Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Generations Tech > 8th Generation Honda Civic (2006-2011)
8th Generation Honda Civic (2006-2011) 2006, 2007, 2008, 2009, 2010, 2011 honda civic coupe, sedan, si
8th Gen. Factory Radio Problem...anybody?
Responding Members:
User Tag List
Old 05-16-2008, 01:37 AM   #1
sarahsbluecivic
Default 8th Gen. Factory Radio Problem...anybody?
Proud new owner of a stock 06 Civic w/ 55k miles. The radio certainly has a problem though, hoping that just maybe someone else has had a similar issue: The radio sort of cuts off and on, even when tuned to strong station(s). It's not individual speakers, it's all speakers at once (fade/balance has no effect). When on AM, if I turn volume way up, I can just barely hear it....on FM it sounds much better, but still cuts out for no apparent reason. Often the volume increases or decreases dramatically too, also for no apparent reason (both AM & FM). Haven't tried any remedy yet, have only had car 3 days. Likely, I may need to get to the back of the radio....boy, taking apart that dash looks to be a big ordeal. Any suggestions? Thanks in advance.... Sarah
sarahsbluecivic is offline   Reply With Quote
Old 05-16-2008, 01:19 PM   #2
veca1987
I.T. SOHC i-VTEC
veca1987's Avatar
Well the reason why it the sound is going up and down because it has a feature built into the radio itself to reduce road noise the faster you drive. But what it seems like that you probably need a new Radio...Very odd Though... :\
veca1987 is offline   Reply With Quote
Old 05-16-2008, 06:03 PM   #3
GETxERxDONE
GETxERxDONE's Avatar
does the car have tint? if it does, its prob a metallic tint that is interfering with the antenna which is in the rear window.
GETxERxDONE is offline   Reply With Quote
Old 05-16-2008, 07:00 PM   #4
Tom
honda.co.jp
Tom's Avatar
eh, yes for remote transmitted items, such as keyless entry, however the tint will not effect the radio antenna in the glass, cause teh tint is not blocking or rather not in between the glass and antenna, but on teh inside of both, also the antenna is still wired from the glass to the front of the car, so this would not effect it since the signal is still snt by wire, not transmitted through the air inside of the car.
Tom is offline   Reply With Quote
Old 05-16-2008, 07:55 PM   #5
GETxERxDONE
i will have to disagree. ask any tint shop if metallic tint will enterfere with radio/GPS
Old 05-16-2008, 08:45 PM   #6
Tom
honda.co.jp
Tom's Avatar
your entitled to your opinion, but tint shop's don't know about anything more the the transmitter parts, hell even honda says that about electronically transmitted signals can possibly be lost, such as remote starts, keyless entry, and remotely operated parts, but a radio antenna signal is not the same since it captures the signal outside of the car and then sneds it via cable to the radio, not by air waves.
Old 05-16-2008, 10:10 PM   #7
GETxERxDONE
right, but if you stick a giant sheet of metal next to it, it intereferes with the signal coming in. not after it gets to the antenna.
Old 05-16-2008, 11:09 PM   #8
Tom
honda.co.jp
Tom's Avatar
good thing that tint isn't made from metal then.
Old 05-17-2008, 12:08 AM   #9
veca1987
I.T. SOHC i-VTEC
veca1987's Avatar
If it would be...that would have sucked though. Anyway............i think a solution to the problem would probably just to get a new factory radio or any aftermarket ones. Thats the only thing that i could think of. I had the same problem with my old car and an aftermarket radio. I would lose signal, sometimes not even play CD's. So just get yourself like 100 dollar CD or MP3 capable player and you should be set.
Old 05-17-2008, 07:57 AM   #10
Tom
honda.co.jp
Tom's Avatar
that in my opinion and experience over the years working for honda is that the oem audio units really do suck,besides the screens going dark, they loose signal, or the volume doesn't go up or down, or even better some snot nose kid sticks quarters in them and our service department will warranty it, lol, douchbags, lol.
Old 05-17-2008, 04:05 PM   #11
Ty's Si
Newb to the Import scene
Ty's Si's Avatar
Sounds to me like you should listen to the guy that works for honda and either take the car in and see what the warranty will do or just buy yourself a new radio. No offense to the other party that had commented.
Ty's Si is offline   Reply With Quote
Old 01-05-2011, 10:56 PM   #12
deora68
I know this is an old post, but I have searched through the forums for a similiar problem. I just bought a 2006 civic lx and the radio reception sucks. The cd player works fine with good sound quality, but when you go to am or fm there is a lot of interference. Fm is not terrible but the sound is buzzy. Am really sucks. My back glass is tinted though. Is there anything I can do for better reception? I want to keep everything stock if possible...Thanks in advance!
deora68 is offline   Reply With Quote
Old 01-06-2011, 01:05 AM   #13
GETxERxDONE
they probably used a metallic tint for the back window, which killed reception. get it removed and see if it fixes the problem, if it does, get some ceramic put back on.
8th Gen. Radio Removal hypo74 8th Generation Honda Civic (2006-2011) 1 08-03-2010 08:41 PM
8th gen. radio& speakers issue bigred1 8th Generation Honda Civic (2006-2011) 5 01-06-2009 07:28 AM
7th gen 8th gen into 6th gen????? Project "H" 6th Generation Honda Civic (1996-2000) 10 02-29-2008 09:40 PM
8th Gen SI Exhaust on a 8th gen LX ? ceppto 8th Generation Honda Civic (2006-2011) 10 10-13-2006 03:01 PM
problems with factory radio osoflin Tech Archive (No Posting) 1 01-09-2006 12:52 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
