Search:
Welcome to ClubCivic
Go Back   ClubCivic.com - Honda Civic Forum > Honda Civic DIY / How To > DIY How To's > Interior / Audio / Electronics DIY How-To's
How To: Install shift boot, e-brake boot and lid cover
User Tag List
Old 03-23-2010, 03:50 PM   #1
dbramaged
dbramaged's Avatar
Default How To: Install shift boot, e-brake boot and lid cover
After posting pictures of my interior, people have been asking how to do this, so here it is:
Depending on the year of your car, it may vary, but it's pretty simple. (Instructions based off 6th Gen)
This method will not allow use of factory e-brake handle, must have aftermarket e-brake handle.
Shift Boot
1. Remove Shift knob
2. Remove the center console, rear section and front.
3. 2 screws are holding shift boot in place, remove those and the bracket and boot pulls right out
4. remove shift boot from bracket, !!! BE CAREFUL !!! although it's a light metal it will easily cut you if your grip slips as I cut one of my fingers to the bone!!!
5. Grab the new shift boot, wrap around bracket and make slits to match
6. replace bracket and shift boot back in console
E-Brake Handle & Boot
7. E-BRAKE! This is fun! - Remove the handle any way you feel comfortable - I cut my e-brake handle off with a dremel & cutting wheel
8. remove rubber boot.
9. Install new boot and slide down the e-brake as far as you can to make room for your new AFTERMARKET handle
10. install new e-brake handle as far onto the lever as possible to make sure the button will engage fully
11. Pull E-Brake boot over base of handle (Most aftermarket handles have a lip to fit the boot over - I had to use a flat head and work it around for a tight fit
Center Console Armrest Cover
12. There are 2 philips screws holding the cover in place - remove them and the lid comes right off
13. There are 3-4 more screws on the under side of the cover holding the plastic in place - remove screws and the plastic inside will pull from the lid
14. Either you can remove the OEM fabric or leave it on, I left mine on. Wrap the lip with the new cover - pulling the excess material into the under side of the lid - Try to remove all wrinkles near the edges
15. replace plastic inside to the lid by loosely installing the removed screws to allow for some adjustments. The plastic piece will pull the remaining excess material once you tighten the screws complete.
16. Use a flat head or butter knife carefully to flatten any wrinkles and wedge under the lid
17. re-install lid to console and put back into car
18. Install front section of Console and replace shift knob.
You're done! - Enjoy the new interior pieces... If you need pictures, I can post some later tonight.
350Z sitting on Nismo LMGT4s
dbramaged is offline   Reply With Quote
Old 03-23-2010, 06:08 PM   #2
AllStockHatch
Unregistered User
AllStockHatch's Avatar
Nice write up! Pics would do justice here, you know people are going to ask for them.
Originally Posted by RonJ View Post
Jump your wife's service connector. She may be throwing some CEL codes.
Originally Posted by EJ6Civic27 View Post
Ive tried, with no luck. She's throwing the "too tired" code, and the "is that all you want from me, is sex?" code. Looks like I either need to re-build it, or trade it in for something different.
03 s2000
99 Civic DX Hatch
96 Civic CX Hatch
94 Del Sol
07 Ruckus
98 Accord
My build thread-->http://www.clubcivic.com/board/showthread.php?t=204411
AllStockHatch is offline   Reply With Quote
Old 03-23-2010, 06:24 PM   #3
dbramaged
dbramaged's Avatar
will do.
Old 03-25-2010, 03:52 AM   #4
moebiius
there isn't a way to to the e brake handle without cutting it? there's gotta be a way...when you cracked it open with the dremel...how was it held together from the inside? compression? glue? please give me and the people here some insight on that.......thanks OP
moebiius is offline   Reply With Quote
Old 03-25-2010, 10:02 AM   #5
dbramaged
dbramaged's Avatar
Unfortunately, I have already thrown it away.... But when I originally looked, it appeared almost like there was plastic tension clips in place holding it. But based on where they were and the the actually e-brake level, it just didn't make any sense... Sorry. I just didn't look at it very much as once I decided I was going to cut it off, I wasn't planning on figuring it out...
Old 03-25-2010, 11:11 AM   #6
Genuine Rolla
Its PETEY PETE, y0!
Genuine Rolla's Avatar
Pics definitely would be awesome.
Moved to the How-To Section
x
[ProjectJayDeM, y0!] [<><] [CCSC#9] [College.$tatus] [ClubCivicCouch Crew#4]
Originally Posted by connies92hatchie View Post
Cmon do you see how small Max's head is? Pushing Dank's body through these p***y walls is gonna be a piece of cake!
Genuine Rolla is offline   Reply With Quote
Old 03-25-2010, 01:48 PM   #7
dbramaged
dbramaged's Avatar
I can't edit the original post now..........
Old 03-25-2010, 01:50 PM   #8
EG6 LIFE
hey that hepls alot man thanx
EG6 LIFE is offline   Reply With Quote
Old 03-25-2010, 01:50 PM   #9
EG6 LIFE
helps^^*
Old 03-25-2010, 04:30 PM   #10
dbramaged
dbramaged's Avatar
Default Version 2: With PIctures!
Shift Boot
5. Grab the new shift boot, wrap around bracket and make slits to match - I circled the two tabs that I did not use, it works just fine without.
E-Brake Handle & Boot - (I already tossed my e-brake handle and wasn't able to re-inact this process)
Old 08-19-2011, 01:08 AM   #11
PokenSomeSmot
where did you get that material from???
PokenSomeSmot is offline   Reply With Quote
Old 09-04-2011, 09:36 AM   #12
jdmem205
Great diy I used it to fix my new shift boot correctly and will use it when I get the new fabric for the armrest
jdmem205 is offline   Reply With Quote
FS: Shift Boot(s) / Shift Knob / Circuit Hero Shift Extender (CA) Evan. Parts for Sale 64 01-06-2010 03:42 PM
EG3 Boot Lid Midnight_EG Tech Archive (No Posting) 4 05-12-2009 08:06 PM
Boot for e brake an shift knob OlivertheG Tech Archive (No Posting) 3 10-24-2007 11:54 PM
WTB: Black shift boot (blue stiching) and shift knob junior1023 Parts Wanted 1 01-17-2007 11:31 PM
How to install JDM Shift boot on a 94 Integra? LatinEM2 Interior / Audio / Electronics 6 12-25-2003 01:27 PM
Copyright 2007 ClubCivic.com
Freelance Web Design
