Search:
Welcome to ClubCivic
Z6 Vtec Head On A D15b7
Responding Members:
User Tag List
Old 11-05-2008, 08:47 PM   #1
K.O.S_88
K.O.S
K.O.S_88's Avatar
Default Z6 Vtec Head On A D15b7
I PAID 80 for head that would well what if i put the head on the d15b7 wut else would i would have to do if i did that and could i use the stock wiring harness and run a 1 wire for vtec?? i know i would need a new distributor and new timing belt and head gasket and could i use my same injectors from the d15b7 for the z6 head manifold ?? is this correct what else?
K.O.S_88 is offline
Old 11-06-2008, 12:04 AM   #2
253eg
LEMME SMANG IT GURRLLL!!
253eg's Avatar
Have you even tried searching here, HT, or google on mini-me's?
Ubuntu 11.04 Natty Narwhal
[Drive a VW]
CVLRY
Originally Posted by dank24 View Post
OP is a transvestite
253eg is offline
Old 11-06-2008, 01:13 AM   #3
K.O.S_88
K.O.S
K.O.S_88's Avatar
yea just never done it but i just found a full walkthrough
K.O.S_88 is offline
Old 11-06-2008, 01:59 AM   #4
253eg
253eg's Avatar
K, just wanted to make sure.
here is a link I found pretty helpful when I was interested in mini-me's.
http://www.d-series.org/forums/archi...php/t-802.html
[Drive a VW]
CVLRY
253eg is offline
Old 11-06-2008, 03:03 PM   #5
J_Uhrig87
bestofbothworlds
J_Uhrig87's Avatar
thread jacking here, but that link was very helpful because I am also interested in Mini-me's.
thanks for the help once again 253eg
J_Uhrig87 is offline
Old 11-06-2008, 08:49 PM   #6
12.8:1 Ls/vtec
IT'S OVER NINE THOUSAND!!
12.8:1 Ls/vtec's Avatar
take out the oil control orifice and go ahead and bolt down the head, I'd use a y8 head gasket b/c they are built better than a z6 and b7. I think you need a vx timing belt also.
12.8:1 Ls/vtec is offline
Old 11-07-2008, 05:40 PM   #7
SiBlue_EK
save the SOHC
SiBlue_EK's Avatar
are you trying to put a d16z6 head on a d15b7 block??
if so, that will not work
Save the SOHC
SiBlue_EK is offline
Old 11-07-2008, 08:00 PM   #8
12.8:1 Ls/vtec
where do you live that you've never heard of a mini me swap. Don't be so hasty to say that it can't be done, b/c it has been done thousands of times.
Old 11-08-2008, 01:11 PM   #9
K.O.S_88
K.O.S
K.O.S_88's Avatar
yea
K.O.S_88 is offline
Old 11-08-2008, 01:27 PM   #10
K.O.S_88
K.O.S
K.O.S_88's Avatar
was wondering well if i bought the p28 wiring harness and ecu why would i have to use the wire to oil pressure to the wire sine i have the head with vtec solonoid shouldnt everything just connect up without doing no modifications with the wires????
K.O.S_88 is offline
Old 11-08-2008, 01:48 PM   #11
253eg
253eg's Avatar
If you have the z6's engine harness and ecu, then you'll be set
[Drive a VW]
CVLRY
253eg is offline
Old 11-08-2008, 02:44 PM   #12
12.8:1 Ls/vtec
if and only if your car is a 92,b/c they were the only year with it wired to the strut tower plug, and if you put the harness on, then it will plug up just fine. If your car is a 93-95, then you would still have to wire it up.
Old 11-08-2008, 02:56 PM   #13
253eg
253eg's Avatar
Ah, didn't know that. Great info
[Drive a VW]
CVLRY
253eg is offline
Old 11-08-2008, 04:10 PM   #14
K.O.S_88
K.O.S
K.O.S_88's Avatar
o ok cuz i read that how to tech and it said that i have to wire it manually but i have a 92 eg
K.O.S_88 is offline
D15b7 in 98 LX: What head? epic_civic Engine Tech / Drivetrain 7 06-17-2010 05:22 PM
D15B7 head? B16EFHATCH Tech Archive (No Posting) 1 01-29-2010 01:40 AM
D15B7 with a D16Y8 head rsal22 Tech Archive (No Posting) 4 04-16-2009 12:06 PM
D15b Vtec Head On D15b7? hum22a Tech Archive (No Posting) 6 01-29-2008 10:34 PM
d15b7 series head kickere696 Engine Tech / Drivetrain 2 09-22-2004 02:27 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
