Search:
Welcome to ClubCivic
How to test radiator fan
Responding Members:
User Tag List
Old 04-22-2009, 06:01 PM   #1
takeachance
Default How to test radiator fan
I changed my coolant today and let it idle for a while and filled it up when it needed it but i never saw the fan turn on. The top hose was hot and could barely touch it and the bottom hose was also hot. I couldnt find any bleeder screw near the thermostat. It never got above what it normally does on the temp gauge though so i dont tihnk it overheated.
takeachance is offline
Old 04-22-2009, 08:18 PM   #2
2slo4u
wait4me
2slo4u's Avatar
to bleed it just let it sit with the cap off for a bit
try positive negative to the battery and see if the fan kicks on that way
2slo4u is offline
Old 04-22-2009, 08:38 PM   #3
sf22189
names Brenton
sf22189's Avatar
cap on to the "first stop" That way you don't have radiator fluid boiling over all over the place
[WTB RADIATOR FOR EG IN OHIO]
sf22189 is offline
Old 04-22-2009, 08:52 PM   #4
takeachance
i tested the fan at the ECT plug on the thermostat housing and it came on so the fan works....maybe its just not gettting hot enough??? or the temp plug might be bad
Old 04-22-2009, 09:17 PM   #5
knightxrider1
knightxrider1's Avatar
did you fflip your switch to HOT inside the cabin? it kinda takes a long time w the cap off and your filling it w fresh coolant for the fan to come on. like. 15 mins.
knightxrider1 is offline
Old 04-22-2009, 09:41 PM   #6
zeroarmy27
It does take quite a while for the fan to kick on on my HX. I replaced the radiator in it about a year ago and had the same worry, but the fan kicked on when it needed to. Take it for a small spin around the block and come back, if the fan still doesn't come on... wait a while. Watch the temp. gauge.
Just got my HX back after a year of captivity. I love my EJ7.
zeroarmy27 is offline
Old 04-22-2009, 09:54 PM   #7
takeachance
yea i drove around the block afterward and i didnt hear it turn on but it seems the temp gauge on the dash was right about where its supposed to be. I just dont want it to overheat. The top hose was really hot though im not sure how hot its supposed to get.
Old 04-22-2009, 09:59 PM   #8
zeroarmy27
it should be hot, bottom colder. That's the point. I had to let mine idle for about 10 mins after a 2 mile journey until the fan kicked on. I was worried about wiring/relay until it kicked on.
Do I need a radiator fan? Ceros Engine Tech / Drivetrain 5 08-20-2010 03:47 PM
Radiator Fan help??? powerdbyhonda Tech Archive (No Posting) 2 06-20-2007 08:26 AM
Radiator Fan recall Tech Archive (No Posting) 6 02-20-2007 08:12 AM
Help with Radiator Fan legion Engine Tech / Drivetrain 2 01-10-2005 02:33 AM
Radiator Fan ? Turbocivic71 Engine Tech / Drivetrain 5 11-17-2003 05:08 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
