Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Wheels / Tires / Brakes / Suspension
Ball Joint / Wheel Bearing Removal
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 04-14-2008, 04:34 PM   #1
04CivicLX
04CivicLX is on a distinguished road
Question Ball Joint / Wheel Bearing Removal
Hey - Somewhat new to the Honda Circuit. I just took possession of a 2004 Civic LX Sedan, 5sp 70K miles, Pure Stock!. Its a nice Magnesium Metallic and runs like a champ! Its time to do some maintenance on the car and need some input. I noticed it needs a new Driver Side Ball Joint, due to a ripped boot and a clunking noise i'm beginning to get. Here is my question:
1. When replacing the Ball Joint, is it better to purchase a new Knuckle w/ the Ball Joint already Pressed in, or...
2. Buy just the Ball Joint and press out the old and press in the new?
3. If i remove the knuckle completely, is the Wheel Bearing Hub Assembly a "bolt in" unit or is it Pressed in?
4. What is the Proceedure for Removing the Wheel Bearing Assembly / Ball Joint?
I'd appreciate any of your input on any How-To's and if you know of any links that would be of help, that would be great. Thanks for your time.
04CivicLX is offline   Reply With Quote
Old 04-14-2008, 05:26 PM   #2
LatinEM2
La Raza #2
LatinEM2's Avatar
LatinEM2 is on a distinguished road
Knuckle/Hub/Wheel Bearing Replacement
Special Tools Required
Hub dis/assembly tool 07GAF-SE00100
Ball joint remover, 28 mm 07MAC-SL00200
Attachment 62 x 68 mm 07746-0010500
Driver 07749-0010000
Support base 07965-SD90100
Raise the front of the vehicle, and support it with safety stands in the proper locations.
Remove the wheel cap, wheel nuts, and front wheel.
Remove the brake hose bracket mounting bolt (A).
Remove the caliper bracket mounting bolts (B), and remove the caliper assembly (C) from the knuckle. To prevent damage to the caliper assembly or brake hose, use a short piece of wire to hang the caliper assembly from the undercarriage. Do not twist the brake hose with force.
Raise the stake (A), and remove the spindle nut (B), then remove and discard the nut.
Remove the brake disc retaining flat screws (A).
Screw two 8 x 1.25 mm bolts (B) into the disc to push it away from the hub. Turn each bolt 2 turns at a time to prevent cocking the disc excessively.
Remove the flange bolt (A) and wheel sensor (B) from the knuckle. Do not disconnect the wheel sensor connector.
Remove the flange nut (A) while holding the joint pin (B) with a hex wrench (C), and disconnect the stabilizer link (D) from the lower arm (E).
Remove the lock pin (A) from the lower arm ball joint, and remove the castle nut (B). NOTE: During installation, insert the lock pin into the ball joint pin in the range of 180 degrees or below from the inside of the vehicle. Insert the lock pin from the inside to the outside of the vehicle.
Disconnect the lower arm from the knuckle using the special too.
Loosen the damper pinch bolts (A) while holding the nuts (B), and remove the bolts and nuts.
Remove the driveshaft outboard joint (C) from the knuckle (D) by tapping the driveshaft end (E) with a plastic hammer while pulling the knuckle outward, then remove the knuckle. NOTE: Do not pull the driveshaft end outward. The driveshaft joint may come off.
Separate the hub (A) from the knuckle (B) using the special tool and a hydraulic press. Be careful not to deform the splash guard. Hold onto the hub to keep it from falling when pressed clear.
Press the wheel bearing inner race (A) out of the hub (B) using the special tool, a commercially available bearing separator (C), and a press.
Remove the snap ring (A) and the splash guard (B) from the knuckle (C).
Press the wheel bearing (A) out of the knuckle (B) using the special tool and a press.
Wash the knuckle and hub thoroughly in high flash point solvent before reassembly.
Press a new wheel bearing (A) into the knuckle (B) using the old bearing (C), a steel plate (D), the special tool, and a press. Place the wheel bearing on the knuckle with the pack seal side facing (metal color) toward the inside. Be careful not to damage the sleeve of the pack seal.
Install the snap ring (A) securely in the knuckle (B).
Install the splash guard (C), and tighten the screws (D) to the specified torque.
Press a new hub bearing unit (A) into the hub (B) using the special tools and a press.
Install the knuckle/hub/hub bearing unit in the reverse order of removal, and note these items:
Be careful not to damage the ball joint boot when installing the knuckle.
Tighten all mounting hardware to the specified torque values.
Torque the castle nut to the lower torque specification, then tighten it only far enough to align the slot with the ball joint pin hole. Do not align the castle nut by loosening it.
Install a new lock pin on the castle nut after torquing.
Use a new spindle nut on reassembly.
Before installing the new spindle nut, apply a small amount of engine oil to the seating surface of the nut. After tightening, use a drift to stake the spindle nut shoulder against the driveshaft.
