Search:
Welcome to ClubCivic
Gas Pedal Sticking
Responding Members:
User Tag List
Old 01-25-2010, 10:43 AM   #1
nickenumbers
Question Gas Pedal Sticking
I have noticed that my gas pedal is sticking a little bit. It is when I take my foot off of it, and I put my foot back on it, I have to push a little harder to move it, then it functions fine. But initially, I have to give it a little more of a push.
This doesn't happen all the time, but it is beginning to happen more frequently.
Any one else had this problem, or can tell me what to look for?
Thank you very much.
nickenumbers is offline
Old 01-25-2010, 10:46 AM   #2
Jersey8
B20: Detroit Muscle!
Jersey8's Avatar
i would first try the cheaper options: check your throttle body rotating assembly (valve plate inside, interior walls), spring, etc. if its gunky/dirty, clean it up with some throttle body cleaner.
if that doesnt work you may need to replace the cable
Jersey8 is offline
Old 01-25-2010, 12:20 PM   #3
redexcoupe
redexcoupe's Avatar
I have the same problem, and its not that bad, but its just kind of annoying. I cleaned out my TB and it seemed to help alittle bit, but not completely gone. I was gonna try and adjust the throttle cable, but then i noticed the nut around the cable is like super rusty and i didnt wanna deal with something breaking. How hard is it to replace the cable?
Does your car have cruise control? if it does? does it work really s***ty? Mine works but it doesnt like to keep a constant speed very well, it will speed up and then slow down and then speed up again and then slow down. It does that every time i use it. anyone else having this problem? or now how i could fix it?
redexcoupe is offline
Old 01-25-2010, 02:59 PM   #4
What Civic?
XpL0d3r's Avatar
Mine does the same thing from time to time. Cleaned my TB and it was much better.. still happens a little bit though
Originally Posted by Bhikku View Post
At least i have a banjo coming in the mail, i had ordered it while drunk as f*** on saturday....i have no idea how to play a god damn banjo...
( '02 Acura RSX Type-S | '05 Kawasaki Ninja 500RR | '97 Honda Civic B18 Turbo | '05 Infiniti G35 Coupe (SOLD) )
XpL0d3r is offline
Old 01-25-2010, 03:27 PM   #5
r34civic
well bro, not going to lie, my civic did the same thing, and yes, it was the floormats being a little to big and when i pushed the pedal down, it would get caught under the floormat lol, just check that out, cheapest fix you can do
r34civic is offline
Old 01-25-2010, 04:07 PM   #6
nickenumbers
Excellent answers everyone. Thank you very much. I will check out all of these things and get back to you!
Old 01-26-2010, 12:52 PM   #7
Jersey8
Jersey8's Avatar
get some pb blaster for that rusty nut.
ive personally never replaced a throttle cable but it can't be very hard. all it does is connect to the pedal, through the firewall, and to the cable stay/tb rotor.
i need to move my floormats back from time to time as well
Jersey8 is offline
Old 01-26-2010, 12:57 PM   #8
JDM_SPEC_SI-R
JDM_SPEC_SI-R's Avatar
i just took mine apart and did a complete over haul with cleaning it and polishing it up. i forgot to lube it up after wards so mine sticks when i punch it to the ground from time to time.
just needs oil/grease
Sponsors:
Zen MotorSports
RED IYE DIMENSIONS
Racing Trenz
JDM_SPEC_SI-R is offline
Old 01-26-2010, 01:11 PM   #9
When all other options are exhausted (e.g., thoroughly cleaning the TB), then the next step would be to replace the throttle cable, which can get notchy over time. A new OEM cable is about $30 if I remember correctly. This TSB describes the replacement procedure. It's pretty simple.
RonJ is offline
Old 01-26-2010, 02:51 PM   #10
Szady
D-Series Master
Szady's Avatar
Mine does it too. Kind of annoying. Last time I had it happen (on my old motor), the the throttle plate inside the TB was closing too much, causing it to bind/stick to the walls of the TB. I adjusted it so it didnt close as far, but still shut completely, and the issue was gone. I need'a take a look at mine and see whats up....
Szady is offline
Old 04-13-2010, 03:12 PM   #11
nickenumbers
Thanks for the info everyone. I have cleaned it a couple of times both where it attaches to the gas pedal inside the vehicle and under the hood. It is still sticking. It is my car, but my wife was driving it and she actually was remarking on it this past weekend. When mama ain't happy, no one is happy. ;-)
I am going to use RonJ's Service Bulletin above, order the throttle cable and replace it.
I will report more later. Thanks everyone and especially RonJ for the exact specific instructions.
Old 04-14-2010, 10:38 AM   #12
nickenumbers
1. When installing the new throttle cable do I need to add any lubrication?
2. If yes, what exact name and type of lubrication?
Thank you.
Old 04-14-2010, 11:18 AM   #13
No
RonJ is offline
Old 04-14-2010, 02:04 PM   #14
305ej6
305ej6's Avatar
check your floor mats, throttle cable.... or just contact Toyota they might be able to help you...
305ej6 is offline
Old 04-19-2010, 08:58 AM   #15
nickenumbers
Installed the new Throttle Cable. Was an easy installation. It took me about 15-20 minutes, and this was the first time I have ever done it. So, that means it was easy!
$25 Throttle Cable from my local Honda Parts Shop.
Gas pedal functions perfectly now! I have been testing for the last 3 days.
Thanks to everyone who helped me finally solve it!
(As a side note to all the nerdy people like me, my old throttle cable had the 3 inch rubber boot where it attaches to the throttle, ripped and torn. And this perhaps was part of my problem. In addition to what Ron J pointed out that no one can see but inside the plastic cover of the cable itself, the wire of the cable could be fraying and binding inside.)
Gas pedal SocalGreenz Engine Tech / Drivetrain 6 06-01-2011 03:29 PM
gas pedal tweedy17 Engine Tech / Drivetrain 0 05-21-2011 10:42 AM
gas pedal problem silk007 Tech Archive (No Posting) 5 10-31-2009 04:56 PM
Gas pedal sticks JasonxEHS Tech Archive (No Posting) 2 11-01-2008 08:33 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
