Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Wheels / Tires / Brakes / Suspension
How do you measure drop????on your coilovers???
Responding Members:
User Tag List
Old 02-16-2008, 02:39 PM   #1
Redwing24
Proud owner of a 99tegls
Redwing24's Avatar
Default How do you measure drop????on your coilovers???
just got my coilovers, I'm going to lower 1.75 in the front and 1.5 in the rear. My question is do I measure from the top of the coilover sleave to get the accurate height. Or what. I don't think it would be from the bottom, because that would mean less spring tension and lower drop, right??
Guardsonduty.net
Redwing24 is offline   Reply With Quote
Old 02-16-2008, 02:43 PM   #2
tonyM
caca poopoo
tonyM's Avatar
to be honest, everytime ive set up new suspention on a car,
i parked on level ground and just played with it until it was where i
wanted it to be. then i would measure the wheel gap on each wheel.
hope this kinda helps
http://img249.imageshack.us/img249/3827/tonym.jpg
tonyM is offline   Reply With Quote
Old 02-16-2008, 05:22 PM   #3
Jimmy2times
White, middle-class
Jimmy2times's Avatar
thats what i'm doing right now. u just gotta play with it and let it settle then adjust and figure it out to compensate for your weight and the weight of anything in your trunk and such.
CCMC #1 CCAWMC #16
Jimmy2times is offline   Reply With Quote
Old 02-16-2008, 05:32 PM   #4
ryanM
if you wanted a precise drop distance, you should have gotten springs.
with coilovers you just need to keep adjusting until you get it where you like it.
the way i did it was set them all the way down, put them on the car, realize my exhaust is sitting on the ground, then i raised it up until i had 1/2" of clearance and called it good.
ryanM is offline   Reply With Quote
Old 02-16-2008, 05:33 PM   #5
Genuine Rolla
Its PETEY PETE, y0!
Genuine Rolla's Avatar
What I do...is break out the measuring tape and measure the car where it was before you dropped it, then put in the new coil overs and from there, just adjust accordingly.
x
[ProjectJayDeM, y0!] [<><] [CCSC#9] [College.$tatus] [ClubCivicCouch Crew#4]
Originally Posted by connies92hatchie View Post
Cmon do you see how small Max's head is? Pushing Dank's body through these p***y walls is gonna be a piece of cake!
Genuine Rolla is offline   Reply With Quote
Old 02-17-2008, 12:33 PM   #6
Redwing24
Redwing24's Avatar
while looking at them on the floor, how are you going to move the adjusters up and down without the sleeve moving too then????
Guardsonduty.net
Just bought Progress CS-II Coilovers, how much should I drop my car? (2" or 2.5"?) 1999EM1 6th Generation Honda Civic (1996-2000) 7 10-26-2011 02:09 PM
Can someone help do a favor and measure? vertech0 Tech Archive (No Posting) 7 11-16-2009 12:49 AM
Need someone to measure their sedan kbrownmann Tech Archive (No Posting) 4 08-28-2009 01:13 AM
Can someone measure a d15b1 dipstick for me? savgbashr Tech Archive (No Posting) 4 05-18-2009 11:39 PM
measure your balls io_303 Engine Tech / Drivetrain 2 10-10-2005 12:28 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
