Search:
Welcome to ClubCivic
Fixing Jerk on Acceleration
Responding Members:
User Tag List
Old 03-05-2009, 02:31 AM   #1
Evan.
iTrader EVERYthing
Evan.'s Avatar
Default Fixing Jerk on Acceleration
Here's the setup:
1999 Civic EX
B16A3 Motor
4.785 Final Drive in Si Tranny
Symptoms:
In any gear (1-5), when I let off the gas pedal quickly (don't feather it / slowly let off), the car kind of "bucks" back and forth very noticeably. It's most aggressive in 1st gear and least (but still noticeable) in 5th gear. At the same time, if I barely press on the gas pedal (as in stop and go traffic) I get a similiar reaction.
I've determined that it's the motor mounts, namely the rear mount being the main issue. I can replace the rear mount with an OEM Honda mount just fine, but i'd rather replace it with something a bit more durable since it's under a higher load due to the final drive set / etc. However, at the same time I DONT want alot of rattling that comes with aftermarket mounts. So here's the options I've been debating:
A) Get energy suspension inserts on top of the new mounts.
Notes: Alot of people are complaining about aggressive rattles.
B) Get just the Hasport rear mount
Might be too stiff?
C) Get ITR replacement mounts
supposively more beefy than others but retaining stock comfort?
D) Just replace the mounts with OEM Si.
Originally Posted by Mugenkid18 View Post
sk8shorty017: Ruining the hopes and dreams of civic enthusiasts one genuine part at a time.
Originally Posted by projektej8 View Post
mine is genuine Mugen I got it from Sk8shorty on here. He's Baller. Theyre hella expensive
Originally Posted by 98civb18c View Post
$80 is cheap, considering its been handled by the modern day jesus himself, Sk8shorty. GLWS lawl.
Evan. is offline
Old 03-05-2009, 02:35 AM   #2
eskateboarding7
eskateboarding7's Avatar
I believe I have the same "jerkiness" with my RSX. Motor mounts you say huh? I might have to try that if it solves your problem. I've just always read that Hondas are like that and to just put up with it Let me know how it goes.
eskateboarding7 is offline
Old 03-05-2009, 02:54 AM   #3
Black!e
i think thats normal? ehh cuz i have the same jerkiness when i do that
Black!e is offline
Old 03-05-2009, 06:16 AM   #4
mixwell
if you get hasport mounts, get the ones with the street bushings, not race or they will be too hard and your car will vibrate too much.
mixwell is offline
Old 03-05-2009, 11:47 AM   #5
JohnS.
BANGARANG
JohnS.'s Avatar
I have the same problem. 90% of my driving is city driving too so especially in traffic and such, I'm always in 2nd and I gotta let off the gas, coast, press the gas slightly, coast, etc. My car jerks really bad. I push in the clutch to avoid it .
I'm thinking OEM mounts might be too soft... ES will be too harsh... Try ITR ones...?
Questions / comments / concerns? Feel free to PM me.
New to ClubCivic? Click Me!!!
JohnS. is offline
Old 03-05-2009, 05:24 PM   #6
devo1104
devo1104's Avatar
what sort of shifter bushings do you have? when i replaced mine i noticed that it was harsher when i used the clutch
devo1104 is offline
Old 03-06-2009, 05:17 PM   #7
andrewmrtnsn
mine was doing the same thing.. believe it or not it was the IACV. it bucked like a SOB til i got it replaced
andrewmrtnsn is offline
Old 03-06-2009, 05:56 PM   #8
CivicMafia
OEM SI mounts, The guy who had mine i belive replaced with some race mounts ( Idk what kind ) But you can feel the can shake specially when rev'ing ( not real bad though )
CivicMafia is offline
Old 03-06-2009, 05:57 PM   #9
mymmeryloss
RHD is where its at
mymmeryloss's Avatar
itr sounds best to me
***** Turbo Rotary Mazda Minitruck Build*****
Originally Posted by civhatch92 View Post
I love the custom aspect of this build.. totally genius and still super clean!!
mymmeryloss is online now
Old 03-06-2009, 06:12 PM   #10
ryanM
evan, when you go from WOT acceleration to 0 throttle, especially in 1st gear, the engine braking that occurs is very similar to what you would experience if you slammed on your brakes at 50mph. of course your car is going to buck like that. if you dont want it to, push your clutch in when you let off the gas abruptly
ryanM is offline
Old 03-06-2009, 07:33 PM   #11
phong3992
It might be the IACV.. I had that same problem.. it was jerking a horribly in 1st gear..
Check that sensor..
When the car is in neutral trying going slowly through the revs.. if it starts to bounce in between.. 1 - 5 thousand RPM.. its probably your IACV... push the throttle very steady through rpms thats how i knew it was my IACV..
phong3992 is offline
Old 03-07-2009, 01:35 PM   #12
Evan.
iTrader EVERYthing
Evan.'s Avatar
thanks guys...
I know it's partially due to the wear and tear on the mounts but at the same time I'm sure the final drive set and "torque" of it doesn't help..
Evan. is offline
Old 03-07-2009, 07:31 PM   #13
97GreenEX
SiR=Hotness
97GreenEX's Avatar
Same happens to me. But I have polyurethane mounts...And yes it vibrates like a mofo
Gre-EJ8-n
97GreenEX is offline
Old 03-07-2009, 07:35 PM   #14
ryanM
its NOT a problem
thats NORMAL
its like saying "why does my car slow down when i let off the gas?"
ryanM is offline
Old 03-07-2009, 07:41 PM   #15
Evan.
iTrader EVERYthing
Evan.'s Avatar
right, but i'm saying it decelerates hard. I think it's due to the final drive and short gearing though.
Evan. is offline
Slow Acceleration & Quick de-acceleration. STILL BLAZEN Engine Tech / Drivetrain 6 04-14-2011 01:40 AM
jerk/knock question!? civic92si Engine Tech / Drivetrain 0 03-23-2009 03:44 AM
Whitest Kids U' Know - Slow Jerk civicexcoupeman Off Topic 3 09-24-2007 09:41 PM
Clutch Is being a jerk. Help! hundredwatt Engine Tech / Drivetrain 8 08-30-2006 11:27 PM
Jerk at 2k rpms JiuJitsu_greg Tech Archive (No Posting) 5 11-20-2004 02:50 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
