Search:
Welcome to ClubCivic
how can i test my distributor?
Responding Members:
User Tag List
Old 12-08-2009, 10:44 PM   #1
unr8ed06
unr8ed06's Avatar
Default how can i test my distributor?
my car cut out on the interstate yesterday and at first i thought it was my battery. after getting it home and trying to start it again and hooking the battery up to a charger it started but went dead. i pulled a plug wire from my distributor and held it cllose while a friend tried to start the car to see if the distributor was getting fire to it and i didn't see any spark. i'm thinking maybe the distributor is bad. my car has approx 120k on it and to my knowledge it's never been changed. is there anyway to test the distributor? i know auto stores can test the alternators and batterys but, can they test the distributor. i just wanna make sure that's the problem before i go and buy parts i don't need. i'm really not too sure what else it could be. if you've got any input please share. thanks.
unr8ed06 is offline   Reply With Quote
Old 12-08-2009, 11:30 PM   #2
Ej8Kid
Too Much Traction
Ej8Kid's Avatar
Check the fuse, I wasted 40 bucks on a tow and got a new dizzy, Lifetime Warranty. Turns out it was a fuse, why didn't I check it earlier? Because someone stole my fuse box cover when my car was in a shop.
Ej8Kid is offline   Reply With Quote
Old 12-09-2009, 01:10 AM   #3
What Civic?
XpL0d3r's Avatar
check the plugs and wires too. start with the cheapest and work your way up.
Originally Posted by Bhikku View Post
At least i have a banjo coming in the mail, i had ordered it while drunk as f*** on saturday....i have no idea how to play a god damn banjo...
( '02 Acura RSX Type-S | '05 Kawasaki Ninja 500RR | '97 Honda Civic B18 Turbo | '05 Infiniti G35 Coupe (SOLD) )
XpL0d3r is offline   Reply With Quote
Old 12-09-2009, 01:18 AM   #4
When you turn the key to ON(II), can you hear the fuel pump prime for 2 seconds?
Use this method to check for spark at the plugs.
If you lack spark, definitely first check 15A fuse 9 in the dash fuse box.
Next check for CEL codes. Click here.
If fuse 9 is fine and there are no CEL codes, pull the coil and ICM out of the distributor. Test resistance of the coil and take the ICM for testing at an auto parts store.
RonJ is offline   Reply With Quote
Old 12-09-2009, 11:32 AM   #5
Sammo115
It be me, Sammo
Sammo115's Avatar
And RonJ does it again! I shall try this. Hope this works for the OP.
Originally Posted by YoungKadafi View Post
I know most people will be like WTF-R, but after that many episodes of bangbus my fingers can bend raw titanium.
Sammo115 is offline   Reply With Quote
Old 12-09-2009, 11:40 AM   #6
Originally Posted by CMRdevelopment View Post
...I shall try this.
The only difference for your car from 99-00 Civics is that 15A fuse 9 does not protect your distributor circuit. So there's no need for you to check that fuse.
Old 12-09-2009, 12:06 PM   #7
unr8ed06
unr8ed06's Avatar
yea i can hear the fuel pump prime and the 15a fuse is good. since the car has been home i've had it hooked to a battery charger thinking maybe the battery went dead. well last nite i tried starting it and it started fine once. me and a neighbor were checking it out and tried starting it but it wouldnt and then it did for a brief second then went dead again. this morning it has started fine on each attempt. i've gotta run a few errands but when i get home i'll check any codes then check the coil and icm. i'm just not too sure what else it could be. its weird that it starts sometimes then wont other times.
Old 12-09-2009, 12:19 PM   #8
If the engine will start sometimes, then fuse 9 must be fine as you said.
Important note: Listening for priming of the fuel pump and checking for spark must be done when the engine will not start. Otherwise, you learn nothing. In addition, your method for checking spark is not very effective, so try the method I posted.
Old 12-09-2009, 12:25 PM   #9
Sammo115
It be me, Sammo
Sammo115's Avatar
98 Sir. Would it still make a difference?
Old 12-09-2009, 02:07 PM   #10
unr8ed06
unr8ed06's Avatar
i took the dist cap off but, didn't really know where to go from there. i know i've gotta get the rotor off and pull the cover off to check the ignition coil but, i'm not sure how to get that rotor off and i didnt wanna break it. car wont start now that the cap is back on.
also checked the cel and i'm getting 7 blinks. there is no code 70 so i'm guessing its 7 which is tps sensor.
Old 12-09-2009, 02:13 PM   #11
No need to check distributor fuse 9 for a 98 Civic.
Old 12-09-2009, 02:20 PM   #12
Does your car currently run? If so, are there any performance problems right now?
Regarding code 7. Start by clearing the code from the ECU and then running the car to see whether the same code repeats. Remove the 7.5A Back Up fuse under the hood for a few minutes to clear the code.
To remove the rotor, you need to do quick flicks of the ignition switch to position the rotor screw where it is accessible.
Old 12-09-2009, 02:27 PM   #13
unr8ed06
unr8ed06's Avatar
the car ran fine before. it just suddenly shut down on the interestate the other day. didn't have a cel or anything. i put the dist cap back on and the car wont start again. i'll start pulling the rotor off now. i've got an ohmmeter. just didnt wanna break anything.
Old 12-09-2009, 02:58 PM   #14
Okay, so right now the engine won't start. A bad TPS would not generally prevent the engine from starting. Therefore, you need to go back to the basics. Do nothing else until you get answers to these items:
-Listen for the fuel pump priming
-Check for spark by the method I posted
-Clear the code and see whether it returns after cranking the engine.
Old 12-09-2009, 04:07 PM   #15
unr8ed06
unr8ed06's Avatar
i can hear the fuel pump but, i didn't have spark during the test. i cleared the codes and am not coming up with anything now.
earlier when i put the dist cap and rotor back on it fired up fine. i turned the car off and tried starting it again and it wouldn't. that's when i started doing all your test. the ignition coil is reading the correct outputs as well. do i just need a new distributor?
New Distributor SomeBlackGuy Parts for Sale 2 03-08-2007 07:55 PM
Distributor help!! EK_99_BOI Engine Tech / Drivetrain 4 02-22-2007 12:31 AM
z6 distributor brownbob06 Parts Wanted 0 01-11-2006 04:00 PM
What distributor do I need for my ZC? 91ZCcivic Engine Tech / Drivetrain 4 01-27-2004 05:17 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
