98 LX: Power lock problem & do I have keyless entry?
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 10-21-2009, 03:23 PM   #1
nickenumbers
nickenumbers is on a distinguished road
Lightbulb 98 LX: Power lock problem & do I have keyless entry?
My 1998 Honda Civic LX automatic door locks stopped working this past weekend.
I do not have the key-less entry, just the power door locks.
Is the Control box in the driver side door?
I was thinking about buying an after market key-less entry system and just swapping out the old control box with the new key-less entry box. Do you guys think that would work?
Also, how do I rule out the driver door lock/unlock switch?
Thank you.
nickenumbers is offline
Old 10-21-2009, 04:33 PM   #2
Civic minded
RonJ's Avatar
Reputation level: 137
RonJ will become famous soon enoughRonJ will become famous soon enough
What exactly is the problem?
The keyless receiver for your Civic would be located in the stock radio. If you have the stock radio, then you just need a remote.
RonJ is offline
Old 10-21-2009, 04:35 PM   #3
nickenumbers
Old 10-21-2009, 04:42 PM   #4
Civic minded
RonJ's Avatar
Is fuse 51 under the hood blown?
Just curious, how do you know that your Civic does not have the keyless system?
RonJ is offline
Old 10-21-2009, 04:48 PM   #5
nickenumbers
Fuse 51 under the hood is not blown. Good question.
I do not know that I do not have the keyless sytem if it was installed by the factory, but I did not opt for it at the dealship when I purchased the car.
When I try to use the switch on the driver side door to lock or unlock the car, nothing happens. First time in 10 years it has not worked.
Old 10-21-2009, 04:57 PM   #6
Civic minded
RonJ's Avatar
Does your radio have a valet button?
RonJ is offline
Old 10-21-2009, 05:02 PM   #7
Civic minded
RonJ's Avatar
Originally Posted by nickenumbers View Post
Fuse 51 under the hood is not blown...When I try to use the switch on the driver side door to lock or unlock the car, nothing happens. First time in 10 years it has not worked.
The power lock control unit is behind the driver door panel. Check whether the Wht/Grn wire at the control unit has battery voltage.
RonJ is offline
Old 10-21-2009, 05:05 PM   #8
Civic minded
RonJ's Avatar
These additional tests will help to pinpoint the problem:
RonJ is offline
Old 10-21-2009, 05:21 PM   #9
nickenumbers
Holy Cow! RonJ you are the amazing! Thank you very much for all the help!! Simply astounding!
Old 10-21-2009, 10:48 PM   #10
jcamb
jcamb is on a distinguished road
i have an extra power door lock control unit you can have for 20 bucks, in case it turns out thats what you need...
jcamb is offline
Old 10-22-2009, 10:31 AM   #11
nickenumbers
jcamb, please email me so I can get details on your extra power door lock control unit.
Old 10-22-2009, 11:39 AM   #12
nickenumbers
RonJ, can you contact me offline at nickenumbers@yahoo.com I wanted to ask you about the keyless aspect of the 98 Honda Civic. Even though I didn't opt for the keyless option from the dealership, what do I need to do to activate it?
I do have the Valet Switch on my head unit/radio.
Thank you.
Old 10-22-2009, 11:48 AM   #13
Civic minded
RonJ's Avatar
Pull the radio out and check whether connector B (see diagrams) is plugged into the rear of the radio or possibly loose and unplugged behind the radio. If you have connector B, plug it into the rear of the radio and purchase a remote.
RonJ is offline
Old 10-22-2009, 12:31 PM   #14
nickenumbers
RonJ, excellent. Thank you.
More questions.
1. Where would you suggest that I get the wireless remote?
2. Does it have to be a Honda Civic wireless remote or is any remote smart enough to memorize the signal from the head unit/radio?
Thank you.
Old 10-22-2009, 01:04 PM   #15
Civic minded
RonJ's Avatar
Of course, first verify that you have connector B behind the radio. If you do, here's one place that you can buy a genuine Honda remote:
http://www.hondaautomotiveparts.com/
(enter your VIN for best results)
RonJ is offline
lock motors, keyless entry baller_ivy Interior / Audio / Electronics 6 10-11-2011 08:44 PM
99 DX coupe: How install only driver-side power lock & keyless? jbwilliam Tech Archive (No Posting) 1 05-24-2010 11:42 AM
Aftermarket alarm...keyless entry, power locks Marita Tech Archive (No Posting) 1 08-29-2008 05:57 PM
help diy automatic door lock/keyless entry 96 dx hatch red ek hatch Tech Archive (No Posting) 22 10-27-2004 05:23 PM
