Search:
Welcome to ClubCivic
Random Misfires!!!!!
Responding Members:
User Tag List
Old 02-16-2010, 10:37 AM   #1
dabz1981
Default Random Misfires!!!!!
2000 civic Lx auto with 95k miles - no mods
CEL came on.. took it to autozone and i got 6 codes: random missfire, missfire on cylinder 1, 2, 3 and 4, and EGR valve/incorrect valve clearance . The car runs crappy all the time missfiring when it's hot or cold. i've tried everything (well almost everything as i know this can be caused by many diff things) in the following order sinse the issues began:
Ignition switch - i heard civics of this generation has ignition switch issues/recalls (mine did not have a recal but the symptoms matched)
Spark plugs/wires - replaced with NGK plugs and OEM Honda wires
Fuel filter
Distributor rotor and cap
Distributor - brand new distributor not refurb (included new coil, new cap, new rotor - adjusted timing after)
After i replaced the distributor there was no CEL!!! So i decided to drive it round for 30 mins up to 70mph to make sure all was fine, car ran perfect. But then pulling from a stop sign the CEL started blinking again and eventually stayed on.. took it back to autozone and i'm now getting 4 codes: random missfire, missfire on cylinder 1, 2 and 3... i'm inclined to rule out the bad EGR valve code i first got because it's no longer showing up but i dont know anymore... any assistance/advice would be GREATLY appreciated.
dabz1981 is offline
Old 02-16-2010, 11:39 AM   #2
brian762
Are you sure the wires are on the plugs all the way and they didnt pop off? thats what happened to mine after i replaced my plugs and wires, also check the dizzy cap to make sure they didnt pop off there.
brian762 is offline
Old 02-16-2010, 12:21 PM   #3
dabz1981
yes the plugs are on the right place on the cap, everything is tight. i just confirmed that this 2000 civic lx does not have an EGR valve.. .only the HX models did so i'm ruling that out completely, which makes me even more confused now.... also to add, the car runs rough on idel and acceleration (missfires)
dabz1981 is offline
Old 02-16-2010, 12:25 PM   #4
Genuine Rolla
Its PETEY PETE, y0!
Genuine Rolla's Avatar
Where does your car idle at?
x
[ProjectJayDeM, y0!] [<><] [CCSC#9] [College.$tatus] [ClubCivicCouch Crew#4]
Originally Posted by connies92hatchie View Post
Cmon do you see how small Max's head is? Pushing Dank's body through these p***y walls is gonna be a piece of cake!
Genuine Rolla is offline
Old 02-16-2010, 12:28 PM   #5
brian762
the only other thing i can think of is timing, but if it ran fine for a bit, i think that would rule that out.
brian762 is offline
Old 02-16-2010, 12:35 PM   #6
dabz1981
It's idling low.. i'll have to say between 600 -700 RPMs with occasional missfires but not enough to shut it off. it struggles when taking off and puffs like crazy.
dabz1981 is offline
Old 02-16-2010, 12:37 PM   #7
dabz1981
i've beein thinking about that but it did run fine before the cel came back on. now i'm thinking it may be the map sensor but i'm not getting codes for it or the cat converer or o2 sensor... just stupid misfires and an egr valve i dont have
dabz1981 is offline
Old 02-16-2010, 12:49 PM   #8
What are the specific CEL codes? Did a previous owner install and HX ECU into your LX?
RonJ is offline
Old 02-16-2010, 01:14 PM   #9
dabz1981
when the issue first started i had 6 codes: misfire codes for all cylinders (po301, po302, po303, po304), another that said incorrect valve clarance/EGR valve, and the random misfire code. after replacing the distributor I currently have po301, po302, po303 and the random missfire codes after about 30 minutes or so of driving it with no CEL. Could timing cause this issue? i feel comfortable with the timing adjustment i did after replacing the distributor, and as previously mentioned the car did run great right after i did.
dabz1981 is offline
Old 02-16-2010, 01:44 PM   #10
Post this specific code.
RonJ is offline
Old 02-16-2010, 02:00 PM   #11
dabz1981
P0171 is the code.
dabz1981 is offline
Old 02-16-2010, 03:37 PM   #12
P0171 is not a CEL code for the EGR system. As you said, an LX has no EGR system. The code instead tells you that the engine is running lean. Start by replacing the fuel filter.
RonJ is offline
Old 02-16-2010, 04:23 PM   #13
dabz1981
already did. replaced the fuel filter, ignition switch, spark plugs (ngk), wires (honda oem as the after market ones did not fit properly), replaced distributor cap and rotor, and when this did not work decided to replace the entire distributor and adjusted the timing just to be safe.
dabz1981 is offline
Old 02-16-2010, 04:55 PM   #14
already did. replaced the fuel filter...
Missed that. Measure the fuel pressure and check the fuel pressure regulator while you are at it.
RonJ is offline
Random speedygonzales Off Topic 15 08-04-2011 07:21 AM
94 DX Hard to start, misfires, ans when it warms up it sputters and dies! HELP!! ribblet New to the Site? 5 01-02-2011 02:16 PM
Random?!? DxHatchGirl Off Topic 5 10-22-2009 10:16 AM
Car Misfires Under Accel 95 EJ Coupe Tech Archive (No Posting) 20 12-20-2008 09:44 PM
CEL - Misfires? Blk05Civic Tech Archive (No Posting) 3 04-15-2005 12:11 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
