Search:
Welcome to ClubCivic
97 Civic Window goes off track!!!!
Responding Members:
User Tag List
Old 11-06-2008, 12:05 AM   #1
19josh97
RaWr Vtexz
Default 97 Civic Window goes off track!!!!
Ok guys...I need some help here.. My windows keep falling off track! And even if they stay the top left of the window wont go into the seal I have to pull my window when I roll it up.
I have a 97 ex coupe. Any help???
19josh97 is offline
Old 11-06-2008, 12:06 AM   #2
Jbuck2KCivic
Jbuck2KCivic's Avatar
Put some lube on the window track and problem solved. It is very common for this to happen on 6th gen Civics.
Jbuck2KCivic is offline
Old 11-06-2008, 12:35 AM   #3
19josh97
RaWr Vtexz
On what track? Not the seals right?
19josh97 is offline
Old 11-06-2008, 01:12 AM   #4
EK|B
EK|B's Avatar
Stolibears did a great write-up on this, search it in the How-Tos.
Help your future children live better, save water by taking a shorter shower, etc.
Originally Posted by Redturbo0 View Post
Hate you! ITS A RICK ROLL PEOPLE!
Originally Posted by CivicEXofD0om View Post
WTF is up with this rick roll s***??
And btw id hit that chick right in the face with my wing dang doodle.
Civic vs Skyline: http://youtube.com/watch?v=oHg5SJYRHA0
EK|B is offline
Old 11-06-2008, 01:32 AM   #5
highneo
Pi Lambda Phi
highneo's Avatar
spray silicone on the tracks. you might have to remove the interior door panel, so that you can put the windows back on track though.
97 civic coupe
stolen 10/25/08
f*ck thieves
highneo is offline
Old 11-06-2008, 01:35 AM   #6
19josh97
RaWr Vtexz
I have fixed it 4 times now. but it just wont stay in track. like towards the seatbelt side the window is out of the door.
19josh97 is offline
Old 11-06-2008, 02:10 AM   #7
Commodore
back again
Commodore's Avatar
The best thing to do is not to roll it down all the way. I've had to fix my window 6 times already, due to people rolling it down all the way (valets, mechanics, friends, etc). I usually leave it half-way open at most, so that the problem does not occur.
Commodore is offline
Old 11-06-2008, 10:46 AM   #8
EK|B
EK|B's Avatar
LOL I know how that is. Whenever someone rides with me, I always tell them not to roll down the window.
EK|B is offline
Old 11-06-2008, 10:49 AM   #9
Jbuck2KCivic
white lithium grease works good too
Old 11-06-2008, 10:53 AM   #10
Bheims
Bustin windows outcha car
Bheims's Avatar
Both my windows did that no matter how many times I put them back on track (it takes me about 4 minutes now lol) or how much wd-40 or silicone/grease I applied. The only thing that worked was taking it to a shop and having professionals do it. Think they replaced the motor and the track
waay fu*king frustrating
Bheims is offline
Old 11-06-2008, 10:58 AM   #11
Jbuck2KCivic
Make sure the scissor mechanism that lifts the windows up isn't bent or loose.
Old 11-06-2008, 07:53 PM   #12
v-teg
v-teg's Avatar
does that also apply to manual roll up if it comes off track?
v-teg is offline
Old 12-04-2008, 08:34 AM   #13
dontknow
Mine does this too, a right pita ...
I'm the same, Iv'e got to flick the button as I "pull" the glass up from the front of the door so as to get it seated in the top corner (above the lock).
dontknow is offline
Old 12-04-2008, 10:18 AM   #14
Solid_Snake
Te mato con mi VTEC
Solid_Snake's Avatar
Mine used to do that. I just sprayed some Wurth HHS 2000 on the tracks and never had a problem ever since. that was like 4 months ago and i roll the windows all the way down and no problems.
'99 Civic EX Coupe 5 Speed (Current car)
'96 Civic EX Coupe 5 Speed(Gone but never forgotten)
Solid_Snake is offline
Old 12-04-2008, 12:32 PM   #15
guachi
guachi's Avatar
This is a known issue for this 6th generation civics, actually i had all of those simptoms that you are describing....
On my case i was able to fix it... basically i noticed that there are issues with the rails that guide the windows through the rubber seals, the seals need to be sprayed with graphite, go to a hardware store and get some of that, if you use oil or other kind of lubricants it could damage the seals, the sliicone spray on the brushes is also a good move this will reduce the friction between brushes and the glass window as well as the graphite will do with the glass and the rubbers...
Take your door apart, open it and take a look at the scisor like mechanism, put some grease on those...
and last but not least you will notice that the window has a specific curve, that rail must also have the curb, from time to time and door slams witht he window up that rail tends to straighten up, so you need to find which point of that rail is bent and try to slowly and smoothly move it to its original possition, on my case i used a piece of wood, i found the right spot where the rail would bent and located a specially sized piece of wood there that i glued in, i actually did that about a year ago and it has been working ever since, i even put in new tinted windows and it still works great... Give a shot!!
guachi is offline
How To: Window Track Maintenance racing_kid Interior / Audio / Electronics DIY How-To's 14 07-25-2013 10:16 AM
95 Civic rear window track wires grinding? NY's_Freshest Interior / Audio / Electronics 0 09-09-2011 01:05 PM
window off track? help!! Coutts Tech Archive (No Posting) 7 07-03-2007 08:32 PM
Window keeps falling off track Puff0028 Interior / Audio / Electronics 7 06-03-2005 06:36 AM
Window off track, help! Kakusandan Tech Archive (No Posting) 3 09-24-2004 01:51 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
