✯2012 Honda Ruckus✯
✯1991 Honda Civic DX Sedan✯
biglou954 is offline   Reply With Quote
Old 11-30-2007, 06:51 PM   #5
snozepp147
snozepp147's Avatar
have you done a mod to it lately or did it just not start one day? make sure both fuel and spark are getting into the cylinders/
98 civic ex
OFFICIAL Mid Atlantic Meet!
FS:Bseries and More!
snozepp147 is offline   Reply With Quote
Old 11-30-2007, 09:50 PM   #6
aaren99
aaren99's Avatar
I had the same problem with an older car of mine and I changed everything from the coil, plugs wires, rotor and still nothing. I finally changed the module/ignitor located inside the distributor and as soon as I replaced it I could feel the spark go though the wires.
aaren99 is offline   Reply With Quote
Old 11-30-2007, 09:51 PM   #7
imbcruz
ItsMeBraulio!!
imbcruz's Avatar
Coil.. ?
Parts For Sale
http://www.clubcivic.com/board/showthread.php?t=129067
imbcruz is offline   Reply With Quote
Old 12-01-2007, 07:10 AM   #8
Project_EK9
Project_EK9's Avatar
check the ign.coil.
Project_EK9 is offline   Reply With Quote
Old 12-01-2007, 12:48 PM   #9
civic98turbo
I'm back ....
civic98turbo's Avatar
check all the fuses as well...
example ign coil ...there is 2 fuses for this..under dash and under hood....
if not blown check the ICM ( ignition control module) and if thats not it...check the coil itself...and then plugs, wires, cap, rotor..ect
Objects in mirror are hotter than they appear
civic98turbo is offline   Reply With Quote
Old 12-01-2007, 09:35 PM   #10
Civic_Type_Si
I Fixed the probelm it was the icm inside the dasg i had put in a blower for the heater and forgot to plug it back in lol
2000 civic Si not starting freddyrules Engine Tech / Drivetrain 3 12-12-2011 12:49 AM
B16a2 spark plug wire and distributor problem Kazan Tech Archive (No Posting) 13 12-30-2009 02:29 PM
2000 civic si starting probs jaredjmoore89 6th Generation Honda Civic (1996-2000) 20 01-08-2008 11:20 PM
!!!!2000 Civic Si Not Starting (distributor Problem No Spark) Need Help Asap!!! Civic_Type_Si Engine Tech / Drivetrain 1 12-05-2007 12:32 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
