Input Shaft Bearing
» Thread Makers: Thread titles must summarize the technical question or problem, and the first post must include the year, trim, and any mods for your Civic.
» Responding Members:
» All Members: Rude or flaming posts will not be tolerated, though civil debate and disagreement are acceptable.
Old 03-31-2010, 06:03 PM   #1
mss8rc
mss8rc is on a distinguished road
Default Input Shaft Bearing
Here's my problem: I have a stock D15B7 with manual transmission that has 250,000 miles on it. The transmission is 100% orginal. I have a bad input shaft bearing (sounds like metal grinding or spinning when the clutch pedal is out and goes away when I push the clutch pedal in). Should I replace the input shaft bearing or should I wait until the transmission dies and just replace the whole tranny? I don't know if I am fully capable of replacing an input shaft bearing because I've never really taken apart the tranny before. From what I understand on other posts, when I do the input shaft bearing...it is probably a smart idea to replace the clutch and other bearings as well (which I can't really afford). I am pretty mechanically inclined though (I've done everything else that has ever gone wrong with my car).
mss8rc is offline
Old 03-31-2010, 06:13 PM   #2
Civic minded
RonJ's Avatar
Reputation level: 137
RonJ will become famous soon enoughRonJ will become famous soon enough
Start shopping for a replacement tranny.
Don't guess, troubleshoot
-Manuals: site 1 and site 2; -Spark; -Fuses; -Pull 92-00 CEL codes; -Fuse 15 TSB; -Clean IACV or FITV
Please do not PM me tech questions.
RonJ is offline
Old 04-01-2010, 09:23 AM   #3
x23Curtis23x
x23Curtis23x's Avatar
x23Curtis23x is on a distinguished road
x2 and when u go to get a new tranny get one from an ex or si there better imo
x23Curtis23x is offline
Old 07-23-2010, 03:42 AM   #4
95exb18
95exb18 is on a distinguished road
ok so when the clutch is out and makes a grinding noise its the imput shaft bearing and when you push it in and it grings is the throw out? cause mine only stops grinding when ur at a complete stop with the clutch in, when i take it out it sounds like there is rocks bouncing around in the case
95exb18 is offline
Throw out or input shaft bearing Manderson Tech Archive (No Posting) 8 08-28-2009 05:20 PM
Input shaft bearing Kswest Tech Archive (No Posting) 6 04-13-2009 11:34 PM
input shaft bearing? ftrms Engine Tech / Drivetrain 1 02-05-2009 06:05 PM
input shaft bearing reyscivic Tech Archive (No Posting) 10 11-10-2008 09:18 PM
Input shaft bearing? eortizr Tech Archive (No Posting) 0 08-30-2006 12:57 PM
