Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic Technical > Engine Tech / Drivetrain > Engine Tech / Drivetrain Tech Archive / How To's
How To: Timing Belt D16Y5, D16Y7, D16Y8
Closed Thread
Old 02-24-2004, 03:33 PM   #1
NOFX
I'm NOT eran!
NOFX's Avatar
Car: :
View/Rate My Garage
Default Timing Belt - D16Y5, D16Y7, D16Y8
Okay, this was taken directly out of the Honda Civic ('96-'00) & CR-V ('97-'00) / Acura Integra ('94-'00) Haynes Repair Manual. This info is from Chapter 2 Part A - Single overhead cam (SOHC) engines. I am not to be held accountable for any problems or mistakes which might occur.
Timing Belt and Sprokers - Removal, Inspection and Installation
Removal
Refer to illustrations 10.11, 10.13, 10.17, an 10.18
1 Disconnect the cable from the negative terminal of the battery. Caution: If the radio in your vehicle is equipped with an anti-theft system, make sure you have the correct activation code before disconnecting the battery.
2 Place blocks behind the rear wheels and set the parking brake.
3 Loosen the lug nuts on the left front wheel and raise the front of the vehicle. Support the front of teh vehicle on jackstands (see Chapter 1).
4 Remove the left front wheel and remove the splash sheild from under the engine.
5 Support the engine with a floor jac. Place a wood block between the jac pad and oil pan to avoid damaging the pan.
6 Remove the upper left engine mount bracket (see Section 18 ).
7 Remove the spark plugs and the engine drivebelts (see Chapter 1).
8 Unbolt the power steering pump qithout disconnecting the hoses and set it aside (see Chapter 10).
9 Remove the engine oil dipstick.
10 Position the number one piston at Top Dead Center (see Section 3). Caution: Always rotate the crankshaft counerclockwise (viewed from the pulley end of the engine). Clockwise rotation may cause incorrect adjustment of the timing belt.
11 Remove the upper timing belt cover (see illustration).
12 Remove the drivebelt idler pulley and bracket from the front of the engine.
13 Using a strap wrench or chain wrench to hold the crankshaft pulley bolt with a socket and breaker (see illustration).
14 Slip the pulley off the cranshaft.
15 Remove the dipstick tube from the front of the engine.
16 Remove the lower timing belt cover.
17 If you intend to reuse the timing belt, use white paint of chalk to make match marks to align the sprockets with the belt and an arrow to indicate the direction of rotation (see illustration).
18 Loosen the timing belt tensioner bolt (see illustration). Push on the tensioner to release the tension on the belt, then retighten the bolt. Remove the crankshaft fluctuation sensor and slip the belt off. If you're replacing the crankshaft oil seal, slip the sprocket and inner belt guide off the crankshaft (see Section 11).
19 If you're replacing the camshaft or camshaft oil sel, slip a large screwdriver through the camshaft sprocket to keep it from rotating and remove the bolt, then pull off the sprocket. Also remove the Woodruff key.
Inspection
Refer to illustrations 10.20 and 10.21
20 Rotate the belt tensioner pulley by hand and move it from side-to-side, checking for play and rough rotation (see illustration). Replace it if roughness or play is detected.
21 Check the timing belt for wear (especially on the thrust side of the teeth), cracks, splits, fraying and oil contamination (see illustration). Replace the belt if any of these conditions are noted. Note: Unless the engine has very low milage, it's common practice to replace the timing belt with a new one every time it's removed. Don't reinstall the origiunal belt unless it's in like-new condition. Never reinstall a belt in questionable condition.
Installation
Refer to illustrations 10.23, 10.24 and 10.25
22 If you removed the sprockets, reinstall them. Don't forget the Woodruff key for the camshaft sprocket and the inner belt guide for the crankshaft sprocket. Tighten the camshaft sprocket bolt tothe torque listed in this Chapter specifications.
23 Before installing the timing belt, make sure the dot ot "UP" mark on the camshaft sprocket is at the top and the two index marks are in line with the cylinder head and face (see illustration).
24 Temporarily reinstall the crankshaft pulley and bolt and turn the crankshaft (if it was disturbed) until the timing mark on the crankshaft sprocket and the pointer on the oil pump are aligned (see illustration).
25 Install the timing belt tightly around the crankshaft sprocket, then around the tensioner pulley, water pump pulley and camshaft sprocketin sequence (see illustration).
