Search:
Welcome to ClubCivic
Hood Release Cable
Responding Members:
User Tag List
Old 04-09-2009, 09:32 PM   #1
SoJ1Ro
just sit back and enjoy
SoJ1Ro's Avatar
Question Hood Release Cable
Sup guys, so i recently just bought a new hood release cable kuz mine broke like most hondas. i was wondering if there is a thread about how to install it. i've done my homewok and found other websites that explained how to install it, but not for a honda. Im pretty sure its the same. I just want to know if you guys ever installed one before and how hard is it? whats your experience with this?
SoJ1Ro is offline
Old 04-10-2009, 01:20 AM   #2
toxicity359
im doing this on my car soon, when i figure out ill send you a holler.
toxicity359 is offline
Old 04-10-2009, 03:52 AM   #3
SoJ1Ro
SoJ1Ro's Avatar
sweet yeah tell me how it goes. i already know where its goin in and all but if you could take pics. that be awesome. thanks
SoJ1Ro is offline
Old 04-10-2009, 10:51 AM   #4
mitka
It is easiest to replace if you took your fender off. In fact it is self evident how to do it then. You will need to get two plastic retainers under fender to hold it (I never was able to remove existing ones w/o damaging them). The rest of plastic retainers (on the bulkhead) can be taken off easily w/o damage.
w/o taking fender off:
you need to pull out old cord (you basically unscrew the release lever, cut the cord from inside, pull out rubber grommet that plugs hole in the firewall, and pull the cord out from the outside). Then thread in new cord from inside the car, when you need to catch it from the hole in front which is tricky thing to do. This way of course you bypass the retainers under hood, which is not important - it will work w/o them.
You need to take hood latch out in order to attach the cord to the latch properly. Take marker and mark the contour of the latch on the bulkhead, so you know how to position it in the same place when you reattach it.
mitka is offline
Old 04-10-2009, 06:24 PM   #5
SoJ1Ro
SoJ1Ro's Avatar
is there any size bolts i should have to be ready for this? and thanks for the info
SoJ1Ro is offline
Old 04-10-2009, 07:26 PM   #6
jerzfinest13
jerzfinest13's Avatar
Would it be difficult to put in the hood latch b/c I need to install 1 since the previous owner broke the stock and added some random Hood latch. Any help? Or would I have to replace the whole thing (latch & cables)
jerzfinest13 is offline
Old 04-10-2009, 10:26 PM   #7
deemee
I am the Master...
deemee's Avatar
i would recommend relocating your hood cable as a crime deterrent since your installing a new one
here is a link with instructions http://causeforalarm.thecarthing.com...ble/index.html
deemee is offline
Old 04-11-2009, 12:00 AM   #8
mitka
No need to replace the cable if cable is not damaged and works. you take off grille to get access to two bolts that hold latch.
mitka is offline
Old 04-12-2009, 02:12 AM   #9
sixwhip14
sixwhip14's Avatar
Mine is broke as well, but I don't mind. It would take that much longer for some scumbag to get at my engine.
sixwhip14 is offline
Old 04-13-2009, 01:06 AM   #10
jerzfinest13
Ohhh ok, it still opens its just that damn latch is a cheap ass 1 and sucks when I have to open my hood.
Old 03-16-2010, 07:48 PM   #11
thambi23
thambi23's Avatar
on my 2000 civic the same thing happened the plastic part broke off can i just buy the plastic part or need to replace the cables and everythin else..
thambi23 is offline
Old 03-16-2010, 09:40 PM   #12
red98civ
red98civ's Avatar
holy thread resurrection...!
if you're talking about the little handle you pull to open the latch, i believe you have to replace the whole cable. I recently did a cable-relocate but left the little handle off, it'll make it just a tad bit harder for a thief
red98civ is offline
Old 04-21-2010, 07:39 PM   #13
DaggWood
DaggWood's Avatar
There is a simple solution to the broken handle.
Look at this post,. http://www.clubcivic.com/board/showt...57#post2915757
Really simple to fix, no need to remove anything in the car.
DaggWood is offline
Old 04-21-2010, 08:00 PM   #14
CIVIC_VTEC
LOW AND SLOW!
CIVIC_VTEC's Avatar
s*** idk i took my hood release off and put in hood pins
LOW AND SLOW
CIVIC_VTEC is offline
Old 07-14-2010, 01:48 PM   #15
tomrip1
great info....BUT my hood is closed, cable broken, how can I release the hood now??
tomrip1 is offline
Hood Release Cable broken, please help!! jistenstrom Tech Archive (No Posting) 3 02-18-2010 11:59 PM
Hood Release Cable Troubles Szady Tech Archive (No Posting) 5 11-20-2009 02:33 PM
Hood Cable Release Re-route Slick_99 Tech Archive (No Posting) 7 07-08-2009 01:23 PM
Relocated Hood Release Cable JDM-JNKY Tech Archive (No Posting) 7 09-24-2006 05:59 PM
evil hood release cable.. xxsenceo89x Exterior / Detailing / Bodywork 18 04-08-2006 06:53 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
