Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 7th Generation Honda Civic (2001-2005)
7th Generation Honda Civic (2001-2005) 2001, 2002, 2003, 2004, 2005 honda civic coupe, sedan, hatchback si
2004 Civic EX Rough Idle
Responding Members:
User Tag List
Old 01-21-2008, 10:09 AM   #1
alex04civic
Question 2004 Civic EX Rough Idle
My girlfriend and I recently got an 04 Civic EX Sedan for her. This car is a rebuilt salvage car, but the price was right. It has 34,000 miles on it and bad motor mounts when we got the car, and when the car was cold it had a rough idle but it would go away after driving it a bit so i was not concerned about it. Well I replaced the motor mounts with a cheap non oil filled mounts and now the car idles rough all the time. I know its not a transmission problem because no matter what gear the car is in P R N or D it is unchanged, but once the car is brought above ~1000 rpm its runs smooth, and when its idling rough if you put your hand on the engine it seems to not have any unusual vibrations.
I am used to working on fords and my honda experience is pretty much limited to an 89 prelude with dual carbs....
Any help is appreciated...
alex04civic is offline   Reply With Quote
Old 01-21-2008, 11:00 AM   #2
EMIIspecED
TEAM OCELOT rep.
EMIIspecED's Avatar
like are we talking small vibration in the engine or dose the engine look like it's trying to wiggle it's way out of the engine bay?
EMIIspecED is offline   Reply With Quote
Old 01-21-2008, 11:21 AM   #3
alex04civic
you cant even see the engine vibrating, but if you put your hand on the engine it seems normal, but yet the car vibrates badly, thats why i am thinking that maybe its the cheap mounts i used...
Old 01-21-2008, 01:09 PM   #4
joe7987
Yep.
joe7987's Avatar
Alex, that is very possible. Cheap or not, if the mount is stiffer than stock, the car is going to vibrate more than normal. If the vibrating started immediately after you replaced the mounts, I'd be willing to bet it is simply that.
By rough idle, do you mean that the car vibrates, or do you mean that the rpm's actually fluctuate?
CCCC #04
joe7987 is offline   Reply With Quote
Old 01-21-2008, 04:00 PM   #5
alex04civic
The rpms hold solid, just have a bad vibration in the car, and once the you bring the rpms above ~1000 rpm its nice and smooth. i know the factory mounts are oil filled because the destroyed ones were leaking when i took them off the car, but these new ones are even advertised as stiffer than stock...
Old 01-21-2008, 05:08 PM   #6
joe7987
Yep.
joe7987's Avatar
Yep I'd be willing to bet that's your problem.
CCCC #04
Old 01-21-2008, 07:44 PM   #7
EMIIspecED
TEAM OCELOT rep.
EMIIspecED's Avatar
check ur subframe too it could be severly bent, or maybe not bent that much, any subframe damage can mess the whole drivetran up, just another suggestion
Old 01-21-2008, 08:33 PM   #8
Kaotic_Zeus
Most hated man
Kaotic_Zeus's Avatar
Get some OEM Engine mounts. Problem solved.
Playstation Network: Kaotic_Zeus
Kaotic_Zeus is offline   Reply With Quote
95 Civic DX Coolant Loss & Rough Idle Fiq Engine Tech / Drivetrain 2 09-29-2010 04:11 PM
90 civic rough idle then smoke after warm up bludworth06 Engine Tech / Drivetrain 0 09-22-2010 12:44 AM
I'm having the same Low rough Idle with A/C on. But mine is in a 1996 Civic EX The_Rookie 6th Generation Honda Civic (1996-2000) 7 06-03-2010 11:24 AM
95 civic lx.. somewhat rough/low idle & backfiring PhatAzzCracka Tech Archive (No Posting) 5 04-07-2010 06:45 PM
rough idle --> brake= not rough andre4444 Tech Archive (No Posting) 1 05-31-2007 08:32 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
