Search:
Welcome to ClubCivic
Idle problem
Responding Members:
User Tag List
Old 02-10-2004, 10:19 PM   #1
softtouch
Question Idle problem
I have a Civic ESi '94. Idle is at 700 around, which should be normal. If I accelerate a little, the idle goes up to 1500, than down to maybe 300 and back to 1500 and stays there. That "going down" to 300 or below let the engine sometimes shut down. What can that be? Its like the engine dont get enough gas for a very short time. The needle is not moving or something. Everything is normal once after a second.
softtouch is offline   Reply With Quote
Old 02-10-2004, 10:21 PM   #2
x007den
New User
fuel filter may be??
x007den is offline   Reply With Quote
Old 02-10-2004, 10:23 PM   #3
softtouch
No, fuel filter is clean and intact. Strange thing is, my local honda service shop said "thats normal, as long the needle goes back"... I am very much sure that this is not normal...
Old 02-18-2004, 08:29 PM   #4
98xSLVRxEK
Do you have an intake in your car if it is a cheap one i had the same problem the rubber surround is letting dirt into your car and it is clogging the mass airflow sensor I had to take it to a mechanic to get it fixed hope that helps.
98xSLVRxEK is offline   Reply With Quote
Old 02-18-2004, 09:45 PM   #5
neandercris
Poontang Pie
have the same prob too
i think it just need more gas or sumthin
neandercris is offline   Reply With Quote
Old 02-18-2004, 10:16 PM   #6
softtouch
Its not the intake, not the gas filter, not the spark plugs, not the PCV... all checked already and all is fine.
I noticed that if the A/C is on, it is even more worse. Cant start accelerating normal. The rpm goes, for example, up to 1500, drop down to 200 (sometime even the engine shut down) and goes up to normal after that. If the aircon is off, it goes up to 1500, down to 900 and back to 1500... I have no idea what that can be. I even was at honda service center and they said, thats normal (maybe they are not normal!)...
Old 02-18-2004, 11:07 PM   #7
Tom
honda.co.jp
Tom's Avatar
electronic air control valve on the back of the intake manifold, if this goes bad it will cause a iratic idle such as you have described.
Originally Posted by Destroy View Post
Put some forged internals in it. What the f*** else would you put in, rainbows?
Tom is offline   Reply With Quote
Old 02-19-2004, 01:46 AM   #8
Anarchi
Catalyc converter or muffler could be dirty/clogged
Anarchi is offline   Reply With Quote
Old 02-19-2004, 02:19 AM   #9
softtouch
Anarchi: Thanks for the tip! I did never think about that! I will have that checked today.
Old 02-19-2004, 04:04 PM   #10
Tom
honda.co.jp
Tom's Avatar
umm no, this would not cause the car to bounce the idle, but hey if you can prove me wrong go ahead.
gearbox problem or idle problem ?? help plz~ dasltc Engine Tech / Drivetrain 1 04-13-2010 12:48 PM
Need Help! Idle Problem!! zzangkluvses Tech Archive (No Posting) 7 11-09-2008 10:56 AM
Sorry.. Idle Problem. bigdaddyvincent Engine Tech / Drivetrain 21 01-25-2007 05:02 PM
Idle problem nightryder99 Engine Tech / Drivetrain 3 09-08-2006 12:48 AM
Idle Problem defvayne Engine Tech / Drivetrain 6 04-05-2004 01:49 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
