Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Wheels / Tires / Brakes / Suspension
Symptoms of a bad wheel bearing?
Responding Members:
User Tag List
Old 05-30-2008, 05:09 AM   #1
guitar_adam2000
Alcohol ab-User
guitar_adam2000's Avatar
Default Symptoms of a bad wheel bearing?
Just noticed an odd noise from the front of my car the other day, was doin about 50. Initially i thought it was my intake but when i let off the gas and coast the noise continues. Sounds a bit like a fan going fast then slow, like VVVVVvvvvvvVVVVVVvvvv (buts its defo not the fan b4 anyone suggests that)
Tracking seems fine and tires look okay, there's no grinding or clonking, any way of checking if it is the wheel bearing without simply replacing it and hoping thats whats wrong?
guitar_adam2000 is offline   Reply With Quote
Old 05-30-2008, 04:21 PM   #2
DetainedCivic
I haz SR20
DetainedCivic's Avatar
Usually with a bad wheel bearing, if you have the car in gear (5spd), jack just one side up. If the wheel has any play in it, you could suspect a bad wheel bearing. Usually what I do is just pull the wheel off and then expect from there. They are fairly cheap to replace and a good idea if you don't have an idea how long they have been on the car.
Other then that, the noise you describe can be a number of things if it's not the wheel bearing.
DetainedCivic is offline   Reply With Quote
Old 08-05-2008, 12:58 AM   #3
drekoe
about how "cheap" would it be to replace the two front wheel bearings? and is it easy to do? if it is, i might do it myself
drekoe is offline   Reply With Quote
Old 08-05-2008, 01:24 AM   #4
Solid_Snake
Te mato con mi VTEC
Solid_Snake's Avatar
it is simple but you need a hydraulic press to press the hub out of the knuckle which then let you get to the bearing.
'99 Civic EX Coupe 5 Speed (Current car)
'96 Civic EX Coupe 5 Speed(Gone but never forgotten)
Solid_Snake is offline   Reply With Quote
Old 08-05-2008, 01:37 AM   #5
Ian123
Ian123's Avatar
i was quoted at $97 for my rear wheel bearing. and you'll know if its the wheel bearing. it will make an annoying whining noise
Originally Posted by 99sivtec509 View Post
your the s*** dude you should have your own tv show
Ian123 is offline   Reply With Quote
Old 08-05-2008, 07:49 PM   #6
2000sicivic
Paid 250 for honda to change my front one, just jack your car up and if you can move the wheel in all directions then it is the wheel bearing
2000sicivic is offline   Reply With Quote
Old 08-05-2008, 09:34 PM   #7
98blackej6
98blackej6's Avatar
jack up the and rmove the tire, the hub assembly should spin freely, any resistance at any point you need to replace the wheel bearing.
98blackej6 is offline   Reply With Quote
Old 08-06-2008, 12:52 AM   #8
JohnS.
BANGARANG
JohnS.'s Avatar
Try listening for the noise when you turn. When my front driver side wheel bearing went, I would hear this "wub wub wub" noise whenever I turned. Eventually, I felt the shaking in the steering wheel and heard it going straight as well.
I spent somewhere around $100 to get it fixed at a local shop.
Questions / comments / concerns? Feel free to PM me.
New to ClubCivic? Click Me!!!
JohnS. is offline   Reply With Quote
Old 08-06-2008, 01:40 AM   #9
EM1FTW
EM1FTW's Avatar
you can also buy/borrow s pecial tool that fits parway in the bearing. then you hit it with a really big hammer.
the press is more needed for putting the new bearing in.
EM1FTW is offline   Reply With Quote
Old 08-06-2008, 05:50 AM   #10
guitar_adam2000
Alcohol ab-User
Thought this thread had died, anyway being as its been brought back to life, i'm still having the problem, and yes it does make a wub wub wub sound when i turn in - its hard to tell which side its commin from though. Not felt any shaking through the steering wheel yet.
I've jacked up both wheels and there doesn't seem to be any play in either of em. I went out and bought the bearing a while ago but i've yet to get it fitted, I wanna make sure i identify the correct wheel first!
Old 08-12-2008, 01:51 AM   #11
drekoe
if you're gonna do it yourself, i'd say do both at the same time.
i was doing some research and found that it might be my wheel bearing or wheel hub. let me explain and you guys let me know what you think. as i take off from a stop, if i accelerate normal, it makes no noise. if i step on it alittle bit more than normal, it makes that annoying screeching sound. makes the noise in all gears only if i step on it. if i let off the gas, the noise goes away. there is no wub wub sound at all when turning. had both axles replaced due to torn boots a while back. the annoying sound only comes from right side.
Old 04-14-2013, 09:31 AM   #12
Vespabretta
Default Honda civic bearing
The humming sound from the front is 90% front bearing gne bad. You can't do it on your own,you need a hydraulic press to do it to push the old one out and the new one in,but not an expensive process .
Bearing for honda civic 2007model is (my car) DAC4378W-1(Koyo bearing) remember its for front wheel.both wheels of front have same bearings.
The humming noise will definitely do away.
The bearing alone cost me 35$/wheel or 2000 Indian rupees.
The car is running like a charm now,no noise.
Vespabretta is offline   Reply With Quote
Old 04-14-2013, 11:39 AM   #13
This thread is 5 years old. The OP has likely fixed the problem.
RonJ is offline   Reply With Quote
Old 06-28-2013, 05:45 PM   #14
drmgmenon
Hi, can you let me know where you got the bearings changed?at dealer they are quoting around 16K.thanks in advance.
drmgmenon is offline   Reply With Quote
Bad Wheel Bearing? Ann_Vine Engine Tech / Drivetrain 3 08-29-2011 05:53 PM
bad brakes or wheel bearing???? sikcoupe98 Tech Archive (No Posting) 14 07-09-2009 09:07 AM
symptoms of a bad ignition coil 93egcoupe Engine Tech / Drivetrain 0 03-08-2007 07:38 PM
Symptoms of a bad ignition coil? Jersey8 Engine Tech / Drivetrain 2 02-11-2007 10:50 AM
bad wheel bearing? Apice Tech Archive (No Posting) 14 02-08-2007 10:21 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
