Search:
Welcome to ClubCivic
How to check Oil Pressure and Oil Pump?
Responding Members:
User Tag List
Old 05-10-2009, 10:08 AM   #1
pburchins
Default How to check Oil Pressure and Oil Pump?
We are in the process of swapping motors. The last motor we put in threw a rod in the # 4 cylinder. We started to take apart the old engine and everything looks good. I am wondering if the oil pump failed on the motor and wasn't pumping the oil. I don't want the same thing to happen on the new (used) engine.
How can I confirm that the pump is working and the oil pressure is actually ok ?
Thanks,
pburchins is offline
Old 05-10-2009, 10:51 AM   #2
SGGilmo
Yay, Another Car.
install it and get a oil pressure gauge. or you can do this.
Originally Posted by BULL3TPR00F View Post
well i managed to get it in i just had to jiggle it like crazy back and forth while smashing it in over and over again
94 Grand Am 86 Cougar 95 Civic EX eh9 90 PreludeSI
91 Integra LS 94 Civic EX ej1 92 Prelude si 89 Mighty Max
92 Mighty Max 4x4 v6 89 FZR600 06 GSXR750 93 Miata
01 Miata 09 R6s 07 CBR600RR 00 Dakota 92 Civic LX eg8
SGGilmo is offline
Old 05-10-2009, 11:15 AM   #3
pburchins
Great......Thank you for the information! I want to double check so I don't have to put another engine in the car. :)
Old 05-10-2009, 12:47 PM   #4
SGGilmo
Yay, Another Car.
no problem. i dont blame you.
SGGilmo is offline
Old 05-10-2009, 12:50 PM   #5
s_crowley 17
s_crowley 17's Avatar
sticky?
s_crowley 17 is offline
Old 05-10-2009, 12:58 PM   #6
sohclubkid
Sick 6/6
sohclubkid's Avatar
great post bro! i was about to try and explain the pressure gauge and using feeler gauges to check the pump... but you covered it all!
sohclubkid is offline
Old 05-10-2009, 01:14 PM   #7
SGGilmo
Yay, Another Car.
lol. honda service manual pdf files ftw
SGGilmo is offline
Old 05-11-2009, 03:35 PM   #8
krisma
Don't mean to hijack the thread, but I have an oil pressure issue that I would like to piggy back on this:
I recently did a head gasket/timing belt/water pump change. A day and half after completing the work and driving about 110 miles my oil pressure light came on while going about 65-70 mph/2800-3000 rpm. I quickly pulled off on the highway verified good oil quantity and nothing visually loose in the engine compartment.
After my checks I started the car and no light came on except for the startup light check. I proceeded home normally about another 28-30 miles and then the light started to flicker like crazy, shut off, flicker intermittently, then stayed on for the next 5-8 miles until I got home. Again, I shut the car off quantity still good. I had someone run the car while I wiggles all the wire harnesses then had them take it up to 3000 rpm ad did the same thing, but could not get the light to come on.
So... I went out and bought an analog direct read oil pressure gauge and installed it today 5-11-09, completely bypassing the pressure switch. I turned the car on and the gauge reads 75 psi at idle?!!!
Any thoughts on this high psi reading? Bad gauge from stock?
Car has 190,000 miles 1995 LX 1.5 ltr.
Thank you all!!
krisma is offline
Old 05-11-2009, 07:26 PM   #9
SGGilmo
Yay, Another Car.
wow. 75 psi is insane for idle. what was it at 3k? maybe a clog somewhere and the pump is trying to push it out with no luck. are you sure you put the head gasket on correctly? could be blocking one of the holes.
SGGilmo is offline
Old 05-12-2009, 12:00 AM   #10
krisma
well I learned something new! It turns out it's a viscosity issue. On a cold engine or one that has been shut down for a while these type of direct read analog gauges stay on the high side until the engine warms up.
It turns out that after a little while of running the engine the psi drops down to normal range on the gauge. After about 5 minutes idle was reading about 10 psi, 3k was about 58-62 psi (gauge doesn't give a lot of accurate increments). I did a series of quick on/off's after the engine was warm and it went to reading what manual specs call for. I then did about 3 on/off's giving the car about 30-45 minutes in between and I got the same high psi issue every time, but every time it also came down after a while.
Cheap gauge maybe, but more than like viscosity was the culprit. Hope this info helps others.
krisma is offline
new oil pressure gauge and oil filter sandwich adapter arod52388 Tech Archive (No Posting) 1 04-25-2009 01:03 AM
gauges,water,oil,oil pressure ek JdmB18C667 Parts for Sale 2 04-06-2008 11:05 PM
whats the easiest way to wire up a electric oil pressure gauge and fuel pressure? BseriesEG Interior / Audio / Electronics 3 07-18-2007 08:54 PM
Oil Pressure & Oil Temp Sensor Installation Bljacque Tech Archive (No Posting) 1 07-08-2007 04:42 PM
oil adapter for oil pressure sensor/turbo feed o0kuam0o Forced Induction 4 08-03-2005 12:26 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