26 Loosen the belt tensioner bolt, allowing the tensioner to tension the belt, then temporarily tighten the bolt.
27 Carefully turn the crankshaft counterclockwise six revolutions and recheck the timing marks and camshaft sprocket index mark for poor alignment. If the crankshaft binds or seems to hit something, do not force it, as the valves may be hitting the pistons. If this happens, valve timing is incorrect. Remove the belt and repeat the installation procedure and verify that the installation is correct.
28 To properly tension the timing belt, loosen the tensioner bolt 1/2 turn (180-degrees), rotate the crankshaft counterclockwise until the camshaft pulley is three teeth past TDC and tighten the tensioner bolt to the torque listed in this Chapter's specifications.
29 Reinstall the remaining parts in the reverse order of removal.
30 Refer to Chapter 1 and adjust the drivebelts.
31 Run the engine and check for proper operation.
One thing after another making me want to leave the entire Honda scene.
[OEM 98 Discontinued Rear Lip #0009]
[OEM 98 Discontinued Front Lip #0001]
NOFX is offline
Old 02-24-2004, 03:34 PM   #2
NOFX
I'm NOT eran!
NOFX's Avatar
Car: :
View/Rate My Garage
Here are the specifications listed for that chapter.
General
Firing order............................................. ......1-3-2-4
Cylinder numbers (front to rear).......................1-2-3-4
Bore.............................................. ...............2.95 inches
Stroke............................................ ..............3.54 inches
Displacement...................................... ..........97.0 cubic inches (1.6liters)
Camshaft
Endplay
.....Standard..................................... ..............0.002 to 0.006 inch
.....Maximum...................................... ............0.020 inch
Lobe height
.....D16Y5
..........Intake
...............Primary............................ ..............1.5129 inches
...............Secondary.......................... ............1.2674 inches
..........Exhaust................................. .............1.5269 inches
.....D16Y7
..........Intake.................................. ...............1.3897 inches
..........Exhaust................................. .............1.4678 inches
.....D16Y8
..........Intake
...............Primary............................ ..............1.4479 inches
...............Secondary.......................... ............1.5068 inches
..........Exhaust................................. .............1.4964 inches
Runout
.....Standard..................................... .............0.001 inch
.....Service limit............................................. 0.002 inch maximum
Journal oil clearance
.....Standard..................................... .............0.002 to 0.004 inch
.....Service limit............................................. .0.006 inch maximum
Oil pump
Rotor-to cover clearance
.....Standard..................................... .............0.001 to 0.003 inch
Tooth tip clearance
.....Standard..................................... .............0.001 to 0.006 inch
.....Service limit............................................. .0.008 inch maximum
Outer rotor-to-pump body clearance
.....Standard..................................... .............0.004 to 0.007 inch
Torque specifications
Camshaft bearing cap bolts
.....6 mm bolts............................................. ....104 in-lbs
.....8 mm bolts............................................. ....14
Camshaft sprocket bolt.....................................27
Cransshaft fluctuation sensor mouonting bolt......104 in-lbs
Crankshaft pulley bolt.......................................130
Cylinder head bolts
.....Step 1................................................. .......14
.....Step 2................................................. .......36
.....Step 3................................................. .......49
.....Step 4................................................. .......49
Driveplate-to-crankshaft bolts.............................54
Intake manifold nuts..........................................17
Exhaust manifold-to-cylinder head nuts...............23
Exhaust pipe-to-manifold nuts
.....D16Y5, D16Y7............................................. 25
.....D16Y8........................................ .................40
Exhaust manifold upper heat shield bolts.............17
Exhaust manifold lower heat shield bolts
.....D16Y5, D16Y7............................................. .96 in-lbs
Flywheel-to-crankshaft bolts................................87
Oxygen sensor............................................ .......33
Oil pressure switch............................................ .156 in-lbs
Oil pan drain plug
.....D16Y5, D16Y8............................................. ..29
.....D16Y7........................................ ...................33
Oil pan-to-engine bolts.........................................104 in-lbs
Oil pump pick-up tube to pump housing buts..........96 in-lbs
oil pump pick-up screen-to-main bearing cap..........96 in-lbs
Oil pump housing-to-block bolts............................96 in-lbs
Oil pump cover-to-housing....................................60 in-lbs
Rear main oil seal housing bolts...........................96 in-lbs
Timing belt cover bolts.........................................86 in-lbs
Timing belt tensioner bolt.....................................33
Valve cover botls............................................. ....86 in-lbs
VTEC lock-up solenoid bolts................................104 in-lbs
Water pump bolts............................................. ..104 in-lbs
NOFX is offline
Old 02-24-2004, 03:37 PM   #3
Shiznit
Stickin it to the Man
Shiznit's Avatar
Car: 2000 Civic Si
Power: 142.2 HP
View/Rate My Garage
damn thats complicated.