Before installing the brake disc, clean the mating surface of the front hub and the inside of the brake disc.
Before installing the wheel, clean the mating surface of the brake disc and the inside of the wheel.
Check the front wheel alignment, and adjust it if necessary.
08 Civic Si coupe
LatinEM2 is offline   Reply With Quote
Old 04-15-2008, 12:23 AM   #3
simpsonbuck3436
Efficiency Junkie
simpsonbuck3436's Avatar
simpsonbuck3436 is on a distinguished road
[QUOTE=LatinEM2;2254933]Knuckle/Hub/Wheel Bearing Replacement
Damn! you better give this man some props!
"You win with people"
simpsonbuck3436 is offline   Reply With Quote
Old 04-15-2008, 12:24 AM   #4
simpsonbuck3436
Efficiency Junkie
Not to hijack this thread, but how much of a drop do you have latin, front and rear?
I read you post alot and hold high esteem of your knowledge.
Old 04-15-2008, 05:12 AM   #5
Tkdtim1226
Tkdtim1226's Avatar
Tkdtim1226 is on a distinguished road
Damn Latin, do you work on Hondas for a living or are you just that good?
What I got:
AEM SRI, Momo Pedals, Megan Shorty Header
What I don't yet have the money for:
Stage 2 camshaft with AEM Cam Gear, High Flow Cat, Magnaflow Exhaust, AEM EMS... I could go on forever
Tkdtim1226 is offline   Reply With Quote
Old 04-15-2008, 10:59 AM   #6
LatinEM2
La Raza #2
LatinEM2's Avatar
Thanks man! I have Eibach Sportline springs with 1.4 in drop in the front and the back.
Im just that good
I have access to alldata at my work so i can post pretty much anything on repair
08 Civic Si coupe
Old 04-15-2008, 11:10 AM   #7
toneekay
Rubbin on yo booty
toneekay's Avatar
toneekay is on a distinguished road
Im just that good
^i wish i had allldata.. but i dont wanna pay ;P
BLAH BLAH BLAH
toneekay is offline   Reply With Quote
Old 04-15-2008, 11:49 AM   #8
EMIIspecED
TEAM OCELOT rep.
EMIIspecED's Avatar
EMIIspecED is on a distinguished road
Damn Latin this one is for you
C:\Documents and Settings\HP_Administrator\Desktop\clubsig.jpg
If it's cool team ocelot did it first
FOR SALE : koni yellows for 04-05 em2, rears only, Great Price! PM FOR INFO
Link to my "MEMBER'S RIDES" section
http://www.clubcivic.com/board/showthread.php?t=134747
TEAM OCELOT
Originally Posted by Hecz View Post
aka, the guy that makes things happen.
Originally Posted by Bheims View Post
R2D2 > balls
doesnt get any gayer than the danglin balls, glad you went another route
devision post champion
EMIIspecED is offline   Reply With Quote
Old 04-15-2008, 05:09 PM   #9
LatinEM2
La Raza #2
LatinEM2's Avatar
If you guys need anything off alldata just contact me
08 Civic Si coupe
Old 04-15-2008, 05:11 PM   #10
EMIIspecED
TEAM OCELOT rep.
EMIIspecED's Avatar
quick question what grill do u have latin?
TEAM OCELOT
R2D2 > balls
Old 04-15-2008, 05:13 PM   #11
LatinEM2
La Raza #2
LatinEM2's Avatar
Its a Type R style off ebay
08 Civic Si coupe
Old 04-15-2008, 05:23 PM   #12
toneekay
Rubbin on yo booty
toneekay's Avatar
hmm.. whats your logon and pw
BLAH BLAH BLAH
Old 04-15-2008, 05:31 PM   #13
EMIIspecED
TEAM OCELOT rep.
EMIIspecED's Avatar
ok i was very wrong on 7thgenhonda thanks 4 the info
TEAM OCELOT
R2D2 > balls
Old 04-15-2008, 05:34 PM   #14
LatinEM2
La Raza #2
LatinEM2's Avatar
I don't have one. I work for the public library and the website has access to it
08 Civic Si coupe
Old 04-15-2008, 05:36 PM   #15
JDM Davey
Silver Member
JDM Davey's Avatar
JDM Davey is on a distinguished road
Latin i know this is completly irrelivant but do you by any chance have the color code for your car. i love that color
JDM Davey is offline   Reply With Quote
ball joint replacement raysteve Tech Archive (No Posting) 1 10-05-2010 12:40 PM
Lower Ball Joint Removal Szady Wheels / Tires / Brakes / Suspension 2 04-11-2009 03:08 PM
Lower ball joint EK_99_BOI Wheels / Tires / Brakes / Suspension 1 01-24-2007 07:08 PM
Ball Joint.... io_303 Wheels / Tires / Brakes / Suspension 6 11-14-2005 06:01 PM
Lower ball joint bubbles Tech Archive (No Posting) 13 06-09-2005 11:17 AM
