Bad ELD or short
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 03-12-2010, 01:02 PM   #1
loudferio13
loudferio13's Avatar
loudferio13 is on a distinguished road
Default Bad ELD or short
well took car to a garage today cause of idle surging.well it was all fixed.while I was there I had them check the check engine light.he came up with codes for bad 02(no cat) and eld.Well awhile back i had some problems with my alternator it would turn on and shu off completely whenever it wanted.well with RonJ's help I thought I had it figured out.So My mechanic finds out the number 15 fuse alt/sp sensor was very loose and is hard to get the fuse to set right.My question is is that whats causing the eld to throw a code and why do I even get the slightest dimming from doing anything in my car.Im talking putting windows down or up headlights on/off just anything it drops like 0.1-0.2 volt.Not sure whats wrong but my batts in my car are both deep cycle high ah and res batts from xs power and I have an ho alt so not sure why anything should drop voltage especially like putting the windows down.please help its annoying.
loudferio13 is offline
Old 03-12-2010, 01:59 PM   #2
Civic minded
RonJ's Avatar
Reputation level: 137
RonJ will become famous soon enoughRonJ will become famous soon enough
If fuse 15 loses contact with the terminals in the dash fuse box, CEL codes will be thrown and the alternator won't work properly. You may need to replace the dash fuse box to fix, but make sure the problem is not a short in the wire harness (click Fuse 15 link in my signature).
Don't guess, troubleshoot
-Manuals: site 1 and site 2; -Spark; -Fuses; -Pull 92-00 CEL codes; -Fuse 15 TSB; -Clean IACV or FITV
Please do not PM me tech questions.
RonJ is offline
Old 03-12-2010, 02:09 PM   #3
loudferio13
will do going to check this weekend also would this make like the lights and power windows seem like flicker or very slowish its just weird that im not blowing fuses.also would it be smart to bypass the eld or would it kill my alt or batt
Old 03-12-2010, 03:21 PM   #4
Civic minded
RonJ's Avatar
If fuse 15, the dash fuse box, or the wire harness is the problem, then bypassing the ELD will do no good. Any of those problems will affect not only the ELD but also the voltage regulator inside the alternator and the O2 sensors.
RonJ is offline
Old 03-13-2010, 10:56 AM   #5
loudferio13
so just check the fuse 15 then like you said and hopefully not have to get a new fuse box.can i just run 4 brand new wires.thanks again man
Old 03-13-2010, 07:56 PM   #6
loudferio13
hey ronj do you have the diagram of where all the wires go fo the alt, fuse box, underhood fusebox, and around intake.
93 civic neutral safety, ignition switch, ELD, ? diablosmiles1 Engine Tech / Drivetrain 7 07-02-2012 01:20 AM
89 civic dx ELD and o2 cel Code #1,#20 stiletto407 New to the Site? 1 06-10-2012 11:13 AM
Where is the ELD and what does it do? Jas0n Tech Archive (No Posting) 6 01-19-2010 11:05 PM
eld problem t85konrad Tech Archive (No Posting) 2 06-05-2007 03:55 PM
is short shifter bad for tranny? pinkdevil Engine Tech / Drivetrain 35 11-19-2005 07:11 PM
