Search:
Welcome to ClubCivic
main bearings
Responding Members:
User Tag List
Old 07-04-2009, 07:29 PM   #1
TiiM iiS l3eAsT
Scamming Piece Of s***
Default main bearings
ok well i found out i have spun 3 main bearings....
i know the crank isnt good...
now i was wondering....what about the top main bearings ?? where the crank is still holding them in....are those gonna be messed up to ??
also what is the best way to find out main bearing sizes ??
i know plastiguaging for the rod bearings....but what about the main bearings ??
ALSO....
can the crank come out without taking out the engine ??
i know transmission has to come out....but what about the engine ??
i dont really feel like taking the engine out again...so if there is a easier way to do this then let me know !!
WARNING
I am a low life scamming piece of s***... So pathetic and broke that I have to STEAL from others.. I am actually SUCH a low life that I take pride in this behavior..
TiiM iiS l3eAsT is offline   Reply With Quote
Old 07-04-2009, 09:34 PM   #2
31dev31
Chillin' Canadian Member
31dev31's Avatar
You can pull out the tranny, then pull the crank from underneath with the engine still in the car, but you'd have to remove the head so that you can correctly install the crank afterwards. I believe the front and rear mounts can support the engine while the driver and passenger mounts can come out, but you should support the engine from the top anyways.
To find out the bearing sizes, you can measure the diameter of the bearing races on the crank.
Plastigauging is only to verify proper torquing and ensuring the job was done properly.
2004 Ford Ranger EDGE - 4.0 V6, 4x4, 4:10 LSD
Click for HID Projector Retrofit DIY
Click for EG6 Inspiration Blog
31dev31 is offline   Reply With Quote
Old 07-04-2009, 10:20 PM   #3
Szady
D-Series Master
Szady's Avatar
Pull the tranny, somehow support the engine (w/out the tranny there to hold it up, you somehow need to support it, b/c the rear mount isnt there anymore so your left with just the drivers side mount), then you can pull the crank out. Honestly, I would just pull the entire engine out. It'll be 10000x easier to measure for new bearings and install everything again.
As far as measuring for new main bearings, you measure the same way you would for rod bearings, with a plastiguage. If the upper main bearings (ones in the block portion) look good and are still within spec, leave them. But, then agian, if your replace 1/2 of them, might as well replace all of them at once.
Szady is offline   Reply With Quote
Old 07-05-2009, 03:07 PM   #4
TiiM iiS l3eAsT
why would i have to remove the head to install the crank lol ??
WARNING
Old 07-05-2009, 11:29 PM   #5
31dev31
31dev31's Avatar
So that you can move the pistons to bolt on the connecting rods to the crank.
Old 07-05-2009, 11:36 PM   #6
cheezeonmakneez
love unicorns
cheezeonmakneez's Avatar
You know that the pistons can move if you push/pull from the bottom right?
Originally Posted by Destroy View Post
The next useless thread you post I'm gonna pm you a pic of my hairy asshole.
Originally Posted by Wit tuning View Post
Mugen GTR: I want to make a new style)
Originally posted by ej8arm lol im tellin you people just get dumer by the day!!!!
cheezeonmakneez is offline   Reply With Quote
Old 07-06-2009, 02:09 AM   #7
TiiM iiS l3eAsT
lol thats what i was thinking ....
WARNING
Old 07-06-2009, 03:16 AM   #8
PhntmSk8r
H23VTEC
Idea:
Dont be lazy and just pull the motor. If you just work on it, and get it done instead of trying to avoid it you'll save yourself the headache of trying to do s*** upside down, and working in a confined space. Plus if you have to drop the tranny, and pull the head... you might as well just pull the motor. Makes it a s*** load easier to work on
two people (you and a buddy) should very easily be able to pull a single cam in 60-90min without any problems.
Im a little confused as to what you're asking about with the 'top of the bearing' holding the crank in?
If the bearing actually spun, the top piece will be welded/melted to the bottom piece (assuming its even still in there) and it also likely chewed up the journal on the block and in the main caps, which also means you should absolutely pull the motor and take it to a machine shop. You'll likely have to get slightly oversized bearings once they fix the chewed up journals.
ALL MOTOR H23 VTEC POWERED EJ8
PhntmSk8r is offline   Reply With Quote
Old 07-06-2009, 02:38 PM   #9
TiiM iiS l3eAsT
well heres pics of the bearings...
crank:
main bearings:
WARNING
Old 07-06-2009, 03:05 PM   #10
PhntmSk8r
H23VTEC
looks to me like you over torqued the girdle and didnt do it in the right sequence. Something is not right, if you spun the bearings the two parts of them would be welded together as one (most likely)
Old 07-06-2009, 08:10 PM   #11
cheezeonmakneez
love unicorns
Just get some superglue and call it a day
Old 07-07-2009, 02:28 AM   #12
TiiM iiS l3eAsT
not sure.... i didnt assemble the motor together..... i gave all the parts to my builder which is an excellent stock honda builder....but im not to sure if hes good with high performance....i think he made the clearances too tight.....but im not sure ....
but ya he assembled the motor....then i put it back in the car lol...
WARNING
Old 07-07-2009, 01:19 PM   #13
daniel86
Great set of pictures.
Easy Number Plates - Road Legal & Custom/Show Number Plates
http://www.easynumberplates.co.uk
daniel86 is offline   Reply With Quote
Old 07-07-2009, 03:21 PM   #14
PhntmSk8r
H23VTEC
Clearances are clearances. Wont matter if its 'performance' or 'stock'
From what i've seen some of the all motor/turbo guys usually go for the tighter end of spec if possible.
Maybe yours were at the tighter end, then he over torqued the girdle? not sure...
Thats why you should always build it yourself, then you know what you did wrong and can learn from it
Old 07-07-2009, 03:37 PM   #15
Szady
D-Series Master
Szady's Avatar
Need help with main and rod bearings c_osorio Tech Archive (No Posting) 16 07-28-2010 06:15 PM
b16a main/rod bearings? hyphy88hatch Tech Archive (No Posting) 4 05-09-2008 01:44 AM
TOGA rod/main bearings rupesh52 Engine Tech / Drivetrain 1 08-07-2007 05:56 AM
***rod & main bearings*** silver booolet Engine Tech / Drivetrain 7 07-05-2007 11:41 PM
F.S. Brand New ACL Main Bearings accordy2g Parts for Sale 4 07-07-2006 10:00 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