[ EM1 Crew ] [ CCCC #0215 ] [ vB Garage ] [ CC Night Crew #0021 ]
WTB: 99-00 Si Driver side front lower control arm
Shiznit is online now
Old 02-24-2004, 03:44 PM   #4
NOFX
I'm NOT eran!
NOFX's Avatar
Car: :
View/Rate My Garage
That's why I'm having one of the guys at Honda do it for me.
NOFX is offline
Old 02-24-2004, 04:11 PM   #5
anfrey
ɹǝƃuoɯǝɔɐǝd ƃo
anfrey's Avatar
Car: ɐpƃ ɯsd
Power: 227 HP / 217 TQ
View/Rate My Garage
damn, that seems like a royal pain in the ass
"non impediti ratione cogitationis" - conloquium currus
set the gearshift for the high gear of your soul... you've got to run like an anfelope, out of control!
"government big enough to supply everything you need is big enough to take everything you have.
the course of history shows that as a government grows, liberty decreases."
-thomas jefferson
anfrey is offline
Old 02-26-2004, 03:53 PM   #6
Jas0n
What's up dogz!!!
Jas0n's Avatar
Car: 95 Civic Coupe
View/Rate My Garage
yes!!!!!!!!!!
Jas0n is offline
Old 03-03-2004, 11:34 PM   #7
Bobo_686
Shiny things amuse me
Bobo_686's Avatar
Car: 98 Prelude SH
View/Rate My Garage
oh god, it is...trust me, heh, had to do one on a 94 accord...my god, it took many many hours and and many many drinks 2 find out how 2 do it, lol
5th gen BB6 h22a
Bobo_686 is offline
Old 03-03-2004, 11:35 PM   #8
mugen00
American Honda=Domestic
mugen00's Avatar
Car: 05 DC5
View/Rate My Garage
im confused!!
mugen00 is offline
Old 03-03-2004, 11:37 PM   #9
9civic7
Gold Member
Car: 97 Civic Dx
View/Rate My Garage
t-belts aren't that hard on SOHC Hondas i am going to do mine in a couple months
9civic7 is offline
Old 03-03-2004, 11:59 PM   #10
NOFX
I'm NOT eran!
NOFX's Avatar
Car: :
View/Rate My Garage
Now with pics!
NOFX is offline
Old 06-09-2004, 11:39 AM   #11
importlegions
1 god, 1 life,1 choice
importlegions's Avatar
Car: gudbye2thehatch, now a 98 lude
View/Rate My Garage
well, im goining to do this today hopefully, thanks for the help
importlegions is offline
Old 06-09-2004, 03:32 PM   #12
Zak8022
Titanium Member
Car: Zenki Civic
View/Rate My Garage
sohc engines are easy. i did mine last year. the hardest part was breaking the crank bolt loose. oddly enough air tools wouldnt do it.. but a big ass 3 ft breaker bar would. hehe.. that took all of 3 seconds to break it loose. just take your time, its fairly straight forward. if you do things right, and dont move shit once you take the old TB off, you shouldnt have to worry about timing. i think it took me and a friend about half a day once we were able to get the crank bolt off.
Zak8022 is offline
Old 06-09-2004, 04:18 PM   #13
NOFX
I'm NOT eran!
NOFX's Avatar
Car: :
View/Rate My Garage
Mike's air tools took mine off. Mostly what he uses it seems. I remember lots of noise..... lol
NOFX is offline
Old 06-09-2004, 04:50 PM   #14
Zak8022
Titanium Member
Car: Zenki Civic
View/Rate My Garage
heh.. yea. well the air tools we were using were not professional quality. the tank and compressor were sufficient, but the actual gun wasnt rated that high. im sure higher grade air tools, sich as what i would imagine mike would have (or have access to) would definately do the trick.
Zak8022 is offline
Old 06-09-2004, 05:25 PM   #15
Mr. Lin
whydoscrubsgetdows?
Car: vbp
Power: enough HP / enough TQ
View/Rate My Garage
Gargh... mine better not do anything stupid any time soon...
Mr. Lin is offline
Closed Thread
vB code is On
ClubCivic.com Merchandise Free Overnight Shipping on Competition Clutch Products Save on AEM UEGO Widebands Skunk2 Camber Kit Sale
Find this site helpful? Donations are appreciated.
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Forum SEO by Zoints
