Search:
Welcome to ClubCivic
95 civic having starting problems??
Responding Members:
User Tag List
Old 10-06-2009, 02:54 PM   #1
JdmPrncss
I ♥ NYGraFFit :)
JdmPrncss's Avatar
Question 95 civic having starting problems??
I'm new to this site and very sorry if I am posting this in the wrong section... But I've been having a problem when I go to start my car and my boyfriend and I can not figure out what is wrong with it, we have checked and changed stuff which seems to fix it but then it starts doing it again...
The car is an automatic and when I go to start my car it will start up then cut right off unless I hit the gas. It does not do this all the time, its just kind of random when it does it. Does any one have any suggestions of what could be causing this?? Any help would be great!!
Thanx :)
JdmPrncss is offline
Old 10-06-2009, 04:10 PM   #2
SGGilmo
Yay, Another Car.
any cel codes? (check engine light codes)
Originally Posted by BULL3TPR00F View Post
well i managed to get it in i just had to jiggle it like crazy back and forth while smashing it in over and over again
94 Grand Am 86 Cougar 95 Civic EX eh9 90 PreludeSI
91 Integra LS 94 Civic EX ej1 92 Prelude si 89 Mighty Max
92 Mighty Max 4x4 v6 89 FZR600 06 GSXR750 93 Miata
01 Miata 09 R6s 07 CBR600RR 00 Dakota 92 Civic LX eg8
SGGilmo is offline
Old 10-06-2009, 04:23 PM   #3
JdmPrncss
I ♥ NYGraFFit :)
JdmPrncss's Avatar
No it's not throwing any codes at all! We replaced my fuel pump, ignition wires, and the distributor. And all seem to "fix" the problem then a week or two later it starts doing it again.
Old 10-13-2009, 07:49 PM   #4
lethal6
Doh!!
lethal6's Avatar
Sounds like a bad or semi bad main relay. If it is going bad it will intermittently cut in and out. Trust me, I just went through it. 7 out of 10 times it wouldn't start. Replaced the main relay and haven't had a problem since.
Btw the main relay is under the dash by the interior fuse panel, bolted just behind the bottom where your left knee faces. From what I read it has 2 relays in it, 1 controls the fuel pump and 1 controls the injectors.
lethal6 is offline
Old 10-13-2009, 08:06 PM   #5
psychotic_civic
Guest
Posts: n/a
x2...replace the main relay. your problem will go away. this is a common problem with 5th gen civics
Old 10-14-2009, 12:45 PM   #6
JdmPrncss
I ♥ NYGraFFit :)
JdmPrncss's Avatar
Thanks guys!! I'll try that :)
Old 03-04-2010, 09:49 AM   #7
Germanican
Hi, I'm new to this site and got a problem with our '95 Civic DX Coupe.
I don't know a lot about cars, so please forgive me for wrong terms or asking stupid questions :-)
If this doesn't fit in here, please feel free to split it and move it to the right area. :-)
Couple weeks ago we had a snowstorm and I was going to start the car. I started, but it shut of after 2 sec. or so. Tried to start it again and it wouldn't go and it smelled burnt on the driver side. A friend of ours checked the car, cause we had to get a new starter in, since the old one had a crack and was loose. Our friend also changed the fuel filter. I have to say, the previous owner of the car didn't do a lot on the car, just the minimum (oil change, new brakes and that's it)
When key is on II the CEL comes on for 2 sec and turns off, I think I can hear the fuel pump prime for about 2 -3 sec and then I hear a click. If you turn the key all they way it will crank, but not start.
And also the A/C is not working. Previous owner said it has a leak, cause she got it charged and the next day all was gone. So is it hard/expensive to get a new A/C put in?
Thanks for your help
Germanican is offline
Old 03-04-2010, 01:56 PM   #8
^^^Check for spark. Click Spark link in my signature.
RonJ is offline
Old 03-04-2010, 03:13 PM   #9
Germanican
Thanks RonJ. Will tell my friend and a friend of his to check that.
1998 hoda civic ex starting problems lavertue24 Engine Tech / Drivetrain 4 04-26-2011 11:10 PM
2006 Civic EX starting problems JohnS. 8th Generation Honda Civic (2006-2011) 4 01-17-2011 07:23 PM
93 Civic Problems Starting 93EGcp Engine Tech / Drivetrain 2 08-18-2010 08:24 AM
92 Civic Si starting problems armybiker01 Tech Archive (No Posting) 15 09-07-2009 04:42 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
