Search:
Welcome to ClubCivic
No gas pedal pressure and car wont start pls help!
Responding Members:
User Tag List
Old 02-23-2010, 04:11 PM   #1
quincyb11
quincyb11's Avatar
Default No gas pedal pressure and car wont start pls help!
Hey guys! I have no gas pedal pressure at all on my 99 civic dx. It was working fine last night when I started it, revved it a couple times, then this morning I fired it up and it was idling pretty high. It went from 1500 to 2000 then when I tried too apply some gas there was no pressure at all, it would just go straight to the floor without any resistance, doesn't stick it though comes right back up. Now I can't start my car at all. I am very puzzled.
I recently replaced a fuel injector because cylinder number 4 wasn't firing. That obviously wasn't the problem because it's still not firing. I'm guessing it may be a burnt valve or damaged valve seal that is causing the misfire.
Anyways i'm not sure what has happened. My car ran fine before last weekend with just a misfire and little bit of rough idle. After I changed that fuel injector it seems like a series of problems are starting to happen.
So now my car wont start plus I have no pressure in my gas pedal.
Any help would be appreciated guys!
K-SERIES ALL DAY EVERYDAY!!!!
quincyb11 is offline
Old 02-23-2010, 04:51 PM   #2
Aldundra
Aldundra's Avatar
high idle usually indicate vacuum line problems.
Check around the engine bay for disconnected/worn vacuum lines
Don't know whats going on with the throttle though
Aldundra is offline
Old 02-23-2010, 05:52 PM   #3
First solve the gas pedal problem. My guess is that the throttle cable broke or came loose above the pedal or at the throttle body.
When the pedal is fixed, check for spark and fuel if the engine won't start. Any CEL codes?
RonJ is offline
Car pulls to the right wen i push the gas pedal aztekpride3 Tech Archive (No Posting) 12 02-18-2011 12:20 AM
Car won't start pls help civic_21 Tech Archive (No Posting) 3 03-22-2009 05:37 AM
VTI Wont Start... Pls help ahussa47 Tech Archive (No Posting) 3 02-10-2008 11:17 AM
i need help pls. my car will not start. :cry: 92lstcvc Engine Tech / Drivetrain 2 03-24-2006 02:36 AM
Ran out of gas, car wont start eg4me Engine Tech / Drivetrain 5 07-18-2004 07:31 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
