Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Forced Induction
Forced Induction Nitrous, supercharger, turbo
vacuum lines
Forced Induction
Responding Members:
User Tag List
Old 11-27-2008, 11:53 AM   #1
00civicsiturbo
addicted to Boost
00civicsiturbo's Avatar
Default vacuum lines
As of yesterday, i've been putting on my turbo kit on my em1. I'm pretty much done with everything except welding my downpipe to exhaust and hooking up my vacuum lines. I've got to say, i'm pretty clueless about where to put all the vacuum lines for the turbo. I connect them to the waste gate, bov... and where do I run those?
please, any help would be greatly appreciated.
thanks
00civicsiturbo is offline   Reply With Quote
Old 11-27-2008, 12:51 PM   #2
2slo4u
wait4me
2slo4u's Avatar
if your turbo has a nipple, use that to connect to your wastegate
for your blow-off valve, use the FPR
2slo4u is offline   Reply With Quote
Old 11-27-2008, 01:42 PM   #3
00civicsiturbo
addicted to Boost
I don't think the turbo has a nipple. its just a basic greddy turbo for reference.
here’s a pic.
Can I connect the wastegate to the bov? those are the only places on the turbo kit that I need vacuum lines, right?
Old 11-27-2008, 02:29 PM   #4
96sohccivic
no just drill a hole in the turbo and put in a nipple to run to the wastegate Then run the bov off of the fuel pressure regulater
96sohccivic is offline   Reply With Quote
Old 11-27-2008, 03:02 PM   #5
2slo4u
wait4me
2slo4u's Avatar
if you dont want to drill into the turbo for the nipple(i wouldnt)..just tap into your brake booster hose..make sure its closer to the intake manifold and make sure its before the check valve
if you choose to run it off the brake booster hose, you can also fun your boost gauge hose from there also
bov-FPR
Wastegate-Brake booster hose
Old 11-27-2008, 03:06 PM   #6
TiiM iiS l3eAsT
Scamming Piece Of s***
you cant run the wastegate to the bov....
you can buy a vacuum manifold and run the vac lines to it.....
heres my vac mani.....you tee it into the brake booster line......since its the biggest vac source
dont use the plastic fittings though....go buy brass fittings bc the plastic fittings broke on me.....
heres it hooked up
WARNING
I am a low life scamming piece of s***... So pathetic and broke that I have to STEAL from others.. I am actually SUCH a low life that I take pride in this behavior..
TiiM iiS l3eAsT is offline   Reply With Quote
Old 11-27-2008, 04:03 PM   #7
00civicsiturbo
addicted to Boost
good looking out guys. thanks very much and happy thanksgiving.
Old 11-28-2008, 05:50 PM   #8
96sohccivic
its cheaper and easier to just drill the hole in the turbo.. there is already a spot for the nipple it takes 5 seconds to drill the hole and your done...
Still air in brake lines? or Lines need to be replaced chunktwo Tech Archive (No Posting) 52 06-21-2007 07:25 PM
vacuum lines LoKee05 Tech Archive (No Posting) 7 11-07-2006 10:41 PM
vacume lines? coolant lines? dank24 Engine Tech / Drivetrain 1 07-19-2006 12:35 AM
seafoam... vacuum lines..? guwakjai010 Engine Tech / Drivetrain 5 09-18-2005 03:00 PM
vacuum lines arroshiz Engine Tech / Drivetrain 1 09-03-2004 11:34 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
