Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Wheels / Tires / Suspension
diy- energy suspension rear trailing arm bushings
Old 03-25-2009, 01:57 PM   #1
ventturei26
Capt. Fuse
ventturei26's Avatar
Car: 95 civic hatch
Power: 134 HP / 110 TQ
1/4 Mile ET: 15.207 @ 0.00 MPH
View/Rate My Garage
Default diy- energy suspension rear trailing arm bushings
so i have had these nice new bushings here for awhile now and today i decided (after looking at my torn bushing) i should probly do this today, i did a few other things today, but i didnt take picture of the, they included the good ol arp extended studs and some new rotors and pads, i as about ready to put my russel SS brake line on but someone before me stripped the nut going to the hose
new bushings!!!
now i found t way easier to havethe knuckles off of the car while doing this, for two reasons on i can manuever them around and get the from different angles, which makes this whole thing alot easier and 2) if u et pissed off like i did and use a torch to burn the bushing out, it may be a god idea to not have it attached to the car when the things on fire, specially that close to a fuel tank
started with the stock trailing arm and bushing
nah- thats not torn, its just weathered a bit...
i starter by pulling the broken bushing away and slicing at it with my safety knife (arnt really that safe though,those things are sharper than most my other knives)
and now you have this...
next i started using the knife again to trim away all of the excess rubber from the pic (since it will be reused with the energy bushings)
i got to about this before i gave up for the night and went to bed...
next day i used a die grinder and removed the last remaining rubber and cleaned the pin up a bit
now we start on the rest of the bushing thats still in the trailing arm, after about 30 minutes of trying to cut with a saw, a knife and a few other air powered tools, i got pissed off, and got the torch
(you could ue a butane torch, available at any parts store, i just happen to have a oxy/ace torch laying around...
while still hot, use a file and remove the extra bushing material while its still hot,after everything it will look like this
all nice and clean
time for....bushing!
now you have to make sure you put the pin in the right way because they are offset and that will matter the next time you want to go align your car, so put them in right the first time even if it take ya a bit to look back and forth, i used a paint pen on the pin and wrote (inner and outer on the pin) and always make sure that you add some lube to the inner and outer part of the bushing before they are pressed in, it will come in the box
now it just happens i have a press, which is by far the easiest way to do this but there is a second.
in the energy manual they say that if u get a 4.5" washer, some spacers and a bolt, you can use them together with 2 wrenches to press them in yourself. (the directions came with the bushings, but a press would be easier and faster)
all done, i went a bit farther and cleaned everything up, masked everything off, sanded off the the weatherbeaten trailing arms and primed them with a high temp coating
and then used a engine gloss black to finish the job, afterwards they looked the nicest ive ever seen them
added my brembo drilled and slotted rotors and my raybestos pads, im waiting till summer to redo my brake so i can finally put my dimpled rotors and hawk hp+ pads on!
and bolted them back up into their spot
a pic of my suspension that could use a cleaning
dont forget, if u disconnect your brake lines in any way you have to rebleed your system and when your doing a job like this its always good to have an alignment done
and finally after all that, cars back on the road, definaly feeling better, turning a bit more solid and i my rear bushing no longer sqeak.
final-
and there ya go
I CONSIDER IT MY CIVIC DUTY TO OWN A HONDA
wtb: front camber arms, jdm audio console, CF hood and hatch
ventturei26 is offline   Reply With Quote
Old 03-25-2009, 02:02 PM   #2
USDM EJ6
Titanium Member
USDM EJ6's Avatar
Car: NFR AP2
View/Rate My Garage
nice dude!!!
USDM EJ6 is offline   Reply With Quote
Old 03-25-2009, 07:06 PM   #3
95CiveX-Mc
95CiveX-Mc's Avatar
Car: 95 Civic
View/Rate My Garage
shit hahaa i was jus lookin for a DIY for the RTA bushings hahaa nicely done!
95CiveX-Mc is offline   Reply With Quote
Old 03-25-2009, 07:17 PM   #4
AllStockHatch
UNREGISTERED USER
AllStockHatch's Avatar
Car: 99 Hatch and a 07 Ruckus
View/Rate My Garage
Nice write up.
AllStockHatch is offline   Reply With Quote
Old 03-25-2009, 07:46 PM   #5
Silver Bullet
6 spd = titis
Silver Bullet's Avatar
Car: 2005 rsx type s
Power: 170 HP
View/Rate My Garage
awesome work!
Thanks Petey For the Sig...!!!
Silver Bullet is offline   Reply With Quote
Old 03-26-2009, 01:07 AM   #6
CMRdevelopment
It be me, Sammo
CMRdevelopment's Avatar
Car: 98 Hatch Dx : EJ6
Power: 2whp HP / 1.2lbs TQ
View/Rate My Garage
sweet! ive been wanting to upgrade my bushings to but i dont have a damn torch.,
Originally Posted by YoungKadafi View Post
I know most people will be like WTF-R, but after that many episodes of bangbus my fingers can bend raw titanium.
CMRdevelopment is online now   Reply With Quote
Old 03-26-2009, 02:17 AM   #7
ventturei26
Capt. Fuse
Car: 95 civic hatch
View/Rate My Garage
its possible to buy a butane torch from a auto parts store. i just happen to hve access to a oxy/acc torch and there a bit more powerfull....lol
Old 03-26-2009, 08:09 AM   #8
LowNotSlow
Aqua Teen Christmas Force
LowNotSlow's Avatar
Car: RSX, CRX Si
Power: little HP / none TQ
View/Rate My Garage
You had a press, why didn't you just press out the old bushing?
LowNotSlow is online now   Reply With Quote
Old 03-26-2009, 03:04 PM   #9
ventturei26
Capt. Fuse
Car: 95 civic hatch
View/Rate My Garage
because when using a energy bushing you have to reuse the oe metal housing from the old bushing
Old 03-26-2009, 03:21 PM   #10
CMRdevelopment
It be me, Sammo
View/Rate My Garage
notice a difference yet?
Old 03-27-2009, 01:55 AM   #11
GC11090
GC11090's Avatar
Car: '99 Civic Coupe
View/Rate My Garage
Sweet, that is my project as soon as they come in along with the rest of my rear disk swap. Thanks for the DIY
GC11090 is offline   Reply With Quote
Old 04-01-2009, 05:51 AM   #12
ventturei26
Capt. Fuse
Car: 95 civic hatch
View/Rate My Garage
definate difference, my side to side motions are alot better and long turns seem to be alot easier now, i cant believe it took me almost a year for me to do these. it greatly improved the feel of my car
Old 04-01-2009, 06:50 AM   #13
Kaotic_Zeus
Most hated man
Kaotic_Zeus's Avatar
Car: 04 ES2
Power: 1 HP / 2 TQ
View/Rate My Garage
nice... was your alignment off much? if anything at all?
Playstation Network: Kaotic_Zeus
Kaotic_Zeus is offline   Reply With Quote
Old 04-01-2009, 03:31 PM   #14
ventturei26
Capt. Fuse
Car: 95 civic hatch
View/Rate My Garage
wasnt off, as long as you detach just the kunckle itself and leave the camber and toe adjustment pieces on the car, when you bolt everything back up it will be the same.
i didnt do one, but then again i do need to get all my camber kits in, and new front lcas before, after that yea 4 wheel alignment
vB code is On
ClubCivic.com Merchandise Free Overnight Shipping on Competition Clutch Products Save on AEM UEGO Widebands Skunk2 Camber Kit Sale
Find this site helpful? Donations are appreciated.
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Forum SEO by Zoints
