Idle goes up and down! HELP!
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 07-02-2009, 09:08 PM   #1
EK Devil
EK Devil is on a distinguished road
Default Idle goes up and down! HELP!
My civic just started to do that about a few weeks ago and I'm trying to figure how to fix the problem...when the car warms up and when i come to a stop light, it idles up and down....how do i fix that? and where is the IACV and idle screw located at? pics will be helpful. thanks
EK Devil is offline
Old 07-02-2009, 10:09 PM   #2
EJAaron
EJAaron is on a distinguished road
maybe you have a vacuum leak somewhere
EJAaron is offline
Old 07-03-2009, 10:19 PM   #3
Flatblack-Hatch
Flatblack-Hatch is on a distinguished road
It sounds like an ics (idle control sensor) problem. the screw to tune it should be right on the throttle body.
Flatblack-Hatch is offline
Old 07-08-2009, 07:27 PM   #4
Kay@NHT
Kay@NHT is on a distinguished road
yea i would say IACV you can pick one up cheap ... i remember seeing a DIY clean it out online let me see if i can find it for you
Kay@NHT is offline
Old 07-09-2009, 12:06 AM   #5
blue88civic
blue88civic's Avatar
blue88civic is on a distinguished road
Most likley IACV
blue88civic is offline
Old 07-09-2009, 12:54 AM   #6
haftahonda
haftahonda's Avatar
haftahonda is on a distinguished road
sometimes its just low coolant or also a coolant temp sensor. do you have a check eng lite?
haftahonda is offline
Old 07-13-2009, 05:49 AM   #7
89y49rexsi
twinke team bio
89y49rexsi's Avatar
89y49rexsi is on a distinguished road
x2
check your coolant sensors the one you need to check is the 2 pin under the dizzy
also what motor do you have if its the dual point then i have no idea cuz i hate that motor myself
but if its a d16a6 then i beleive the screew that you would need to tighten is on the bottom of the throttle body
too bad its not a b16 i know that s*** inside out lol
my ed sedan build up thread http://www.clubcivic.com/board/showt...82#post2647082
89y49rexsi is offline
Old 07-13-2009, 06:32 AM   #8
fusion
fusion's Avatar
fusion is on a distinguished road
depending on the motor you have you can either have a rotary or a linear IACV. If its a rotary you are screwed and there is no way to clean it. A rotary IACV will be greenish in color and mount on the backside of the intake manifold and youll understand what i mean by rotary when you pull it off. however if you have a linear IACV, it will be located on the backside of your intake manifold held on by 2 bolts. Just pop it off, spray it down with some Simply Green, let it dry, mount it back up and your car will stop surging.
97 EJ8 b16a boosted
95 240sx sr20det
96 EK B16A daily mobber
95 db7 teg
fusion is offline
Old 07-13-2009, 06:43 AM   #9
zoomoutt
projectEFstd
zoomoutt's Avatar
zoomoutt is on a distinguished road
i have the same problem,
i was told to just clean the iacv with some simple green.
depending on where yours is.
Mines is located right next to the dpfi.
i know i know,lame ass dpfi.
im low on green,sorry no money for a swap.only on cosmetic mods.
soon though soon.
heres a great link....
http://www.honda-tech.com/showthread.php?t=2443124
http://www.honda-tech.com/showthread.php?t=1575913
91 EF STD HB RED,BONE STOCK.
zoomoutt is offline
Old 07-13-2009, 08:46 AM   #10
Jersey8
B20: Detroit Muscle!
Jersey8's Avatar
Reputation level: 25
Jersey8 is on a distinguished road
my vote goes to iacv
Jersey8 is offline
Old 07-14-2009, 02:31 AM   #11
kwell
kwell is on a distinguished road
idle set to high... thats what i say but i havent had a iacv in a long time
kwell is offline
Old 07-16-2009, 02:53 AM   #12
TheEf2kid
TheEf2kid's Avatar
TheEf2kid is on a distinguished road
does your car idle perfect after its warm?
TheEf2kid is offline
Old 07-25-2009, 04:12 PM   #13
copliesflip
copliesflip is on a distinguished road
My car has a very similar problem. I have a EG8 with the stock d15 and when i start it up the idle goes up to about 3,000 rpm and then after awhile it will go back down to around 2,000 to 1,500 rpm. I followed the procedure to adjust the the idle speed with the screw but as soon as it starts to drop something causes the idle to go up so that it stays at 1,500 rpm. What should I do next? I looked at the local Honda dealer and auto parts store and they want like $200 for the IAC valve and i dont want to pay that, especially if im not sure that is the problem.
copliesflip is offline
Old 02-06-2011, 01:07 AM   #14
dahansen2000
dahansen2000 is on a distinguished road
Default IACV repair
As a car dealer I've had several Civics that had the idle go high and then low after being warmed up. The latest was a 97 Civic DX. To solve the problem, I removed the throttle body, removed the IACV from the throttle bottle, then I unscrewed both ends of the IACV. With the shaft exposed, I was unable to easily rotate the shaft. I sprayed some Powerlube on both ends and worked the shaft back and forth by hand. After a while it freed up with just a little resistance. I replaced the end pieces and then reinstalled the throttle body. It had one up and down cycle, and then settled in and idled perfectly. It was quite a relief to solve the problem so inexpensively. Before doing this I had replaced the IACV with another one I had from another engine. It did the same thing. This, I would guess, is a common problem, especially with engines that may sit for a while unused, which both of these engines had.
DH
dahansen2000 is offline
Old 02-06-2011, 01:37 AM   #15
darksolderx
darksolderx is on a distinguished road
http://www.youtube.com/watch?v=L788jKEVblY - this video MAY help you with idle problem
http://www.youtube.com/watch?v=9CPqbaSgcok - this mite help you figure out if its a vacuum leak
darksolderx is offline
low idle cold start high idle when warm 00civick_si Engine Tech / Drivetrain 3 05-20-2011 01:02 AM
low idle cold start high idle when warm 00civick_si Engine Tech / Drivetrain 1 05-19-2011 06:25 PM
high idle, low idle, high idle, low idle.... jkcivic Tech Archive (No Posting) 7 09-13-2009 11:55 PM
Idle help 96civ Engine Tech / Drivetrain 2 02-11-2008 05:53 PM
Recharged A/C, now idle fluctuates at idle. br0nx finest Engine Tech / Drivetrain 4 05-29-2006 12:42 PM
