Search:
Welcome to ClubCivic
how do i bypass the crank sensor?
Responding Members:
User Tag List
Old 03-05-2009, 12:43 AM   #1
EkcivicJDMstyle
EkcivicJDMstyle's Avatar
Default how do i bypass the crank sensor?
im swapping my single cam for a different one. its a built jdm d15b block with a built z6 head. i need to bypass the crank sensor. how do i do this?
IM SO JDM MY BLOOD TYPE IS TYPE-R
IM SO JDM TEIN MAKES MY BED SPRINGS
Build Thread- http://www.clubcivic.com/board/showthread.php?t=192045
EkcivicJDMstyle is offline   Reply With Quote
Old 03-05-2009, 03:14 AM   #2
Matt.
so your going obd2a to obd1? Just use a obd2a jumper to obd1 and don't plug the crank sensor into anything. Its no problem.
Or if you really wanted to, you could crack open the stock engine and swap it all over. But its not worth it.
Matt. is offline   Reply With Quote
Old 03-05-2009, 08:36 AM   #3
EkcivicJDMstyle
do you mean the obd1-obd2 dizzy plug? if i have that and i just dont need to plug the crank sensor in at all? i was told i have to wire a few wires together.
Old 03-06-2009, 11:49 AM   #4
orioncivic
by useing the jumper harness it bypasses the pin for the crank fluctuation sensor you can wire it up without the jumper but it will take some patience and homework on the web id just get the jumper and call it a day
orioncivic is offline   Reply With Quote
Old 03-07-2009, 02:37 AM   #5
96civicrunner
Or just use a JDM ECU... JDM ECU's don't read the crank sensor... gey gey USA haha.
96civicrunner is offline   Reply With Quote
Old 07-08-2010, 12:14 AM   #6
wyldhorses
I tried the bypass trick and it didn't work. Any other ideas or what might be wrong with my car?
wyldhorses is offline   Reply With Quote
Old 07-08-2010, 03:12 AM   #7
got traction
i rock the sohc
got traction's Avatar
run a obd1 ecu
"You can never have enough horsepower or ammunition"
7.91@ 196 - Outlaw B series | 9.49 @ 157.3 - Vitara D16 (retired) | 9.81@ 137 Street AM K series 8.46@ 178 - SFWD B series
Originally Posted by redcivicls95 View Post
Yes. Im going to go buy back one of the cars i've built and drive to your s***hole to spank your single cam ass................NOT!
got traction is offline   Reply With Quote
Old 07-09-2010, 11:54 AM   #8
HaroldCivic96
I have the same problem how would my car run with out it plug up?
HaroldCivic96 is offline   Reply With Quote
O2 sensor bypass... lilROOKZ Tech Archive (No Posting) 6 07-17-2009 05:50 PM
Help With O2 Sensor Bypass Oliver Twist Tech Archive (No Posting) 6 07-23-2008 09:05 PM
Can i bypass my Throttle Position Sensor (TPS)????? B18cbubble EFI Tuning 9 06-12-2008 10:54 PM
Can i bypass my Throttle Position Sensor (TPS)????? B18cbubble Engine Tech / Drivetrain 13 05-09-2008 03:22 AM
Crank Sensor? coachwoody Engine Tech / Drivetrain 0 09-19-2004 08:00 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
