Search:
Welcome to ClubCivic
h22a vtec cut out
Responding Members:
User Tag List
Old 03-04-2010, 02:43 PM   #1
lilskater519
Bronze!?
lilskater519's Avatar
Default h22a vtec cut out
ok so ive had problems with this for quite some time and thought it was a head gasket but multiple tests proved wrong.
originally i was loosing much coolant and vtec would randomly cutout everyonce and a while.
-i found 2 large leaks once the car was in the air and fixed them(one in a random connector made from the swap and one at the heater core).
-next i did a compression test on each cyl. and it passed with flying colors.
-from there i did a vaccum test and also passed that with great outcomes..
soo..
does anyone have any idea what could make vtec not work at times or feel weaker?
wheelie bar
lilskater519 is offline   Reply With Quote
Old 03-04-2010, 06:50 PM   #2
Jabes
hows your oil pressure and oil levels cause if there low that could be the problem
Jabes is offline   Reply With Quote
Old 03-06-2010, 09:01 PM   #3
lilskater519
Bronze!?
idk how id check my oil pressure but everything seems in check.
got a little leak from that sensor in the back by oil filter.
she does need an oil change but i dont think that would effect things so much
would the weight of oil effect at al?
as of now theres 40wt in it.
wheelie bar
Old 03-06-2010, 09:01 PM   #4
lilskater519
Bronze!?
c'mon guys help me out here!
wheelie bar
Old 03-07-2010, 10:24 PM   #5
PhntmSk8r
H23VTEC
Fix your oil leaks.
Run 10w30, 40 is kind of thick (but not horrible). Thick oil will cheat you into a higher pressure, but isn't necessary on a well/properly built motor.
Engine codes?
Is the screen in your vtec solenoid clean?
Have you tried replacing the vtec solenoid?
Are the wires making good connection at the vtec solenoid?
ALL MOTOR H23 VTEC POWERED EJ8
PhntmSk8r is offline   Reply With Quote
Old 03-08-2010, 01:13 AM   #6
lilskater519
Bronze!?
Originally Posted by PhntmSk8r View Post
Fix your oil leaks.
Engine codes?
ok sweet.
also with this new header the down tube is really close to my oil pan will that heat my oil to the point i should run thicker??
the engines only got 40k so w30 will be fine.
no cel's.
ive checked the screen once but ill look again.
and ill look into the solenoid and wires.
thanks!
wheelie bar
H22a vtec valve cover: a KeeleDesign KeeleDesign Parts for Sale 1 08-09-2010 12:54 AM
H22a vtec helppppp please AtM- Engine Tech / Drivetrain 7 03-20-2010 01:00 AM
F/S 92-95 H22A Distributor / Vtec Controller VAFC I Rowdyjrb86 Parts for Sale 0 02-14-2008 06:26 PM
H22A surge/cut-out issue EGlude Attitude Engine Tech / Drivetrain 1 12-07-2005 05:46 AM
does vtec cut off? bad6as Tech Archive (No Posting) 4 09-13-2004 11:16 AM
Copyright 2007 ClubCivic.com
Freelance Web Design
