Search:
Welcome to ClubCivic
89 or 91 octane is good for Civic?
Responding Members:
User Tag List
Old 03-10-2010, 11:44 PM   #1
dihanp88
dihanp88's Avatar
Smile 89 or 91 octane is good for Civic?
A friend told me to use 91 octane on my 1999 Civic LX 1.6 to get a better mpg... is it any true? I have been using 89 and my mpg is around 26-28... Some people say If it's a high compression engine then only you want high octane. what do you guys think?
thank you
dihanp88 is offline   Reply With Quote
Old 03-11-2010, 12:00 AM   #2
Regular 87 octane only in a stock LX.
RonJ is offline   Reply With Quote
Old 03-11-2010, 01:30 AM   #3
terceltyler
The Silver Bullet
Agreed. Anything else is a waste of money unless you build the engine or are running boost.
Originally Posted by toneekay View Post
Right now my car is set up for autox/rr and I want it to be more street friendly (so when woman ride in my car they wouldn't be bouncing all over the place)... (great for looking at teh boobs, but not so pleasant in getting into them pantaloness)!!!
terceltyler is offline   Reply With Quote
Old 03-11-2010, 02:29 AM   #4
mpaired_7126
mpaired_7126's Avatar
when i got my d16y7 i used 91 on mines. nothing wrong but it just burns clean and fast. it doesnt hurt the motor however it hurts ur wallet. this was the time when gas was like five dollars a gallon.
mpaired_7126 is offline   Reply With Quote
Old 03-11-2010, 03:33 AM   #5
DarkCreep
D16Y8+T
DarkCreep's Avatar
Your friend is a dumb ass.
I also have a few friends that are dumb asses and think that running 91 on their stock Civics gets them better MPG and more power.
Dumbasses......
YOU DON'T NEED A CAMBER KIT, YOU NEED AN ALIGNMENT
DarkCreep is offline   Reply With Quote
Old 03-11-2010, 08:59 AM   #6
Szady
D-Series Master
Szady's Avatar
I used to have a friend who put 93 in his 100% stock EG coupe with the D15b7. He told me it adds a few HP.
Szady is offline   Reply With Quote
Old 03-11-2010, 11:16 AM   #7
77amc
Yep it does get you better mpg! I've done it countless times.. (when I could afford it or wanted to 'clean out' a fuel system)
From what I've read years ago, the higher octane actually slows down the flame travel so it burns more efficiently across the crown as the piston passes TDC and it pushes more on the downstroke of the rod.
That's why on High comp engines, you will have pre-detonation or 'pinging' BEFORE TDC. If it was firing just after TDC, it wouldn't 'ping' at all because the resistance of the crank being at TDC would already be past and heading down the other side... Make sense to ya?
NOW, what may be happening in a number of peoples engines is that gas stations are selling crap gas for premium prices and thus crapps out the O2 sensor, gives false readings to the ECU, cloggs up the cat, overheats it and forces the exhaust back into the engine eventually killing it...
SO, Just do some cheap things first.. Check if your grounds are clean/tight, pull your cap, check for RED DEATH (red dust that is produced by dieing bushings, needs to be replaced) Scrape your connections inside cap/on rotor, (spray with good silicone) make sure timing is CORRECT (not 'by ear'. If timing is off you will be chasing your tail by adjusting other stuff that isn't the problem) Get some NGK V-groove plugs that are for your heat-range. Don't get all caught up with the multi-tipped plugs, You can't change physics of electricity! OHM-out your wires, should be around 1000/ft or less (less is more $$$)
If you have a 1-wire o2, configure a 4-wired one. (it's helped me even on OBD-0! Minimal, but none the less) If your emissions will allow, header without the cat, OPEN up that exhaust. (enngines are AIR PUMPS, free it up)
Do these or some, log your results per week, and make changes that your $$ alow, keep more logs and then help someone else out by making a thread.. Who knows, it might end up as a 'sticky'
E
77amc is offline   Reply With Quote
Old 03-11-2010, 12:57 PM   #8
No, this makes absolutely no sense for the Civic D16Y7 engine, which is specifically designed to run most efficiently on 87 octane gas. Running anything except 87 octane in this engine is at best a waste of money and at worst harmful.
Old 03-11-2010, 01:04 PM   #9
Esotericimage
Try GOOGLE 1st
ron, u beat me to it after reading all that
Esotericimage is offline   Reply With Quote
Old 03-12-2010, 09:04 AM   #10
charlie brown
smokey
charlie brown's Avatar
its crazy the car myths people bite into and waste money on
charlie brown is offline   Reply With Quote
Old 03-12-2010, 09:07 AM   #11
bizoneoeh
Ex-Gang Member
bizoneoeh's Avatar
Dumbasses......
yeah.... 87 octane is what you should be using unless you're boosted then you should use at least 93. It's your money tho, you can waste it if you want.
bizoneoeh is offline   Reply With Quote
Old 03-12-2010, 04:12 PM   #12
terceltyler
The Silver Bullet
You can use 91 too depending on your tune.
Old 03-12-2010, 04:15 PM   #13
tonyM
caca poopoo
tonyM's Avatar
truth, my car is tuned on 91. Hopefully not for long though.
http://img249.imageshack.us/img249/3827/tonym.jpg
tonyM is offline   Reply With Quote
91 octane in my b18b1 civicspencer Engine Tech / Drivetrain 5 11-01-2010 07:35 PM
knocking on 98 civic LX engine with 87 octane cvic98lx Engine Tech / Drivetrain 9 03-29-2010 02:19 PM
What Octane ? OnePogiEm1 Tech Archive (No Posting) 3 08-21-2008 08:57 PM
octane gasoline speCivic Tech Archive (No Posting) 14 08-27-2006 08:49 PM
Octane?? AZSprmnn Tech Archive (No Posting) 27 11-03-2003 01:09 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
