Search:
Welcome to ClubCivic
B16A Build!!!
Responding Members:
User Tag List
Old 08-14-2008, 03:20 AM   #1
JDM_SPEC_SI-R
JDM_SPEC_SI-R's Avatar
Default B16A Build!!!
i got a very very good deal on a good B16A and i am going to build it first before i drop it in my car. i am going to do the Toda 1800cc Capacity up kit (pistons, crank, and rods) killer cams and gears, valve springs, pulleys, sport injection kit, oil pan and such, and just build a new engine. my questions is, if i upgrade all the internals, can i swap out the 1.6 vtec head to a 1.8 b18c5 vtec head, or is the 1.6 and 1.8 setup a little different? besides the tranny, what other upgrades can i do from the c5 to my b16a?
thanks guys
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
JDM_SPEC_SI-R is offline
Old 08-14-2008, 04:36 AM   #2
BMac00EX
BMac00EX's Avatar
Smile
B engines are interchangeable.... besides the B20a5 from the 3rd gen preludes... so yeah you could
BMac00EX is offline
Old 08-14-2008, 12:49 PM   #3
Billy.
Has returned ;-)
Billy.'s Avatar
personally i think the b16 head > b18 head. but you could swap out the cams for a mild upgrade. but if youre swapping cams you might as well get an upgrade, like a buddyclub stage III or skunk2 stage1
http://www.phearable.net/tech/cams.txt
iTrader Profile
Billy. is offline
Old 08-14-2008, 04:47 PM   #4
JDM_SPEC_SI-R
hmmm. ok, i heard the b18 head was better in many ways then the b16. not sure thats why i asked. but i am building the b16 from scratch pretty much, so i guess it doesnt matter. going all out with N/A
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
Old 08-14-2008, 04:52 PM   #5
Billy.
Has returned ;-)
Billy.'s Avatar
maybe im thinking the b16a is better than the gsr b18. either way im sure there's not a huge difference between b16a and b18c5 'cept for cams
iTrader Profile
Billy. is offline
Old 08-14-2008, 05:01 PM   #6
JDM_SPEC_SI-R
thats what i thought. not really going to make a difference since im replacing all the crap anyways. now one other thing, i read somewhere that when i build the internals, my CC is going to change with the kit im doing from Toda. its going to go from 1595cc to 1800cc, will that effect how many liters im rolling with now? how can i change my liters from a 1.6 to a 1.8 or higher if thats possible? i was also going to bore it out, sleeve it, hone it milled and deck it.... is all this required and how much will it help over all? i want to build a new engine pretty much.
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
Old 08-14-2008, 05:06 PM   #7
Billy.
Has returned ;-)
Billy.'s Avatar
im not sure if your joking or not
1000cc = 1 Liter
thus
1800cc = 1.8 Liter
the toda kit is basically a stroker kit that turns a b16 into a b18 by increasing the rod length (and replacing the crank to match). if youre going to bore it out it will be even larger than 1800cc.... a good example is the b20. it's basically a bored out b18 so it has the same stroke length but larger piston diameter giving it .2L more displacement
*EDIT*
and since you stated that youre going all-motor instead of boost you will want a high compression piston. if you run in the 13.0:1 range you can probably get 210-220whp pretty easily with a 1.8L motor
check some of these out to get an idea of what it takes to make substantial power with an N/A motor:
http://www.kingmotorsports.com/category.aspx?cat=17
iTrader Profile
Billy. is offline
Old 08-14-2008, 05:09 PM   #8
CRXsiterror
I EAT EVO's
CRXsiterror's Avatar
Hey if your taking apart your b16 soon, let me know if theres brass washers or any kind of washers on the oil squirters!!! thanks. im sitting here putting mine together and I forgot. haa.
I want to buy some floor mats for my crx, will accept GSR mats also
GS-R'S photo shoot 06 "click me"
CRXsiterror is offline
Old 08-14-2008, 05:16 PM   #9
JDM_SPEC_SI-R
YEP, thats what i meant. sorry. any tips on how to build this beast i have in mind? this will be the first internal build, so im trying to get a good idea on what and how to do things. theres a book that was mentioned on here that i can find at autozone about honda builds anyone know it?
i will also look for brass washers.
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
Old 08-14-2008, 05:32 PM   #10
Billy.
Has returned ;-)
Billy.'s Avatar
not sure what book youre looking for, but there are plenty out there. search H-T maybe
your plans didnt sound that bad. except there's no reason to start with a type R block if your going to replace all the internals anyways. i would get a b16a block with b16 tranny, get the b18c5 crank and have the it balanced and possibly knife-edged depending on how far you want to go. hone the cylinders for good break-in. forged rods to fit a b18, high comp N/A forged pistons, OEM rings and bearings, arp rod bolts and all other hardware, a good high comp headgasket, and an ecu to tune it all on. might need to up the injectors to 280cc or 300cc. then finish it all off with a good stainless 4-1 header and 2.5" exhaust. if you decide to bore out the block i wouldnt take it too far, 1.9L at most to keep strong walls, but then you need overbore pistons to match
iTrader Profile
Billy. is offline
B16A Power Build VTEC-KZN Tech Archive (No Posting) 5 12-05-2008 10:28 AM
B16a Build W/new Internals JDM_SPEC_SI-R Engine Tech / Drivetrain 10 09-04-2008 02:06 AM
Rate my build b16a Drackonn Engine Tech / Drivetrain 9 12-03-2007 06:32 PM
Should i Build my B16a(sir-II) s17yrsoldboi Tech Archive (No Posting) 3 11-11-2006 09:45 PM
b16a build question...type r internals or other NoWayBack91Si Engine Tech / Drivetrain 7 02-12-2006 06:00 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
