Search:
Welcome to ClubCivic
crankshaft position sensor... where is it located???
Responding Members:
User Tag List
Old 06-24-2009, 12:38 AM   #1
missle10
Default crankshaft position sensor... where is it located???
I have a Honda civic ex 1997 and I cannot find the crankshaft position sensor... I have no clue where it is at.
I need to replace it because a mechanic said it was the problem and i dont want to pay someone for something i can install myself.
so can anyone help me out? its a D16Y8 engine with vtec.
missle10 is offline   Reply With Quote
Old 06-24-2009, 12:41 AM   #2
missle10
Old 06-24-2009, 12:55 AM   #3
civic hatch
civic hatch's Avatar
if im right you have to remove the crank pully, remove the lower timing blet cover and you should see it on the crank.
I'm not African American, I wasn't born in africa. I'm just American
civic hatch is offline   Reply With Quote
Old 06-24-2009, 02:05 AM   #4
Szady
D-Series Master
Szady's Avatar
Take the crank pulley off, remove the lower timing cover, and its bolted to the oil pump housing by 1, 10mm bolt.
Szady is offline   Reply With Quote
Old 06-24-2009, 12:11 PM   #5
jlicrx
jlicrx's Avatar
the crankshaft position sensor (CKP) on the D16Y8 is inside the distributor - the sensor on the front of the crankshaft behind the pulley is the Crankshaft Speed Fluctuation Sensor (CKF) - not the same thing
ZCspeed Racing
jlicrx is offline   Reply With Quote
Crankshaft Position Sensor problem (p0335) massasshadows Engine Tech / Drivetrain 1 06-18-2011 12:56 PM
Crankshaft Position Sensor Problems... Please Help! vcantrell Engine Tech / Drivetrain 2 08-15-2010 10:47 PM
b20 crankshaft position sensor?? EK Devil Engine Tech / Drivetrain 6 08-11-2010 11:01 AM
Crankshaft Position Sensor SilverEXCoupe Engine Tech / Drivetrain 10 09-05-2008 11:39 PM
crankshaft position sensor questions... lownslow Engine Tech / Drivetrain 7 02-09-2008 12:32 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
