Search:
Welcome to ClubCivic
first time DIY head gasket replacement
Responding Members:
User Tag List
Old 02-09-2010, 03:27 PM   #1
6thgenex
6thgenex's Avatar
Default first time DIY head gasket replacement
ill start off that i am new to civic club community, HELLO!
okay, for sometime now my car has been overheating periodically.
found a hairline crack in the radiator, so i switched it out
along with the radiator hoses. work welled temporarily.
NOW, ive had coolant leaking underneath the engine and overheating.
but this time i wasn't able to control it with even the heater on max!
so i started to think it was a bad head gasket,
sure enough i take the spark plug out in piston one and what looks like its been steamed cleaned in there.
ive gone out and purchased a new head gasket set, since i am taking the timing belt off i said what the heck
might as well. so here is what i got:
head gasket set
timing belt
water pump
power steering belt
a/c belt
alternator belt
liquid gasket
i took the head to a machine shop and no cracks but it was warped.
im in the process of putting everything back in reverse order.
the belts are back on and the timing belt is set a TDC.
i just want to make sure im in the green,
everything seems to be running smoothly
any tips or suggestions?
thanks in advance
6thgenex is offline
Old 02-09-2010, 03:36 PM   #2
MidnightCivicEX
EK Ferio WIP
MidnightCivicEX's Avatar
did you get another head or something since your old one was warped??
MidnightCivicEX is offline
Old 02-09-2010, 03:41 PM   #3
6thgenex
6thgenex's Avatar
no. i had it resurfaced
6thgenex is offline
Old 02-09-2010, 05:39 PM   #4
UCCRacing
No Fun
UCCRacing's Avatar
Good job on doing the new parts, hope you went HONDA OEM since the price is the basically the same at least on t-belt and W-Pump but better quality. Not sure what you had liquid gasket for? No need for any of that....
If it is running good then you should be fine.. Hope you did burp the system?
Sounds like you are good to go though...
Originally Posted by Docta2002 View Post
tranny=transmission/transexual depending on the context
Originally Posted by mal2000si View Post
nooo its not "vtech" makes toys for babies..
"VTEC" is what gives honda's power... haha!
Originally Posted by R3dline5.0 View Post
club civics new slogan, "clubcivic, we are here for the t***"
UCCRacing is offline
Old 02-09-2010, 05:48 PM   #5
sohclubkid
Sick 6/6
sohclubkid's Avatar
i sprayed my headgasket wit copper spray from the auto-parts store when i put it on. supposed to help seal it.
sohclubkid is offline
Old 02-09-2010, 05:53 PM   #6
UCCRacing
No Fun
UCCRacing's Avatar
Waste of money... The head gasket is designed to seal with out it...
Old 02-09-2010, 05:59 PM   #7
6thgenex
6thgenex's Avatar
ive heard that sealing the o-rings and head gasket cover with liquid silicone gasket helps for extra sealing...ive heard
6thgenex is offline
Old 02-09-2010, 06:14 PM   #8
sohclubkid
Sick 6/6
sohclubkid's Avatar
hasnt hurt thus far....
Old 02-09-2010, 06:59 PM   #9
frankmoocivic
I <3 ROXY
frankmoocivic's Avatar
hey man welcome!!!!!! im very glad to see that you are doing things yourself and doing it right. alot of people that come on here "talk lik dey frum da hood" or want to do things the cheapest way but you seem to have a grasp of DIY and doing it right. lol but good job so far man. and enjoy your stay.
frankmoocivic is offline
Old 02-09-2010, 09:03 PM   #10
UCCRacing
No Fun
UCCRacing's Avatar
No not saying it will hurt lol Just not needed....
LOL f***ing crazy guy! He is just saying that is how he used to talk and doesn't want you to get picked on too! JK lol
Old 02-09-2010, 11:00 PM   #11
6thgenex
6thgenex's Avatar
thanks for all reponses!
another question, if i apply liquid silicone sealant on both sides of the head gasket for an extra seal,
does it work?
6thgenex is offline
Old 02-09-2010, 11:18 PM   #12
UCCRacing
No Fun
UCCRacing's Avatar
does it work?
Again, this does nothing... It is designed to seal without the sealant, if anything I see it causing a problem... The head gasket thickness is vital and when you add s*** to it that is not necessary it does nothing..
I could be wrong but if you add to it and lets say after some time some of it breaks down and is gone, then that part leaks.... Stick with the Honda book on all gaskets, if it doesn't say apply a sealant then don't....
Old 02-10-2010, 04:34 AM   #13
6thgenex
6thgenex's Avatar
http://www.youtube.com/watch?v=raI2ZXGu4Hc
http://www.youtube.com/watch?v=eXkzhHN2q4A
so finished up, now its not starting....help
posted some vids, let me know
6thgenex is offline
Old 02-11-2010, 01:40 AM   #14
6thgenex
6thgenex's Avatar
http://www.youtube.com/watch?v=RKLa-PI01IM
got it to start, but now i hear a whistling/rattling noise now
what could it be?
6thgenex is offline
Old 02-11-2010, 05:08 AM   #15
UCCRacing
No Fun
UCCRacing's Avatar
Really hard to tell... Where is it leaking coolant? Into the oil? If so it is from applying gasket sealant I bet, the head gasket isn't designed for that, and applying that only makes it not sit correctly.... That rattling noise you really can't hear until the very end and it is so hard to say.... Did you tighten everything to the proper specs per the manual?
D16Y7 head gasket replacement JE Good New to the Site? 0 08-30-2011 04:06 PM
Head Gasket Replacement XeroReboot Engine Tech / Drivetrain 9 10-26-2010 09:38 PM
DIY: D series head gasket replacement + ARP head bolt install DarkCreep Engine Tech / Drivetrain 0 06-28-2010 08:22 PM
Head Gasket Replacement 1995 civic lx krisma 5th Generation Honda Civic (1992-1995) 13 06-16-2009 04:13 PM
head gasket replacement Roodki Engine Tech / Drivetrain 18 11-17-2004 09:44 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
