Search:
Welcome to ClubCivic
water in trunk
Responding Members:
User Tag List
Old 02-23-2009, 07:47 PM   #1
J_Uhrig87
bestofbothworlds
J_Uhrig87's Avatar
Default water in trunk
Hey everyone, so before I start buying parts for my wife's coupe thought I'd see if anyone has had the same problems we're having.
so my wife has a 2000 civic coupe ex and she's been getting alot of condensation and water in her trunk. now when we actually open the trunk, water poors out from where the lights are attached on the trunk itself. now my first thought was tail light gasket is bad, need new tail lights. the weather stripping around the trunk looks good, and I'm thinking new tail lights should do the trick. has anyone else had this problem before?
their stock lights but I have noticed there is a little bit of condensation inside the lense of the tail lights so i figured the lights are the source of the leak.
thanks for your help
J_Uhrig87 is offline
Old 02-23-2009, 08:43 PM   #2
andrew256
andrew256's Avatar
andrew256 is offline
Old 02-23-2009, 09:14 PM   #3
mylovehx
Hatches rock
mylovehx's Avatar
have someone go in the trunk with a flash light and close it then have another person hose it down. thats what we did to find the leek in my bros prelude
Originally Posted by 203CT View Post
When at war with old rusty bolt sometimes you have to go to extreme measure to accomplish your goal. Sometime you lose the battle but I refuse to lose the war against "Old Rusty Bolts"
My EK Hatch Build: Boosted D in the works
http://www.clubcivic.com/board/showthread.php?t=209284
BUY MY STUFF!
http://www.clubcivic.com/board/showthread.php?t=216510
"Hatch Life" Member #1
"D-Squad" Member #8
mylovehx is offline
Old 02-23-2009, 09:49 PM   #4
-civic-
Paintball is better
when it rains the floor of the trunk in mine gets wet. and brother said my tail lights leaked, and i ignored it. And they condensate some times. That was my thought also
-civic- is offline
Old 02-24-2009, 12:06 PM   #5
AGD202
I have heard that the seal around the tail lights go bad and allow water to leak into the trunk on civs. My car has the same problem but not that bad.
AGD202 is offline
Old 02-24-2009, 12:26 PM   #6
Jaybo
Originally Posted by andrew256 View Post
Sunroof drains.
+1... i've got the same problem right now and im pretty sure its my sunroof. if i feel around the ledge that runs along the rear quarter panel, i can feel moisture resting there. it drains from the sunroof back along the rear window and then into the trunk.
Jaybo is offline
Old 02-24-2009, 03:44 PM   #7
J_Uhrig87
bestofbothworlds
J_Uhrig87's Avatar
hmmm, I hope it's not the sunroof. the only thing I would say about it not being the sunroof is that when I open the trunk, the amount of water that poors out from where the tail lights are. you know how the back of the tail light comes through a hole in the trunk? the water poors right from there. I'm going to replace the tail lights anyways cause my wife wants the smoked red/clears than hopefully it'll get rid of it. I was also thinking of taking the whole trunk off and maybe drying it out completly so I know if it's the lights or not. also, if it is the sunroof what do you think would be the repair cost on that? It can get pretty expensive? well I'll take it back to the dealership and make them pay for it, or at least get it fixed at their cost. I mean, I payed almost 7k for the car after tax and license. they should give me some s*** in return.
thanks for the suggestions everyone. much appreciated.
Old 02-25-2009, 06:47 PM   #8
00 Coupe Turbo
00 Coupe Turbo's Avatar
Default how to fix
I know this is kinda dumb idea but al i did was drill 4 hole in the bottom of the trung where the spare tire use to be located, and sealed aroung the holes and under the car with sealer and it doesnt fil up but i also locked myself in the truck in the rain and found the leak and fixed it but it the trunk keeps filling up then dril a couple holes i use 1/2 inch hole but thats just me hope you can fix the problem
00 Coupe Turbo is offline
Old 02-25-2009, 09:03 PM   #9
Jaybo
Originally Posted by J_Uhrig87 View Post
hmmm, I hope it's not the sunroof. the only thing I would say about it not being the sunroof is that when I open the trunk, the amount of water that poors out from where the tail lights are. you know how the back of the tail light comes through a hole in the trunk? the water poors right from there. also, if it is the sunroof what do you think would be the repair cost on that? It can get pretty expensive? well I'll take it back to the dealership and make them pay for it, or at least get it fixed at their cost. I mean, I payed almost 7k for the car after tax and license. they should give me some s*** in return.
the rear drains for your sunroof go through the c-pillar and down into the fender. they empty behind the rear wheels. if it was wet behind the outter portion of your taillights (closer to the fender), i'd suspect drains. but from the sound of it, since it's actually going into the center portion of your taillights, i'd kinda doubt it's the sunroof. i think trunk seal and the lights are most likely.
good luck!
Jaybo is offline
Old 02-25-2009, 10:28 PM   #10
J_Uhrig87
bestofbothworlds
J_Uhrig87's Avatar
yeah thanks for the help. I think for now I'm just going to change out the lights. It doesn't pool up a lot needing to drill extra holes. actually the center of the trunk stays pretty dry. it's mainly around the edges and when I open the trunk it drips into the center. it just keeps making the rear window fog up crazy. it's more than fog too, like really really thick condensation. I'll start with the lights, and if that doesn't help, I'm taking it back to the dealership and slapping the guy in the face.
Old 02-26-2009, 10:27 PM   #11
VIPEk00
Im actually having the same problem.
when it rains or i wash my car water comes in the trunk...not dramatically like OMG..FTW..
but when i open my trunk water poors in on the outter sides of the tailights.
were they come thru on the inside..
And they leak on the outter sides of the inside of my trunk, if that makes any sence.
it sucks because i just built a custom box for my sub an etc and i dont wanna get it wet.
but i hear it may be the tail light seal's which i want my Si tail's but dont know where to get seals.?
mabe adavanced or Oreily's?
LMK
VIPEk00 is offline
Old 02-26-2009, 10:40 PM   #12
Jaybo
Jaybo is offline
Old 03-02-2009, 04:49 PM   #13
mok890
I had the same problem in my 99 ex couple i ended getting locked in the trunk with a flash light but i noticed the right inner lip had a slight crack so i siliconed every crack and taped up all the holes from the trunk siliconed the lights but it fixed it....so cover all holes and cracks lol
mok890 is offline
Old 03-02-2009, 05:48 PM   #14
greenlx777
BigRed is Dead
greenlx777's Avatar
water in the knee
"Operation"
My Boosted B16 >>>>> "Built Turbo SIR"
Custom Turbo Manifolds
Stainless - Mild Steel - Aluminum
greenlx777 is offline
Old 06-10-2009, 06:58 PM   #15
xirixh3x
xirixh3x's Avatar
It could be if your car is debadged it can go through the two wholes in the trunk where the badge goes
xirixh3x is offline
trunk leaking water? ohsnapzitzmeng Tech Archive (No Posting) 12 07-11-2010 05:33 PM
Water in Trunk mrbassman001 Tech Archive (No Posting) 3 10-15-2009 07:03 PM
I'm getting water in my trunk NSZteg Tech Archive (No Posting) 12 02-07-2009 04:11 PM
Water in Trunk - 2000 LX browns58 6th Generation Honda Civic (1996-2000) 10 07-08-2008 03:10 AM
water in the trunk BRAK54 Tech Archive (No Posting) 10 01-04-2007 02:05 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
