Search:
Welcome to ClubCivic
extremely hot lug nuts = ?
Responding Members:
User Tag List
Old 09-09-2009, 06:22 PM   #1
JohnS.
BANGARANG
JohnS.'s Avatar
Default extremely hot lug nuts = ?
I was taking my front lip off today and the back of my hand touched a lug nut (driver side) and I immediately backed it off. It was hot as hell. I couldn't even touch it for more than a second without pulling away. I didn't touch any of the other wheels but I'll try to remember later when I get to class.
I just replaced the rotors and pads not even 5000 miles ago. Could it be a bad caliper? How do you test for a bad caliper? I also read that it could be a bad wheel bearing. But my car doesn't vibrate or make noises when turning. It pulls slightly to the left. I got an alignment done 2 months ago back when I had bald front tires. It drove straight as an arrow after it. Then I got new front tires and it pulled slightly to the left.
I can't afford to have my car in the shop for a day since it's my only car and I work every day and don't even have a bike to ride to work. Any ideas?
Questions / comments / concerns? Feel free to PM me.
New to ClubCivic? Click Me!!!
JohnS. is offline
Old 09-09-2009, 06:48 PM   #2
Esotericimage
Try GOOGLE 1st
its heat soak from the rotors.. if its hot, dont touch it!
Esotericimage is offline
Old 09-09-2009, 06:50 PM   #3
31dev31
Chillin' Canadian Member
31dev31's Avatar
How long were you driving the car before this happened?
This will help determining if it's normal or it could be a seized caliper.
2004 Ford Ranger EDGE - 4.0 V6, 4x4, 4:10 LSD
Click for HID Projector Retrofit DIY
Click for EG6 Inspiration Blog
31dev31 is offline
Old 09-09-2009, 06:55 PM   #4
mixwell
no mention about bad bearings being a culprit? is it the same on the other side?
mixwell is offline
Old 09-09-2009, 06:55 PM   #5
JohnS.
BANGARANG
JohnS.'s Avatar
So hot lug nuts is a normal thing? How do you tell the difference between a hot lug nut caused from a bad wheel bearing / seized caliper from a hot lug nut from heat soak?
Hmm... Maybe a half hour, city driving (not heavy stop and go, but some).
Like I said, I forgot to check the other side when I touched the driver side. I'll try to remember to touch the other 3 wheels when I get to class later. It's about a 20 minute drive.
JohnS. is offline
Old 09-09-2009, 06:59 PM   #6
projektej8
projektej8's Avatar
I gues if they are made out of a pretty heat conductive metal, it would just be heat soak from the brake system. The lug nuts are always hot when we take them off at work, if the cars been driven.
projektej8 is offline
Old 09-09-2009, 07:10 PM   #7
Jbuck2KCivic
Jbuck2KCivic's Avatar
I blame it on the steelies, and the tires probably had something to do with it as well. My vote goes for replacing with new wheels/tires and...problem solved! lol
Jbuck2KCivic is offline
Old 09-09-2009, 07:24 PM   #8
Szady
D-Series Master
Szady's Avatar
Its just b/c your azn John. Thats your problem, you know.
Szady is offline
Old 09-09-2009, 07:34 PM   #9
31dev31
31dev31's Avatar
And your car has a slight pull to the left (driver's) side?
Might need to get your brakes looked at. If you want to do it yourself: Take your brake caliper off, use a large channel locks and see if the caliper piston will go back in it's bore.
31dev31 is offline
Old 09-10-2009, 11:49 AM   #10
Billy.
Has returned ;-)
Billy.'s Avatar
its probably heat soak from the brakes. but if you want to check the bearing just jack up that corner of the car so the tire is completely off the ground, then spin the wheel and listen. if it sounds like its grinding then the bearing is probably bad. make sure youre not hearing the brake pad sliding on the rotor though - completely different noise. also the wheel should turn relatively freely and not come to an abrupt stop when you let it go
iTrader Profile
Billy. is offline
Old 09-10-2009, 11:55 AM   #11
obracer12
obracer12's Avatar
I had a caliper "hyper extend" on me and lock shut.. melted the hub cap right off the steelie... thankfully it was a rental car and i didn't have to deal with it lol..
I suggest taking it for a regular drive, and comming back home, and going to all 4 corners to see if they are all hot.. if so heat soak, if not and only that corner coupled with the pull to that side I'd sat it was your caliper, or it not retracting when you get off the brake.. did you grease your pins when you did your break pads?
***Image removed do to corrupt file. Please relink***
Originally Posted by JerseyKid View Post
my spark is being a guido and blowing out.
Originally Posted by White Boy View Post
Most of the time, sooner or later, most get a soft spot for a civic's.
South NJ club start up PM ask Q's
obracer12 is offline
Old 09-10-2009, 02:26 PM   #12
JCCLARK
The Painter
JCCLARK's Avatar
Try spinning your wheel when up on a jack, I'll be your
brake callipers are binding.
This is exactly why people have brakes that don't last very long, they never clean out their calipers
and eventually they stop releasing, from all the dirt and water buildup.
I've seen them so tight I couldn't turn the tire by hand.
Most shops just replace the caliper, but a good cleaning is all that's needed.
You have to remove the piston and clean it all out.
you'd be surprised at the crud I've seen.
JC
JCCLARK is offline
Old 09-11-2009, 02:43 AM   #13
matt2122
it's a pretty common thing, i wouldn't worry too much about it. if the car tends to pull to the left or right while braking that is usually indicitive of a brake issue, also steering wheel shaking under braking is an indication. last time i toasted a rotor was on my dodge truck.....got a rock stuck between the rotor and pad, pretty ugly. left about a 20mm gouge around the diameter of the rotor
matt2122 is offline
Old 09-12-2009, 04:05 AM   #14
Esotericimage
Try GOOGLE 1st
thread closed!
2002 civic lx engine bay extremely hot xXJDMEM2Xx Engine Tech / Drivetrain 0 02-23-2011 10:00 PM
Lug Nuts TarunVerma Wheels / Tires / Brakes / Suspension 1 01-25-2011 01:37 AM
Lug Nuts civicnc Tech Archive (No Posting) 5 07-22-2008 10:07 AM
Close Ended Lug Nuts Vs Open Ended Lug Nuts mhi Wheels / Tires / Brakes / Suspension 17 03-15-2007 02:10 PM
lug nuts. EatingYourBrainsY0 Wheels / Tires / Brakes / Suspension 3 07-03-2004 09:30 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
