were can i buy a sohc vtec dual solenoid
| Attention Honda Civic Visitor: Remove this block by logging in above or registering. | |||
Welcome to ClubCivic.com, a forum dedicated to the Honda Civic, including all generations. In order to post on this forum you will have to register. Registration is free and will intitle you to other site features including access to post your Honda Civic in the member's garage, join in raffles for performance parts, etc.
| Tech Archive (No Posting) This will also temporarily hold all of the old gen specific threads until they are all moved to the correct categories. |
| Please SEARCH Before Posting a New Thread. -> | |
| Ready to Post a New Thread/Question? -> | ![]() |
Thread Tools |
#1 |
#2 |
the same place you pick up synthetic blinker fluid
#3 |
#4 |
i'm a mod now
#5 | |
It's on ass-backwards.
Both the OP and everyone who posted in here is a moron.
To the OP -- That would come on a D15B Three-Stage VTEC motor. You can probably acquire one from HMOTORS online. However, it's very very very difficult to get three-stage to work correctly and requires a rather hard-to-find JDM ecu. To the rest of you -- Read above. Know what you're talking about before you flame someone. Even if they deserve it.
Jason -- 97 VSM del Sol <2WAYPARADISE> Quote:
#6 | |
#7 | |
A lot of people. It's cheaper than a USDM Y8 or Z6 motor and has the same horsepower rating and higher compression. With the use of a P28 ecu and a standard SOHC vtec solenoid, it performs as well or better than the USDM counterpart.
Smarty Pants.
#8 |
and you could get a b16 for what it costs to find that three stage ecu
#9 | ||
And since when does the three-stage ECU cost more than ... say $150? Because unless you're buying hot merchandise, you're not going to get a B16 for that much. You'll just find one qucker. Your responses are useless and uneducated, so stop posting.
#10 |
i feel 12 again
#11 |
had no idea this existed. good luck on finding one tho.
#12 |
Set This World On Blaze!!
Eran FTMFW!!!!
Eran 2 N00bs -2
Discontinued 96-98 Rear Lip #0001 ][ VSM Crew #5 ][ LSMC #2 ]
#14 |
IT'S OVER NINE THOUSAND!!
not all of the jdm d15b's have that 3 stage system,b/c it would mean that the valvetrain would be the same, which would be impossible. Maybe the 3 stage vtec-e version works the same with a single solenoid, don't know, don't care. The d15b that everybody wants is the single stage 130 hp motor with more compression,a hotter cam, and is basically a special de-stroked d16z6, with a special crankshaft and pistons. But the only reason you will need one of these is if yours is:
A. Missing B. Broken This thing isn't going to give you more vtec or anything, but they are quite a rare piece of s***.
My daily sedan build http://www.clubcivic.com/board/showthread.php?t=215355 My eg6 build http://www.clubcivic.com/board/showthread.php?t=198773 My h2b hatch and gsr hatch. http://www.clubcivic.com/board/showthread.php?t=141692 My H2b dyno day, 215 whp and 160 whtq http://i75.photobucket.com/albums/i2...03/lssvtec.jpg |
#15 | |
That's the problem with JDM motors. They have no numerical designation like the USDM and EDM motors.
There's like six different D15B's and like four D16A's. Three or four different B18C's. It's ludicrous.
| Bookmarks |
| Thread | Thread Starter | Forum | Replies | Last Post |
| I Need the Gasket for Dual Vtec Solenoid. | marcus9023 | Engine Tech / Drivetrain | 0 | 09-20-2010 03:06 PM |
| engine swap ?s. sohc vtec --> sohc non vtec | cb7resurrector | Engine Tech / Drivetrain | 3 | 03-16-2010 08:50 AM |
| D15z4 Dual Vtec Shud I Buy It???? | RESTLESS_22 | Tech Archive (No Posting) | 5 | 10-19-2009 01:13 PM |
| vtec 92-95 engine harness and vtec solenoid for sale | dagajdm | Parts for Sale | 2 | 04-30-2009 12:25 PM |
| WTB: SOHC Vtec solenoid | o0kuam0o | Parts Wanted | 0 | 06-20-2006 07:53 AM |
| Thread Tools | |
