Search:
Welcome to ClubCivic
Head lights and instrument control lights flickering?
Responding Members:
User Tag List
Old 10-30-2009, 12:56 PM   #1
nickenumbers
Default Head lights and instrument control lights flickering?
Does anyone else have a problem with head lights and instrument control lights flickering?
This doesn't happen all the time, it happens intermittently. But it drives me crazy. The back light for the speedometer and revs and the headlights themselves go brighter then darker then brighter then darker.
Has anyone seen this or heard of this before? How do I fix it and what is going wrong?
Thank you.
nickenumbers is offline
Old 10-30-2009, 01:58 PM   #2
Does the battery light in the cluster stay on or flicker on and off while you are driving? You may want to have the alternator tested.
RonJ is offline
Old 10-30-2009, 02:49 PM   #3
nickenumbers
This is another stupid question, but how can I test my alternator?
Thank you.
Old 10-30-2009, 03:40 PM   #4
K-N-2-EK
K-N-2-EK's Avatar
take your car to o riellys or autozone or pepboys..ask for a alternator test...
K-N-2-EK is offline
Old 11-01-2009, 10:03 PM   #5
dragonfly7518
Default same issue
I am having the same problem - have noticed it periodically for awhile. Alternator is fine according to Auto Zone though. If I drive for more than 30 min or so sometimes my right turn signal stops working also.
We've replaced the fuses and the headlight bulbs. Any suggestions on what else could cause this problem?
dragonfly7518 is offline
Old 12-01-2009, 12:14 AM   #6
jay192
im having that problem now with my hatch my mechanic said it has something to do with one of my sensor wires being burnt out because its under the car I'll find out more on Wednesday and posts
jay192 is offline
Old 12-01-2009, 12:30 AM   #7
Check 7.5A fuse 15 under the dash.
RonJ is offline
Old 12-01-2009, 12:50 AM   #8
zb12691
Ebuilt Ricer
zb12691's Avatar
ok, here is the problem. you all have d16y7's. they made s***ty intake manifolds and s***ty wires behind it. a couple wires have rubbed through and are now grounding or sending power to where it shouldnt be. the wires are for your eld and gauge cluster
you might also notice your mph acts as a tach. just find the wires that are rubbed through and wrap them with electrical tape. there below the intake manifold. good luck getting to them. :)
1998 CIvic ex: EBUILT
Originally Posted by sf22189 View Post
s*** i get up to 245 on the highway with my 89 sohc non-vtec car. Do you have a manual? If so you have to shift up. Honda built the tranny so that after going so fast when you shift back into first it reacts as 6th gear. and so on up to 10gears!!!!
zb12691 is offline
Old 12-01-2009, 12:58 AM   #9
This is mostly correct. Several 96-99 engines are affected. Read this TSB.
RonJ is offline
Old 12-01-2009, 12:59 AM   #10
zb12691
Ebuilt Ricer
zb12691's Avatar
thats it, i work for a dealer, we fix this all the time
zb12691 is offline
Old 12-01-2009, 12:25 PM   #11
silvercivic99
i had this problem for a while... it is the alternator for sure.
silvercivic99 is offline
Old 02-25-2010, 08:21 PM   #12
HondaD16y8
Black Dragon
HondaD16y8's Avatar
i have a 97 Honda civic d16y8 and my lights flicker too. i changed my alternator and it fixed it for a while and started again. i looked at the wires behind the motor and it looked fine. it keep s blowing my alternator speed sensor fuse. the check engine light gives me a code for a o2 sensor. i still cannot figure it out. if anybody has any ideas, please let me know. it only has 117,000 miles on it with all new belts. so i cant be the timing belt.
HondaD16y8 is offline
Old 02-25-2010, 08:43 PM   #13
frankmoocivic
I <3 ROXY
frankmoocivic's Avatar
Quick question do you guys have aftermarket stereos or amps in your car?
frankmoocivic is offline
Old 02-25-2010, 09:51 PM   #14
K-N-2-EK
K-N-2-EK's Avatar
if the answer is yes to the above question ^^^^ find yourself a dual stage alternator...ive got friends who work at Electronic stores and specially the 06+ the alt. sucks. find a dual stage run you close to 300
Originally Posted by CHILD View Post
I gotta have a lil bit of everything going on at all times. I can't stand super fresh looking rides that have no go, or no interior (and any other similar combination)
Originally Posted by JohnS. View Post
I'm not so much a fan of 99-00 tails on 96-98's. 96-98's should stay 96-98's. Unless you do the front too.
K-N-2-EK is offline
Old 02-25-2010, 10:26 PM   #15
red98civ
red98civ's Avatar
i had this problem with my right turn signal but it was a lose wire from when i disconnected the halo's on my old headllights, check to make sure all wires are tight.
(may not be the issue in your case, but it cant hurt to check!)
red98civ is offline
flickering lights bestatter72 Exterior / Detailing / Bodywork 3 07-14-2011 02:04 PM
Dimming/Flickering Instrument Lights will85w4 Tech Archive (No Posting) 19 12-10-2009 10:49 PM
flickering lights curlzjr Interior / Audio / Electronics 2 02-24-2009 10:48 PM
Lights Flickering? speCivic Tech Archive (No Posting) 4 12-23-2006 08:39 PM
NEED HELP! instrument lights, corner lights and taillights OUT 1SLOEG8 Interior / Audio / Electronics 4 05-22-2006 02:26 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
